Help with connecting 8" baja design lights with AllPro bumper
Discussion in 'Lighting' started by cgilbane, Nov 18, 2009.
  1. Nov 18, 2009 at 7:56 PM
    cgilbane
    cgilbane [OP] Well-Known Member
    Avon, CO
    07 Tacoma dbl cab
    remote reservoir fox shocks front and rear
    I am installing the allpro off road sheet metal front bumper. I have the light hoop and had a question about the installation of the 8" baja design sol tec light.
    Do I have to buy a wire kit to hook the lights up? The lights came with just a wire sticking out the back.
    How do these lights connect to my car?
    Do I have to buy an aftermarket switch to turn them on and off?
  2. Nov 18, 2009 at 8:58 PM
    bajamoon
    bajamoon Well-Known Member
    STEVE
    Whittier
    you need a auxillary light harness, you can get them at pep boys or autozone for like $20. it is not hard to wire them up, just follow instructions and should take about 20 minutes.
    and what do you mean connect to your car, to the light hoop?
  3. Nov 18, 2009 at 9:00 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    i'm thinking he means connecting them to power and a switch. all should be detailed in the instructions for the wiring harness
  4. Nov 18, 2009 at 9:03 PM
    bajamoon
    STEVE
    Whittier
    that is what i was thinking but the soltek la paz don't mount like regular lights unless he ordered them from baja designs knowing what he wanted.
  5. Nov 18, 2009 at 9:04 PM
    The_Hodge
    SC
    ahhh....and from the questions, it might not have happened
  6. Nov 18, 2009 at 9:05 PM
    bajamoon
    STEVE
    Whittier
    :facepalm:
  7. Nov 18, 2009 at 9:28 PM
    cgilbane
    Avon, CO
    07 Tacoma dbl cab
    I got the la paz lights with the bumper from allpro off road with my entire bumper.
    So i will go to autozone and buy the light harness. Does the light harness come with a switch or can I wire the new baja lights into the old factory switch for my oem fog lights?
  8. Nov 18, 2009 at 9:37 PM
    bajamoon
    STEVE
    Whittier
    are they hid, if yes you can put them into the fog light harness, i am sure you can hook up the halogen but i don't know how. the light harness comes with a switch.
  9. Nov 18, 2009 at 9:44 PM
    The_Hodge
    SC
    i wired my 510's to the stock harness...chopped off the connector and spliced in the 2 wires.
  10. Nov 18, 2009 at 9:48 PM
    bajamoon
    STEVE
    Whittier
    :bowdown: :jerkoff: :D
  11. Nov 18, 2009 at 9:49 PM
    cgilbane
    Avon, CO
    07 Tacoma dbl cab
    I have the halogens. So you think ill need to buy a new wiring harness or can I just wire them into the oem fog lights wires
  12. Nov 18, 2009 at 9:50 PM
    The_Hodge
    SC
    just sayin....i dont think i'd run anything too demanding off of the stock circuit though, just in case.
  13. Nov 18, 2009 at 9:51 PM
    bajamoon
    STEVE
    Whittier
    jhodge said that is the way he did it and he knows what he is talking about. just cut the connector of the end and close one eye and touch the wires.:D
  14. Nov 18, 2009 at 9:53 PM
    cgilbane
    Avon, CO
    07 Tacoma dbl cab
    anyone got any diagrams out there for this? maybe im just too tired from being awake for 48 hours but I cant visualize what you mean
  15. Nov 18, 2009 at 9:58 PM
    bajamoon
    STEVE
    Whittier
    you have the two wires coming off the soltek lights, you might have to make them longer to reach the fog light harness. cut the connector at the end of the fog light wire that used to plug into the foglights then connect the two wires from the fog light wires to the soltek wires. do you know what we mean
  16. Nov 18, 2009 at 10:05 PM
    The_Hodge
    SC
    yeah...definately going to need to be extended. the ones off the lights should be black/red and the ones going to the fogs arent colored like that. one of them has a black stripe and i used that as the black/ground. everything has worked on mine for over 6 months. i think the 510's are only 55W
  17. Nov 18, 2009 at 10:43 PM
    bajamoon
    STEVE
    Whittier
    i think the soltek's are 100w or 130w
  18. Nov 18, 2009 at 10:46 PM
    The_Hodge
    SC
    that'd definately be pushing it IMO...it'd take some research to see if the relay's, fuses, etc could handle that much
  19. Nov 18, 2009 at 10:52 PM
    bajamoon
    STEVE
    Whittier
    agreed, i just hooked up my lightforce hid's to the fog lights and no problems but double that you will most likely blow a fuse at least.
  20. Nov 19, 2009 at 1:09 AM
    cgilbane
    Avon, CO
    07 Tacoma dbl cab
    so instead of hooking into the fog light wires, if i just buy the wiring kit from auto zone, will i still blow a fuse? I dont wanna be running it that way if it might overload it?
    what do i need to do to not blow a fuse?
