Map & Dome LED light problem 1st gen
Discussion in 'Lighting' started by johnyt2, Jan 23, 2010.
  1. Jan 23, 2010 at 12:08 AM
    johnyt2
    johnyt2 [OP] Active Member
    johnyt
    Sacramento
    SR5 Debadged
    Clear Corners, Roll Bar, Flowmaster, 4- 6x8 infiniti kappas,Diamond D3 10'' sub, eclipse cd5030, Color match satoshi grill, color match fender flares and corner lights. DEBADGED, trd plates.
    I just installed some led festoon bulbs in my 2002 taco and discovered a problem. Without the keys turned on the ignition, the led bulbs are dim.(struggling to stay on) anyone know how to fix this problem plz?
  2. Jun 8, 2010 at 11:53 AM
    oregon.country
    oregon.country Well-Known Member
    Mackenzie
    Oregon
    02 4x4 TRD Black
    Level kit, and rancho coil over shocks.
    Same thing happened to my 2002 I was wondering how to fix it as well. How did you get the light cover off the lights above the rear view mirror?
  3. Jun 15, 2010 at 2:48 PM
    RPain
    RPain Well-Known Member
    Chandler, Arizona
    2016 Tacoma DCSB 4x4 TRD Sport
    Link to build in sig
    Under the mirror you will see a removable plastic tab, pry it off with a flat head and then pull the entire plastic piece off after that. Hope mine aren't dim :/
  4. Jun 15, 2010 at 5:42 PM
    Manlaan
    Manlaan Well-Known Member
    Greg
    Riverton, Utah
    2002 XtraCab SR5 V6 4x4 Black
    See Signature
    Thats just the way it is. Those connections dont get full power unless the key is in the ignition.
    Pretty sure you'd have to do some rewiring to get it full power all the time. Probably run a new wire with a relay running off the old connection.
    I suppose the reason they do this is to not have your battery run down as fast if you leave them on.
