Hid help
Discussion in 'Lighting' started by MOT, Feb 8, 2010.
  1. Feb 8, 2010 at 8:07 PM
    MOT
    MOT [OP] Prez of @BattleBornToyotas
    Daniel
    Las Vegas
    08 DB DC 4X4 Sr5 Sport
    Black Housing Head, Custom Retro fit, T-Rex #2 Eyelids 50 inch ToughLight Radius Bar and 2 20 inch Bars behind grill with BAMF mount, T-Rex #2 Eyelids, Custom Vegas Dezert Fab Front Bumper and Rock Sliders,Wet Okole's, WeatherTech Mats, Magnaflow Exhaust, Pro Comp 6 InchStage 2 Lift, K&N Intake,
    So i am looking on ebay what is the best hid kit to buy guys i want 10000k for the head lights and 3000k yellow for the fogs help!
  2. Feb 8, 2010 at 8:18 PM
    MReedTRD10
    MReedTRD10 Active Member
    Laredo, Texas
    2010 TRD Sport DCLB
    LED Halo headlights, HID 10000K headlights,3000K HID fog lights, LED dome lights, LED map light, Pioneer AVIC-X910BT touch screen navigation bluetooth dvd.
    just find one that is in your price range. I have purchased probably about 10 sets for different vehicles for around $70-$80. just make sure it comes with the ballast and bulbs. if you just want a cheap set of HIDs. i know alot of guys here do the retro fit which is a bit more pricey
  3. Feb 8, 2010 at 8:20 PM
    MOT
    Daniel
    Las Vegas
    what are the buld # for the fogs and the head lights i think heads are 9003 right and the fogs are h4 am i right?
  4. Feb 8, 2010 at 8:26 PM
    MReedTRD10
    Laredo, Texas
    2010 TRD Sport DCLB
    Headlights 9003 or H4 10000K blue
    Fog lights 9145 or H10 4000K yellow
    i have HIDs for both my headlights and fog lights and i have 10000K as well
  5. Feb 8, 2010 at 8:27 PM
    memario1214
    Colton
    Missoula, MT
    you dont want 10000k for anything... They have no light output. Just my .02. My 6000k is almost too blue for me.
  6. Feb 8, 2010 at 8:29 PM
    MOT
    Daniel
    Las Vegas
    so you are saying eather will work for the head light and fogs y is there two to chose from just asking just getting in to the head light mod thing? ya i want the deap blue and the bright yellow is the 10000k bright?
  7. Feb 8, 2010 at 8:33 PM
    MReedTRD10
    Laredo, Texas
    2010 TRD Sport DCLB
    i have 10000K and they are pretty bright, but there is brighter.
    and yes they both work, i am not sure the difference. i think they are the same bulb. i could be wrong. but when i searched the bulb number those came out.
    google sylvania. and it should be OSRAM SYLVANIA and you can search your bulb number. but the bulb numbers that i gave you are what i found after i searched
  8. Feb 8, 2010 at 9:09 PM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
  9. Feb 11, 2010 at 6:38 PM
    yosh2000
    yosh2000 Well-Known Member
    CO
    '17 Tundra CM 5.7
    yep, you know what are brighter....4300k, 5000k, shoot, even 6000k!!
    learn what the K means, then get back to us...:D
    check out denso or matsushita ballasts, phillips bulbs, and casper shields...
  10. Feb 11, 2010 at 7:02 PM
    MOT
    Daniel
    Las Vegas
    what watt should i run guys 35 or 55watt
  11. Feb 11, 2010 at 7:08 PM
    Jigzor
    Jigzor Well-Known Member
    Pennsylvania
    20 Gladiator Rubicon
    Steersmarts Draglink, Tie rod, Track Bar
    35w for both headlights and fogs.
    6k Heads H4 bixenon (They will be blue and have higher light output than 10k)
    3k fogs H10
  12. Feb 11, 2010 at 7:13 PM
    rmb_crew
    rmb_crew My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007‎
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
    I have 55W 6k heads and 35W 3k fogs. And they are awesome. DDM is the way to go.
  13. Feb 11, 2010 at 7:16 PM
    MOT
    Daniel
    Las Vegas
    55watt seams to be better but will it be to hot? and mess things up? Melt?
  14. Feb 11, 2010 at 7:20 PM
    AriZonaD54
    AriZonaD54 BANNED in 49 states...
    Andrew
    Valley of the Sun
    35W 5000k!!
    Grabbed some nighttime photos of the HID fogs and headlights;
    Here's complete darkness, you cant even make out the truck!
    Help from a big flood-light....
    Foglights on only...
    HID 5000k's in Headlights and Fogs. Both on...
    SuperWhite LED license plate bulbs...
  15. Feb 11, 2010 at 7:26 PM
    rmb_crew
    havent had a problem with the 55Ws yet. They should be fine, they have lots of room in there and there are vents on the back side of the light to vent hot air. I didnt go 55W for the fogs bc they are smaller and dont have the vents. Probably would have melted....
