Fog Light Mod!
Discussion in 'Lighting' started by MOT, Mar 27, 2010.
  1. Mar 27, 2010 at 11:25 AM
    MOT
    MOT [OP] Prez of @BattleBornToyotas
    Daniel
    Las Vegas
    08 DB DC 4X4 Sr5 Sport
    Black Housing Head, Custom Retro fit, T-Rex #2 Eyelids 50 inch ToughLight Radius Bar and 2 20 inch Bars behind grill with BAMF mount, T-Rex #2 Eyelids, Custom Vegas Dezert Fab Front Bumper and Rock Sliders,Wet Okole's, WeatherTech Mats, Magnaflow Exhaust, Pro Comp 6 InchStage 2 Lift, K&N Intake,
    Ok guys i know there are alot of thread for this i had on saved so i could to it to day but can not find it new had to clean comp Help please! There was one with good eazy to follow pic with it i know you have to do somthing to the relay them use a connector to go in to the green wire some where help guys!
  2. Mar 27, 2010 at 11:26 AM
    MOT
    Daniel
    Las Vegas
    Help Bump!
  3. Mar 27, 2010 at 11:29 AM
    oldtacomaguy
    oldtacomaguy four forty four
    Dave
    SE Conn.
    08 SR-5 4WD Impulse Red Pearl
    Alpine deck and amp, Polk speakers front and rear, Kenwood subwoofer, windows tinted to 20%, Sockmonkey decals, TSB, Eibach springs and Bilstein 5100's
  4. Mar 27, 2010 at 11:32 AM
    MOT
    Daniel
    Las Vegas
  5. Mar 27, 2010 at 11:37 AM
    MOT
    Daniel
    Las Vegas
    I Really Want To Do This Mod Today!:(
  6. Mar 27, 2010 at 11:49 AM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    Clearly or you wouldn't have bumped your original post after only one minute.
    The link posted above is the one I used and had no problems. Took me literally like 3 minutes to complete.
  7. Mar 27, 2010 at 11:56 AM
    bivey
    bivey Well-Known Member
  8. Mar 27, 2010 at 11:58 AM
    MOT
    Daniel
    Las Vegas
  9. Mar 27, 2010 at 11:59 AM
    jtav2002
    Josh
    Reading, PA
    Maybe he saw that, but that won't help since it's for 1st gens.
    And what do you mean finish? I just used a wire tap. I can run outside and take a pic if you really need it.
  10. Mar 27, 2010 at 12:00 PM
    MOT
    Daniel
    Las Vegas
    Ya i know what to do at relay but what do i do at green wire
  11. Mar 27, 2010 at 12:01 PM
    jtav2002
    Josh
    Reading, PA
    Just get a wire tap to tap the wire from the relay to the factory wire you have to splice into. I'll run outside and get you a pic.
  12. Mar 27, 2010 at 12:13 PM
    jtav2002
    Josh
    Reading, PA
    Ran the red wire from the relay to the green wire. At the green wire I just used the blue wire tap to tap my red wire from relay to the green wire.
  13. Mar 27, 2010 at 12:32 PM
    MOT
    Daniel
    Las Vegas
    Bro you rock! so that it you just end the wire at the splice thing at the gree wire?
  14. Mar 27, 2010 at 12:34 PM
    jtav2002
    Josh
    Reading, PA
    Yes, sir, obviously used the part of a blade connector for the relay, then just had the wire long enough to reach that green wire and used that connector there to splice into it and that's it. Other types of wire taps you could probably use, I just used that kind since I had a lot of them laying around.
  15. Mar 27, 2010 at 12:37 PM
    MOT
    Daniel
    Las Vegas
    Sweet so after that is done i can turn then on and off with the fog light switch! It is to good to be true! what kinda wire gage and conetor size you use? O And Thanks for helping with the pics!
  16. Mar 27, 2010 at 12:40 PM
    jtav2002
    Josh
    Reading, PA
    I don't even remember what gauge it was, not all that heavy. I'll have to see if I can find the rest of the wire I had a spool of it laying around somewhere. It's slightly heavier than that green wire you tap into. So perhaps you can judge of that roughly what size to use.
    Just be aware that the anytime fog light mod means, anytime lol. You'll have to remember to turn the switch off when you turn the car off because they stay on. Naturally not an issue at night but if you run them during the day you might forget they are on.
  17. Mar 27, 2010 at 12:50 PM
    MOT
    Daniel
    Las Vegas
    Ok Cool Thanks i saw a guy put a fuse in the one i saw that i was looking for do i need that or will i be ok you dont have one right!
  18. Mar 27, 2010 at 1:58 PM
    jtav2002
    Josh
    Reading, PA
    Obviously taking the precaution of having a fuse is never a bad thing. Although plenty have done it the way I have without problems. I've had mine done since I got the truck in August 2009 and have yet to have an issue. Up to you really. But no I do not have a fuse myself.
  19. Mar 27, 2010 at 2:00 PM
    SoCalR
    SoCalR Well-Known Member
    Rand
    San Diego, CA
    05 TRD Sport PreRunner
    Really? Well, maybe it's different on the newer ones, but on my 05, the fogs turn off when I turn off my truck. Essentially like a DTRL.
  20. Mar 27, 2010 at 2:05 PM
    jtav2002
    Josh
    Reading, PA
    WTF? I wish mine turned off and had no power when the truck is off. Hmm.
