-   -   HOW TO: Tinting tail lights, The right way (PICS) (http://www.tacomaworld.com/forum/lighting/84694-how-tinting-tail-lights-right-way-pics.html)
THExBUSxDRIVER 04-01-2010 06:51 PM
So I used the search feature but never could find a how to thread for this, so I went ahead and made one. Hopefully it isnt a repost.
And please be gentle as this is my first write-up:o
This is easier to do in a well lit area....like outside lol.
Tools and equipment needed:
-- Ratchet with 10mm socket
-- Powder free latex gloves (optional)
-- 800 grit sandpaper
-- 1000 grit sandpaper (optional)
-- 2000 grit sandpaper
-- Microfiber towel (optional as paper towels worked well also)
-- De greaser liquid (I just used gasoline)
****I would like to add that if you dont have a buffing wheel, you could just purchase a headlight restore kit from 3M that is sold at autozone or any other parts store and used the buffing wheel that is included.****
-- Now you can do your tail lights and restore luster to your headlights:D
-- VHT NiteShades
http://i197.photobucket.com/albums/aa34/GOO5E/shade.jpg
-- Clear coat (any one will do, I used the plain 'ol clear)
http://i197.photobucket.com/albums/a...resitclear.pnghttp://i197.photobucket.com/albums/a...O5E/images.jpg
--Rubbing compound of your choice along with Meguiars PlastX
http://i197.photobucket.com/albums/a.../Photo0839.jpg
-- Any polishing product of your choice.
Along with a tool to apply the polish and rubbing compounds, otherwise it will have to be done by hand....time consuming.
So we start off with the tail light, untouched in all its stock glory
http://i197.photobucket.com/albums/a.../Photo0819.jpg
http://i197.photobucket.com/albums/a.../Photo0820.jpg
So to remove the rear light you will use the 10mm socket
--There are only 2 bolts per side.
--They are the highest and lowest ones, leave the other in between alone as they do not hold the light. (sorry no pic)
Once those are removed it time to pull the light out. There are 2 prongs that hold them in and they will take some force to get them to let go.
http://i197.photobucket.com/albums/a.../Photo0838.jpg
Then disconnect the light bulbs with some simple twists
http://i197.photobucket.com/albums/a.../Photo0837.jpg
Next use your product to clean the light off. (I used gasoline)
Take the 800 grit paper and start to sand the light while using water. (I recommend to let the papers soak in water while removing the lights, this makes them a bit more flexy and easier to work with)
--Between different grits, wipe down the light and dry it to see that you have got the whole light.
Once you are done with the 800, start to use the 1000, then drop to the 2000 grit paper
--The 2000 will make it look like it has a flat smooth satin look.
http://i197.photobucket.com/albums/a.../Photo0821.jpg
http://i197.photobucket.com/albums/a.../Photo0822.jpg
Once done with the sanding all together, wipe the light down with your cleaning product( Again, I used regular 'ol gasoline;)). Then let them sit to dry. Using the microfibers will help speed it up.
-- Once they are dry try not to touch the lens surface with your fingers as this will put grease on them, powder free latex gloves come in handy.
So the lights are dry now, good. They should both look like they have the same consistency in texture.
--Now you are ready to apply the VHT NiteShade, remember that it will cure a bit darker than what it looks like freshly sprayed.
**Allow 20-30 min between tint coats**
Hold the can about 7 inches away from the light for better coverage. On the can it says like 12 inches but this will only give you a speckled look and will make you use more coats for good coverage....and more coats means darker lights (which can be a problem with local law enforcement)
Here is the difference after one coat
http://i197.photobucket.com/albums/a.../Photo0823.jpg
***For best and most even results, stand the sanded lights up next to each other and spray across both to get the same coverage on both.***
http://i197.photobucket.com/albums/a.../Photo0825.jpg
Sun's position made them look a bit different from each other but they where even:D
Here is one after 3 coats and a test to see how it would look
http://i197.photobucket.com/albums/a.../Photo0836.jpg
Once you are satisfied with the level of tint let the light dry to the touch, then cure in sun light for about 45-60 min.
When the tint is dry, apply the clear coat of your choice. (I used Krylon with gloss finish)
**It says it dries in 10 min but give it 15min between coats.**
I recommend at least 7-13 coats of clear for better protection, and it'll keep the buffing wheel from burning through the clear to the tint. Be happy to apply more if you wish.
Try to avoid letting the clear run at all cost.
Here it is with 5 coats of clear. Ignore the water spots lol.
http://i197.photobucket.com/albums/a.../Photo0835.jpg
Once COMPLETELY dried, repeat the sanding steps in the same order, but this time use more strokes with LESS FORCE. Remejber to have patience at this level.
This sanding step will get rid of that 'orange peel' effect/texture.
And here is the clear coat sanded.
http://i197.photobucket.com/albums/a.../Photo0842.jpg
Now, the lights are sanded, you are ready to use the rubbing compound.
--I mounted the light to do this because I had no other way to hold them steady, besides its only rubbing compound and polish so your truck wont get hurt.
http://i197.photobucket.com/albums/a.../Photo0844.jpg
Apply good amounts of rubbing compound to your application tool or the rag that you will be using. If using a power drill this stuff WILL get flung all over the place so be ready for a bit of a mess.
((***Remember to rub it clean in between applications of the compound, the PlastX, and the final wax***))
After you are done applying the compound, move on to using the Meguiars PlastX to take out the finer scratches.
Then finally move on to the waxing product of your choice to seal the deal.
Here is the finished product:D
http://i197.photobucket.com/albums/a.../Photo0848.jpg
http://i197.photobucket.com/albums/a.../Photo0846.jpg
http://i197.photobucket.com/albums/a.../Photo0849.jpg
The looks I have gotten from other taco owners is fun, I have even bee asked to do a pair:D:D
Hope this helps you guys out, and have fun! But most of all PATIENT!
05PreRunner 04-01-2010 07:00 PM
Great Write-Up!
Lights look nice!! :thumbsup:
TacoSupreem 04-01-2010 07:00 PM
awesome i need to do this! +1
littledvl 04-01-2010 07:01 PM
Great write up, I will being doing this within the next few weeks.
tacomakid96 04-01-2010 07:02 PM
Great write up!! Looks awesome on your truck man
jodiddly33 04-01-2010 07:07 PM
wow those look awesome!
THExBUSxDRIVER 04-01-2010 07:08 PM
I would like to add that if you dont have a buffing wheel, you could just purchase a headlight restore kit from 3M that is at autozone or any other parts store and used the buffing wheel that is included.
I'll add this to the write up
Oskie_78 04-01-2010 07:12 PM
GreAt job on those tail lights! I wanna to this to mine
jodiddly33 04-01-2010 07:15 PM
BTW can you let us know if they cure any darker over time?
skistoy 04-01-2010 07:53 PM
Outstanding!
JoshR324 04-01-2010 07:54 PM
Great write-up
JM76 04-01-2010 07:58 PM
too bad you are across the country, you could do mine. Nice work!:)
ClemsonTacoma 04-01-2010 08:04 PM
Great write up! :thumbsup:
747 04-01-2010 08:08 PM
Nice writeup! Lights look stealthy! Is that a '92 Mustang in the background...if so, post pics...sweetest body styling of all the stangs (imo)!
Tillers_Rule 04-01-2010 08:12 PM
Nice! Going down your pictures I was thinking; "wow, that looks like shit" Then when I got to the last pics after it was buffed, I was like; "wow, that shit looks awesome!!":thumbsup:
Simon2150 04-01-2010 08:41 PM
Awesome job!
TorenApart 04-01-2010 09:13 PM
Sticky this... or add to cheap/free mods!
skunk 04-01-2010 09:18 PM
FRIGGIN SAH-WWWEEEEET! I have been wondering how the process went. You did a great job. I'm definitely doing this mod next!:D
Cars0n` 04-01-2010 09:20 PM
awesome job man. i needed this ;)
Palmetto Pete 04-01-2010 09:25 PM
Awsome job, look and write-up! Thanks!
