DTFtacoma's 2006 Long Travel
Go Back   Tacoma World Forums > Tacoma Garage > Long Travel Suspension
Long Travel BS Thread
Old 04-19-2014, 08:11 AM   #45341
it's about the off-road miles
tacokid09 is one of the sharper tools in the shedtacokid09 is one of the sharper tools in the shedtacokid09 is one of the sharper tools in the shedtacokid09 is one of the sharper tools in the shedtacokid09 is one of the sharper tools in the shedtacokid09 is one of the sharper tools in the shedtacokid09 is one of the sharper tools in the shedtacokid09 is one of the sharper tools in the shedtacokid09 is one of the sharper tools in the shedtacokid09 is one of the sharper tools in the shedtacokid09 is one of the sharper tools in the shed
tacokid09's Tacoma Gallery
does anyone know for sure if the motor mounts coming off the frame for a 2.7 6lug is in the same spot as a 4.0?
Old 04-19-2014, 09:09 AM   #45342
SPEEDY CRAWLER
4runnercaged is one of the sharper tools in the shed4runnercaged is one of the sharper tools in the shed4runnercaged is one of the sharper tools in the shed4runnercaged is one of the sharper tools in the shed4runnercaged is one of the sharper tools in the shed4runnercaged is one of the sharper tools in the shed4runnercaged is one of the sharper tools in the shed4runnercaged is one of the sharper tools in the shed4runnercaged is one of the sharper tools in the shed4runnercaged is one of the sharper tools in the shed4runnercaged is one of the sharper tools in the shed
4runnercaged's Tacoma Gallery
It's crazy how prone the lower ball joints are too breaking.
One of these days I will have the money for a uniball lower.
Old 04-19-2014, 09:21 AM   #45343
U MAD? OH U MAD
RJALLDAY702 is one of the sharper tools in the shedRJALLDAY702 is one of the sharper tools in the shedRJALLDAY702 is one of the sharper tools in the shedRJALLDAY702 is one of the sharper tools in the shedRJALLDAY702 is one of the sharper tools in the shedRJALLDAY702 is one of the sharper tools in the shedRJALLDAY702 is one of the sharper tools in the shedRJALLDAY702 is one of the sharper tools in the shedRJALLDAY702 is one of the sharper tools in the shedRJALLDAY702 is one of the sharper tools in the shedRJALLDAY702 is one of the sharper tools in the shed
RJALLDAY702's Avatar
RJALLDAY702's Tacoma Gallery
Originally Posted by 06HAOLE View Post
I understand it to be puncture but also containment in a roll over. If your truck is upside down for a while a stock fuel tank is going to leak everywhere while a fuel cell won't. Your stock fuel tank just has those straps to hold it to your frame. Once you build a mount for your fuel cell it isn't going anywhere.
However there are so many pending CARB changes that I've heard about that may make having one on a street truck difficult.
X2^ on what he said.
Also, you can kinda pick and choose where you want to put it, and having it off near the back helps a ton with weight distribution.
My stock tank is going to be the next thing to go.
Old 04-19-2014, 10:44 AM   #45344
from Dirt bike to Dezert Couch
SDSam has much to be proud ofSDSam has much to be proud ofSDSam has much to be proud ofSDSam has much to be proud ofSDSam has much to be proud ofSDSam has much to be proud ofSDSam has much to be proud ofSDSam has much to be proud ofSDSam has much to be proud of
SDSam's Avatar
SDSam's Tacoma Gallery
Actually thats the first i heard it being the bolts, and the other failures are mostly worn clapped out ball joints. I still check mine often and change them out at first sight of wear.
Old 04-19-2014, 12:14 PM   #45346
aka Senor Tacorojo
EL ROJO is one of the sharper tools in the shedEL ROJO is one of the sharper tools in the shedEL ROJO is one of the sharper tools in the shedEL ROJO is one of the sharper tools in the shedEL ROJO is one of the sharper tools in the shedEL ROJO is one of the sharper tools in the shedEL ROJO is one of the sharper tools in the shedEL ROJO is one of the sharper tools in the shedEL ROJO is one of the sharper tools in the shedEL ROJO is one of the sharper tools in the shedEL ROJO is one of the sharper tools in the shed
EL ROJO's Avatar
EL ROJO's Tacoma Gallery
Matt had it happen in his old truck while going over a speed bump. But...they were the same bolts that came with the balljoints and the used kit he got. I red loctite mine in.
Old 04-19-2014, 12:34 PM   #45347
SPEEDY CRAWLER
I have also seen a truck or two where the bolts broke. The bolts broke on mine too, but I think it was a result of the bolts being loose actually I'm pretty positive it was.
And Sam you're right yes most of them are due to clapped out ball joints, that's what my other breakages where from. But now I replace them at first sight of wear. Lesson learned on that one
Old 04-19-2014, 01:04 PM   #45348
Are u thinking about swapping in a 4.0
itd be hell of a lot easier if it was hahah.
More or less my stock mounts cracking so i wondering if i should keep the stock mount from the frame or start from scratch with an entirely new one.
Old 04-19-2014, 01:07 PM   #45349
anthony250f is one of the sharper tools in the shedanthony250f is one of the sharper tools in the shedanthony250f is one of the sharper tools in the shedanthony250f is one of the sharper tools in the shedanthony250f is one of the sharper tools in the shedanthony250f is one of the sharper tools in the shedanthony250f is one of the sharper tools in the shedanthony250f is one of the sharper tools in the shedanthony250f is one of the sharper tools in the shedanthony250f is one of the sharper tools in the shedanthony250f is one of the sharper tools in the shed
anthony250f's Avatar
anthony250f's Tacoma Gallery
:0
Old 04-19-2014, 02:34 PM   #45350
U MAD? OH U MAD
Faaaak man
Old 04-19-2014, 02:38 PM   #45351
TCprerunner is one of the sharper tools in the shedTCprerunner is one of the sharper tools in the shedTCprerunner is one of the sharper tools in the shedTCprerunner is one of the sharper tools in the shedTCprerunner is one of the sharper tools in the shedTCprerunner is one of the sharper tools in the shedTCprerunner is one of the sharper tools in the shedTCprerunner is one of the sharper tools in the shedTCprerunner is one of the sharper tools in the shedTCprerunner is one of the sharper tools in the shedTCprerunner is one of the sharper tools in the shed
TCprerunner's Avatar
TCprerunner's Tacoma Gallery
Could someone take a few min. Of there time and help me out with a susp. Question. Mostly out of ignorance and for the sake of knowing.
Directed at the rear. At higher speed is a softer pack going to handle/ride better? And the shock just keeps it from bouncing? Or do you want a stiff pack?
I see tons of info on what setup to run just wondering what you are going after for a good off road ride.
Old 04-19-2014, 03:01 PM   #45352
SPEEDY CRAWLER
A softer pack will ride better, but you want to make sure you have enough right height so you have enough up travel. Stiffer packs carry more weight so it really depends how much weight you plan on carrying in the back.
Old 04-19-2014, 03:13 PM   #45353
I have a 3 leaf pack and my truck rides like shit when unloaded but I hit bumps constantly while unloaded I would not want to go any more then 2" higher in the back would prefer 1.5 or less nothing like y'all do just unmaintained roads but want to get good performance. I don't haul more then bicycles or canoes on a normal basis.
Old 04-19-2014, 04:28 PM   #45354
Zam15 is one of the sharper tools in the shedZam15 is one of the sharper tools in the shedZam15 is one of the sharper tools in the shedZam15 is one of the sharper tools in the shedZam15 is one of the sharper tools in the shedZam15 is one of the sharper tools in the shedZam15 is one of the sharper tools in the shedZam15 is one of the sharper tools in the shedZam15 is one of the sharper tools in the shedZam15 is one of the sharper tools in the shedZam15 is one of the sharper tools in the shed
Zam15's Avatar
Zam15's Tacoma Gallery
New 7" bedsides for my DC!
Old 04-19-2014, 04:35 PM   #45355
How loud are aluminum strike pads when they hit the lca??
Old 04-19-2014, 04:51 PM   #45356
Originally Posted by RJALLDAY702 View Post
Faaaak man
yeeaaahhh... haha.
Old 04-19-2014, 04:55 PM   #45357
jeffz0rz is one of the sharper tools in the shedjeffz0rz is one of the sharper tools in the shedjeffz0rz is one of the sharper tools in the shedjeffz0rz is one of the sharper tools in the shedjeffz0rz is one of the sharper tools in the shedjeffz0rz is one of the sharper tools in the shedjeffz0rz is one of the sharper tools in the shedjeffz0rz is one of the sharper tools in the shedjeffz0rz is one of the sharper tools in the shedjeffz0rz is one of the sharper tools in the shedjeffz0rz is one of the sharper tools in the shed
jeffz0rz's Avatar
jeffz0rz's Tacoma Gallery
Why are you in a hotel lol
Old 04-19-2014, 05:27 PM   #45358
Zam15's Avatar
Been on business travel for almost a year. Live in SD but work half the time in LA. Glassworks is on the way so I just picked them up on the way to LA. Not going back for three weeks so I don't want them hanging out the back of my truck.
I think the reaction most people were having was "what the hell is that guy carrying" Some guy asked if I was working on the air conditioning haha
Can't a guy have a romantic evening with his bedsides in a hotel?
Surprised you could tell it was a hotel.
Old 04-19-2014, 05:58 PM   #45359
Marnes2986 is one of the sharper tools in the shedMarnes2986 is one of the sharper tools in the shedMarnes2986 is one of the sharper tools in the shedMarnes2986 is one of the sharper tools in the shedMarnes2986 is one of the sharper tools in the shedMarnes2986 is one of the sharper tools in the shedMarnes2986 is one of the sharper tools in the shedMarnes2986 is one of the sharper tools in the shedMarnes2986 is one of the sharper tools in the shedMarnes2986 is one of the sharper tools in the shedMarnes2986 is one of the sharper tools in the shed
Marnes2986's Avatar
Marnes2986's Tacoma Gallery
Originally Posted by Trusso24 View Post
Ground clearance? My links get in the way of the stock tank, that's why I had to ditch it.
Thanks guys! If those are the main reasons for having one, i think im just gonna wrap the tank in aluminum and reinforce the mounts.
If i roll over I just gotta make sure Ive got the extinguishers close by.
I just heard clearing smog is a bitch in california. RJ you gonna register in NV
Old 04-19-2014, 07:33 PM   #45360
Trusso24 has a brilliant futureTrusso24 has a brilliant futureTrusso24 has a brilliant futureTrusso24 has a brilliant futureTrusso24 has a brilliant futureTrusso24 has a brilliant futureTrusso24 has a brilliant futureTrusso24 has a brilliant futureTrusso24 has a brilliant futureTrusso24 has a brilliant futureTrusso24 has a brilliant future
Trusso24's Avatar
Trusso24's Tacoma Gallery
I've had truck parts sent to my hotel before lol. I'm in the room right now as we speak
Mid Travel with BS Thread Gelo760 Suspension 18949 11-26-2014 09:29 AM
IT BS thread chadderkdawg Technology 1730 11-26-2014 07:56 AM
Rcd 4.5" lift vs. Any long travel vs. Icon mid travel lepedog23 Long Travel Suspension 33 05-17-2011 07:31 AM
AZ BS thread... Masada Arizona 3940 10-03-2010 07:11 PM
