General Fabrication
Discussion in 'Long Travel Suspension' started by linked2002, Aug 19, 2011.
  1. Mar 2, 2014 at 1:10 PM
    #1501
    jeverich
    jeverich Well-Known Member
    Jake
    PNW/Kodiak
    07 2.7 4x4
    OME 886/Old Man Doug Suspension Lift, ARB Bumper, Bruteforce High Clearance w/Swing Out, De-badge, Block Heater, Homemade IFS Skid, 7" Kragens, Blue Seas Fuse Block, BlitzPro Fogs, 12k BadLands Winch, BAMF Sliders, ARB Locker, 4.88s Yaesu FT-1900R, Larsen 150B NMO Mount Antenna
    I don't even own a bender.. yet.
    But from the limited research I've done, i don't think you'd get very good results by using an oversized die. Fairly certain that the dies actually specific shape to them; rather than just being a straight form to the outside of your pipe/tube. Each manufacturer is a little different - I know JD2s claim to have more R&D than JMR, etc..
    Short version. I think you'd f up your bends pretty good.
  2. Mar 2, 2014 at 1:12 PM
    #1502
    thekernel114
    thekernel114 Well-Known Member
    Chilliwack, B.C.
    07 tacoma 4x4
    allpro long travel, shackle flip with ome dakars, cruisin offroad bumpers and sliders, 4.88 gears with arb's front and rear, budbuilt skids.
    Just do a test bend and see how much it deformes. If its to much you can always pack the pipe with sand to help it keep its shape.
  3. Mar 2, 2014 at 1:24 PM
    #1503
    RelentlessFab
    Eric
    Sparks, NV
    With how close the sizes are, I doubt it would be too bad. You'll probably just get a tad more flattening of the tube around the radius.
  4. Mar 2, 2014 at 2:01 PM
    #1504
    KenpachiZaraki
    KenpachiZaraki Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    Just started stick welding today, and I laid down some gnarly noob welds :laugh: 6011 on ac at 125a. I ended somehow welding a latch and a 2x4 gusset on a piece of angle iron. My father in law is gonna be like "WTF is this sh**?!" :rofl:
    Need more practice, I need to weld some tabs on my roof mount light bar, but don't have anyone to teach me so YouTube it was. I'll get it eventually, it sucks I can really only do any type of mods on the weekend's since work has me out of town 4-5 days a week.
  5. Mar 2, 2014 at 2:17 PM
    #1505
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Best way to learn is get some 1/4" flat stock and lay flat beads next to each other until you get it down, then move to vertical, then to joints.
  6. Mar 2, 2014 at 3:56 PM
    #1506
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    :thumbsup:
  7. Mar 25, 2014 at 11:08 AM
    #1507
    ComaRyder1
    ComaRyder1 Well-Known Member
    Dakota
    Las Vegas
    2000 tacoma 4x4 5speed caged FOX shocks
    2.5" bypass remote resevoir FOX shocks(front), caged(almost done) stage 3 clutch, cold air intake, flowmaster dump, 33x12.5 BFG A/T tires, 15x10" american racing rims, touchscreen dvd player with gps, 2 12" subs with 1000 watt amp n capacitor
    hi everyone i just joined this forum today. ive been working with steel for a few years now, and also attending school to become certified in several areas of welding, so im fairly savvy when creating the strongest possible design for any of steel structure. that being said, for the question im about to ask, im not looking for the easiest solution, but your advice on the strongest most effective solution.
    I am in the process of caging my cab, i am almost finished with the bed now. When assembling my cage inside the cab, would it be better to drill through the floor of the cab with the hole saw to weld my tubing to the frame? or should i just weld the tubing to a flat plate of steel, and then attach that to the floor of the cab?
    my tacoma was stock a month and a half ago and ive been working on her every weekend since, heres some pics of where im at so far on my build
  8. Mar 25, 2014 at 11:23 AM
    #1508
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Do not just weld it to the cab. What I did is cut square holes way too big, weld to plates on top of the frame. Build the structure and then you can knock the tack welds off the plates and drop the cage to weld the top
    Then after finishing all welding to the structure you can push back into place, re-weld the plates and gusset them
    Then you can tack the cab floor plates back in :)
  9. Mar 26, 2014 at 11:22 AM
    #1509
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Thanks for the replies. I tried it out and I'm satisfied with the results. :D
    1 5/8" tube in a 1.66" pipe die flattened only slightly more than the correct size, approx .03" more as far as I can tell. I wouldn't notice just by looking at it.
  10. Mar 26, 2014 at 12:36 PM
    #1510
    RelentlessFab
    Eric
    Sparks, NV
  11. Mar 26, 2014 at 2:16 PM
    #1511
    bluezac17
    bluezac17 New Member
    Zach
    British Columbia, Canada
    94' 22re
    uhhh kinda stuck and though this would be the right place to come for the answer? I have a 1994 pickup (extended cab, 22re) and i want to do the whole long travel thing but i don't want to have my bed removed (actually wanna be able to put stuff in the back of my truck) so is there a MT option that allows for that?
  12. Mar 26, 2014 at 2:50 PM
    #1512
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    I just realized this is in the LT section, weird.
  13. Mar 27, 2014 at 12:00 AM
    #1513
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    options on the front are endless. as for the rear and gaining travel without going into the bed, you could always relocate the shock mounts similar to the bamf relocation brackets. not entirely sure on how the older pickups are set up, but can't imagine a leaf spring set up having too many options. I know that's the plan for my rear if i ever save up the money to do so since I don't want to intrude on the bed space either. Other option is something like this guys set up for his 4runner. http://d24w6bsrhbeh9d.cloudfront.net/photo/4675318_460s.jpg
    though that takes some serious fabbing and r&d
    good luck
  14. Mar 27, 2014 at 10:18 AM
    #1514
    ComaRyder1
    Dakota
    Las Vegas
    wow man thats pretty solid looking i probably would have never thought of that. i like it alot, thanx for the advice. i will post some pics once i get to that part of my build. im going to finish the bed cage this weekend and hopefully have time to start on the cab
  15. Mar 30, 2014 at 11:08 AM
    #1515
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    I know exactly what you mean.
  16. Mar 31, 2014 at 9:09 PM
    #1516
    mreimann
    mreimann Well-Known Member
    Denver, CO
    '15 double cab Limited
    Icon C/O, Fox 2.0, All Pro Expo 2.0 leafs, Total Chaos UCA's, Airflow snorkel, Custom Built Bed Rack, Pelfrey aluminum front bumper and IFS skid, All Pro aluminum rear bumper, SmittyBuilt winch. RTT
    Are you thinking about filling it in with plate or just a pure tube bumper?
  17. Apr 2, 2014 at 3:27 PM
    #1517
    TRDtexasTaco
    TRDtexasTaco Well-Known Member
    JP
    Sunnyvale Trailer Park
    06 TRD PreRunner
    Billy shocks, Maxtrac spindels, AllPro standard leafs, BAMF shock relocation, King 2.5 smoothies
    i know that sound. its soothing
  18. May 3, 2014 at 3:26 PM
    #1518
    TRDtexasTaco
    JP
    06 TRD PreRunner
  19. May 3, 2014 at 3:44 PM
    #1519
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    looks pretty good. think it would look a little(slightly) better if the top tube was sticking out farther than the bottom one. only down side i see is the gap between the tube and lower grill/lights will be bigger.
  20. May 3, 2014 at 4:26 PM
    #1520
    Explor
    Explor Don’t take the trip ... let the trip take you
    John
    Northampton County Pa.
    FUN
    TRD valve stem caps , A Chimney & Back up camera. , Cooper STMaxx 255/80/17, SCS Dark Bronze wheels, , bed matt, weathertech floor liners and bug deflector , flyzeyez dash and glove box light , Best Top supertop, Brute Force Sliders , Bumpers ,KC back up lights, vent shades, tinting, superwinch 9.5 , Factor 55 winch thimble , KC ditch lights , BAMF IFS skid plates , Tepui Ruggedized RTT , Awning , Bed light kit , Hood Struts , Camburg UCAs ,Bud built gas skid , all pro differential skid , cbi jerry can holder , 15lb CO2 Tank , URD short shift , Defined engineering shackle bolt crossmember, Clazzio seat covers , 4:56 Nitro gears , ARB rear locker, CMKA12 compressor. Super Bump Stops, Bushwacker Flares , CBI bed rack , king resi front 700# , OME Dakar, Bilstein 6100's 10" light bar diode dynamics , AV monster fogs , TC bed reinforcement brackets , TC spindle gussets w swaybar Yeasue Ham , cb
