3 link help
Discussion in 'Long Travel Suspension' started by teddygrahams, Sep 15, 2011.
  1. Sep 15, 2011 at 9:39 AM
    teddygrahams
    teddygrahams [OP] Well-Known Member
    Hey, trying to find out some info on some axle angles. I need to know when the axle cycles does the pinion angle need to stay the same through out the cycle?
  2. Sep 15, 2011 at 9:47 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    i know theres a couple people that could help....
    try to PM Engage offroad, linked2002
    i know both of these people have done links, 2002 is in the process of one right now.
    post in the bs thread also
  3. Sep 16, 2011 at 4:52 PM
    DTFtacoma
    DTFtacoma Dezert Toy Fabrication Vendor
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    talk to 85yota on dezert rangers
  4. Oct 21, 2011 at 6:56 AM
    Lakeside623
    Lakeside623 Member
    Bryan
    Az
    08 prerunner
    Leveling kit, moto metals, added factory fogs and switch
    The pinion angle cannot stay the same. Its gonna go up as the rear end does..
  5. Oct 21, 2011 at 1:33 PM
    linked2002
    linked2002 Well-Known Member
    san diego
    02 tacoma, 3 linked, 6 over custom arms, cage
    links, custom 6 over arms, full 1.75 d.o.m. cage, 35 gallon cell, etc
    the pinion angle does not always go up as the rear end does. that is completely incorrect. you want your pinion at ride height to ideally be pointing on the same plane as the output shaft on your trans. where it moves from there through the travel will tell you what is going to happen with your truck. pinion angle increase as you bump, you are building in anti-squat into the system... pinion angle dives as you go up... that is squat.... or visa versa... ive been caught in one giant brain fart all day so i could be back-ass-wards.
  6. Oct 24, 2011 at 8:44 AM
    DTFtacoma
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
  7. Oct 24, 2011 at 8:58 AM
    linked2002
    san diego
    ^^werd! great thread right there.
  8. Oct 24, 2011 at 1:45 PM
    TC yota
    TC yota Well-Known Member
    Tyler
    Escondido
    Ha
    only if you have a one piece driveshaft
  9. Oct 24, 2011 at 1:53 PM
    linked2002
    san diego
    see and i never understood why people say that. when you have it on the same plane as the output shaft (even in a 2 piece driveshaft format, the first shaft connected to the trans is typically on this angle as well), it splits teh angle of the driveline between the front and back u joint. when you angle the pinion so that it is on the same plane as the 2nd shaft in a 2 piece set up, you are in turn putting the entire bend angle in the firs u joint only and the second u joint (since it is following the same angle as the second shaft at ride) is taking up none of that angle.
    so lets say for the ease of math that the front u joint ( after the carrier bearing ) has an angle of 10 degrees on it and you set the pinion facing up the shaft. the u joint closest to the pinion now has an angle of 0 while the upper has the angle of 10. however, if you face the pinion at the same angle as the trans output shaft (like i did with my stock 2 piece shaft) the 10* angle that was in the upper is now a 5* angle at the upper and lower u joint splitting the angle between the 2 pivoting areas of the shaft.
    just what ive learned while dicking with my link on the back of my truck. maybe it doesnt work that way all the time but it worked for me and im leaving it be. hahaha
  10. Oct 26, 2011 at 10:16 AM
    TC yota
    Tyler
    Escondido
    Ha
    On a toyota 2 piece they don't use u-joints, its called a double cardan joint, the max operating angle on those is only like 25 degrees. Every driveshaft shop in the world will tell you to set it up with the dshaft in line with the joint, that is just how they work
    see the pics in the link
    http://www.4x4wire.com/toyota/tech/driveline/
  11. Oct 26, 2011 at 11:15 AM
    linked2002
    san diego
    oh no no i understand what your saying for sure. and the cardan joint is just 2 individual u joints pressed into a casting. although it has less deflection, it still seemed to work out rather well with my set up. but now you have me wondering. i will go home and adjust the pinion angle and see what i get and report back.
