upper ball joint Camburg LT kit
Discussion in 'Long Travel Suspension' started by 04LTtacoma, Jun 2, 2011.
  1. Jun 2, 2011 at 6:17 PM
    04LTtacoma
    04LTtacoma [OP] Well-Known Member
    Oregon
    I have an 04 toyota tacoma with the burg kit. I was wondering if the upper ball joint was pressed into the spindle or was not pressed into the spindle? I can't remember because it was so long ago when my buddy and I installed the kit.
    This weekend my friend and I are going to replace my spindles and I don't remember if the upper ball joint was suppose to be pressed in or not.
    I have a feeling that it wasn't pressed in, but I can't exactly remember.
  2. Jun 2, 2011 at 6:19 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    if its anything like my spindles and uca setup its not pressed, just uses a bolt and nut. you losen the nut and the bolt pops right out
  3. Jun 2, 2011 at 10:03 PM
    04LTtacoma
    Oregon
    Okay, that is what I thought... Thanks for the reply.
  4. Jun 2, 2011 at 10:34 PM
    04LTtacoma
    Oregon
    So I asked this same question on TTORA and two people replied that I am going to have to press the ball joint out. Anyone else have any thoughts on this question?
    Could I possibly use a ball joint press that I could pick up from napa or autozone?
  5. Jun 3, 2011 at 8:03 AM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    thats a uni ball
    not a ball joint
  6. Jun 3, 2011 at 1:33 PM
    04LTtacoma
    Oregon
    Okay Matt, thanks for the correction.:mad::mad::mad::mad: Grrrrrrr. lol JK
  7. Jun 3, 2011 at 6:06 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Lol well it makes a difference. Yes a ball joint needs pressed out. No you your uniballs do not need pressed out to come APART. But if you want that piece out of the spindle, that is the slug (is the lower misalignment spacer) that IS pressed into the spindle. So for replacing your spindle you will need to press out that slug and press it back into your new spindle.
  8. Jun 3, 2011 at 6:11 PM
    Cr250jumper
    The moon
    50 shades of tan©
    Its this piece here. It is pressed into the spindle and that is a snap ring on the top of the spindle in your picture holding the slug in place
  9. Jun 3, 2011 at 6:15 PM
    Cr250jumper
    The moon
    50 shades of tan©
