Fuel filler extending for glass
Discussion in 'Long Travel Suspension' started by jtlachac08, Feb 3, 2012.
  1. Feb 3, 2012 at 10:20 AM
    jtlachac08
    jtlachac08 [OP] Well-Known Member
    Jeremy
    Phoenix, Az
    As many know, on a 2nd Gen when putting glass bedsides on, the fuel filler neck isn't long enough to meet the pocket on the bedside.
    So, its recommended to purchase a 4runner fuel hose that goes from the filler neck to the tank. Part number 77213-35370.
    However, what have ppl done to extend the evap hoses that are also attached to the filler neck. One is 1/4" and the other 5/8"
    Are you just cutting the lines and adding a small peice of hose to aid in the extension? Pictures would be awsome. I've searched the hell out of this and really only came up with the 4runner part number, which really does no good unless the evap lines get extended as well. I tried last night. Just trying to get ahead of the game before the bedsides get mounted and painted.
    Thx
  2. Feb 3, 2012 at 2:47 PM
    jtlachac08
    Jeremy
    Phoenix, Az
    23 views with no opinions...... Someone out there's done this
  3. Feb 3, 2012 at 2:48 PM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    haven't looked at it are they hard lines or a rubber hose? any auto parts shop has stock 1/4" hose for cheap
  4. Feb 3, 2012 at 2:51 PM
    jtlachac08
    Jeremy
    Phoenix, Az
    There's one hard fixed line attached to the filler, and one hard line thats attached to the body that slips into a nipple on the filler.
    Trying to get the opinion of what others have done before I chop up my good filler neck.
  5. Feb 3, 2012 at 2:59 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    Just get some fuel line from napa and cut it. It's just evap crap, and as long as its airtight will pass emissions and won't throw codes. They get tested under pressure so use hose clamps.
  6. Feb 3, 2012 at 3:01 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Im not sure if your is the same but I just bought new vapor lines. One goes to the overflow and one to the evap thing (charcoal canister on top of tank?). I just bought enough to replace the entire line. Auto zone has the 1/4" and Napa has the 5/8"
  7. Feb 3, 2012 at 3:05 PM
    jtlachac08
    Jeremy
    Phoenix, Az
    Thats what I figured I needed to do. Just wanted to make sure before I hacked it up.
    Then get told "Dude why did you do that, when you should've just bought this xxxxxx"
    LOL
    Word! Truck with be finished next week. Going into paint tonight, picking up bedsides tomorrow and dropping them off, then picking up truck fitted and painted next week. Can't wait!
  8. Feb 3, 2012 at 3:06 PM
    Cr250jumper
    The moon
    50 shades of tan©
    Well there may be a "xxxx" part that will fit perfect. I am impatient though :cool:
  9. Feb 3, 2012 at 3:08 PM
    jtlachac08
    Jeremy
    Phoenix, Az
    Hahaha and I'm a perfectionist :D
  10. Feb 3, 2012 at 3:11 PM
    Cr250jumper
    The moon
    50 shades of tan©
    Nothing wrong with that. Well I shouldnt be too far behind, I just bought rear leafs, shocks, shock mounts, perches, TC bash plates, ubolts, brake lines, DOM, Hobart 190 welder and some other stuff I cant think of
  11. Feb 3, 2012 at 3:22 PM
    jtlachac08
    Jeremy
    Phoenix, Az
    Hot Damn!! What leafs and shocks did you get?
  12. Feb 3, 2012 at 3:24 PM
    Cr250jumper
    The moon
    50 shades of tan©
    F67's from a member here and then had to go with smoothies for now. Hopefully upgrade to some bypasses down the road but with 18" travel the rear might out perform the front even with smoothies
  13. Feb 29, 2012 at 8:44 PM
    Sky
    Sky Taco Member
    Brandon
    Redlands/Yucaipa
    05 V6 4x4 TRD Off-Road
    First of I painted my truck Satin flat black,.... well faded satin flat black lol, it has 5100s up front and J66's as well as billy 5150s in the rear, 285/ 75/16 Falcon wild peak A/T, Axis regulators painted satin black, with a tan rings! brush bar with 30 in led light bar , Custom rear Bumper, Straight Pipe. Led Hi/Low, and led fog lights, Flat Black Interior!
    Just a quick question how do you take the fuel door off?
  14. Mar 1, 2012 at 8:36 AM
    DTFtacoma
    DTFtacoma Dezert Toy Fabrication Vendor
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    Drill out the rivets
  15. Mar 1, 2012 at 11:00 AM
    Sky
    Sky Taco Member
    Brandon
    Redlands/Yucaipa
    That's what I figured.. now the filler neck I just need the 4 runner neck!
  16. Apr 25, 2012 at 11:52 AM
    lilgerber
    lilgerber Well-Known Member
    Aaron
    Fresno, CA
    06 4x4 off road Speedway blue
    Front: Total Chaos 3.5 4x4 LT kit, Engage off-road one piece hood, Caged front end, TC gussets. Rear: Fiberworks fenders, King 14" 3.0 triple bypasses, boxed/braced frame, extended brake lines, 63" chevy leaf springs, U bolt flip kit, TC lower shock mounts. Preformance: URD intake, Doug Thorley headers, Flowmaster 40, 2.5 tubing. Interior: Weather techs, LED's, Double DIn, kicker 10" subs, Kicker componet speakers, Exterior: Method wheels with OMF beadlocks, Custom made bumpers, Retro headlights.
    ^ i need to see one of these !
  17. Apr 25, 2012 at 12:12 PM
    87xjmike
    87xjmike Well-Known Member
    Folsom
    98 5lug 2rz
    downey mid travel 2wd set up
    my stock length tube goes through the wheel well.
  18. Apr 25, 2012 at 12:53 PM
    Cr250jumper
    The moon
    50 shades of tan©
    ^Your tank is on the passenger side? Mine just comes up through the bed too
  19. Apr 25, 2012 at 1:05 PM
    05TacoRunner
    05TacoRunner You say tomato.......... I say fuck you!
    Jason
    Peoria, Az
    Aftermarket nuts and bolts
    The older Toyota trucks have it on the pass side. Same as my 89 Toyota pickup
  20. Apr 25, 2012 at 1:09 PM
    tostidos
    Apple Valley, CA
    07 LT 6spd
    I wonder if you hack it off and just extend it radiator hose with clamps. As long as you have a good seal that might work well.
