Some Questions
Discussion in 'Long Travel Suspension' started by jets, Mar 31, 2012.
  1. Mar 31, 2012 at 7:36 PM
    jets
    jets [OP] Active Member
    John
    805, CA
    2018 TRD OR DCSB
    So I'm slowly getting parts around to start a build on my taco and I just scored a set of SAW coilovers brand new for 500 bucks but they do not have springs. What are you guys running spring rate wise for your tacos with 4x4 with an extended cab? I assume 600# but I just want to make sure before I place an order. Next my question is about the axles themselves. I'm not sure what kit I'm leaning towards still(TC or Camburg) but I prefer TC just on principle. I read somewhere that the tundra axles will work, but what is involved? Would it be better to just fork up the money and get the axles made by TC or Camburg and if I do could I use the TC axles with a camburg kit and vice versa..? (because I still am not sure on the kit)
    Yes I searched and couldn't find the answers to my questions, sorry for the lengthy post just want to do it right the first time around.
  2. Mar 31, 2012 at 10:38 PM
    noSKills858
    noSKills858 battlescars
    Alex
    Poway, CA
    2003 5-lug Prerunner
    Couple shocks, some old tires, and a bad paint job
    What length/size C/O did you get?
    Tundra axles will work fine.
  3. Apr 1, 2012 at 9:11 AM
    jets
    John
    805, CA
    2018 TRD OR DCSB
    They are 2.5 8" so If I get a set of tundra axles they will bolt right in?
  4. Apr 1, 2012 at 12:12 PM
    noSKills858
    Alex
    Poway, CA
    An 18" 600 spring should be good for you; order name: 300.18.600
    Yes the axles will bolt in for the TC kit, I am not sure about Camburg but I don't see why it would change between the two kits. Only thing different would be their custom upgraded CV's.
    As far as the coil overs go they should be fine but I'm not 100% sure on the clearances for the axles seeing how some companies run a longer shock rod end.
  5. Apr 2, 2012 at 10:49 AM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Not sure on TC's exact sizing but a standard 2.5x8 shock will not work on 1st gen Camburg LT kit. You need an 8" shock that collapses to 14 3/8" for Camburg or you will lose uptravel. Chaos may be your only option if your not willing to trade coilovers
  6. Apr 2, 2012 at 11:53 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    listen. trust me
  7. Apr 2, 2012 at 3:40 PM
    jberry813
    Jason
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    What everyone said is true.
    Also for 4x4, you want the cone shaped lower spring seat, not the flat one.
    Like this:
  8. Apr 2, 2012 at 5:40 PM
    jets
    John
    805, CA
    2018 TRD OR DCSB
    Well even better the coilovers I bought were for a camburg kit so the length and everything is set up for the kit and have the cone lowers. When I had my tundra I remember I had 16" coils up front and an 18" wouldn't necessarily fit without having a flat spring seat. I'm still kind of confused about the axles and what has to be done for them to work. I've searched everywhere to no avail. Do they need modifying because the tacoma has that weird tripod inner and the tundra doesn't:confused: jberry what spring length are you running?
  9. Apr 2, 2012 at 7:58 PM
    jberry813
    Jason
    Lake Tahoe
    2012 DCSB Sport
    Oops I misread. You're results may vary, but IIRC my king's are a 16" coil with the cone seat.
    As for the axles, it's a walk in the park. You don't have to swap tripods or anything. Just buy 1st gen Tundra cv axles from the dealer or any auto parts store or even from TC. The 1st gen tundra and tacoma have the same spline count. No special tricks really needed. Remove tacoma CV axles, insert tundra cv axles.
    However, I'd highly suggest you do the porche 930 inner cv boot mod. Use the bates style cv boots.
  10. Apr 2, 2012 at 9:23 PM
    jets
    John
    805, CA
    2018 TRD OR DCSB
    Awesome thanks for the information and heads up, thats what I'll do! Now I just have to debate on which kit I want. I had a TC kit on my tundra and the only complaint I had was it never aligned properly (could have been a bent coilbucket from barging with midtravel) and with the bushing lower it squeeked like no other haha. Definitely going to gusset everything I can before I take the truck out, learned the hard way! I'll have more questions coming I'm sure:)
  11. Apr 3, 2012 at 8:29 AM
    jberry813
    Jason
    Lake Tahoe
    2012 DCSB Sport
    Mine aligned perfect when I first installed it. I have coil gussets and shock hoops, but I've since done a few too many hard hits and I'm sitting slightly negative camber now. Only real way to prevent it is a simple engine cage. If I could do it all over again, I would have bought the heim upper kit and ran at least a single tube between the bypass hoops. Its still in the plan, but later down the road at this point.
    As for the bushings...dry lube. I bathed mine in dry lube before I installed and have never had a single squeek.
  12. Apr 3, 2012 at 8:35 AM
    Cr250jumper
    The moon
    50 shades of tan©
    Im confused :confused:
  13. Apr 4, 2012 at 9:49 AM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    i recognize your screen name from DR... you had the green tundra huh?
    i'm in ojai. you planning to go to the VC off road expo?
  14. Apr 4, 2012 at 4:43 PM
    jets
    John
    805, CA
    2018 TRD OR DCSB
    Yes I did! I'm slowly getting everything around for the build, my dream truck was a built taco 4x4 manual and I am finally in the process!! When is the off road expo going on?
  15. Apr 4, 2012 at 4:52 PM
    nelson18matt
    Goodyear, Arizona
    *SOLD*
  16. Apr 7, 2012 at 7:54 PM
    DIRT YOTA
    DIRT YOTA Aka EL ROJO
    Cory
    Camarillo, CA
    03' dbl cab with some stuff
    Nice build that shit yo!
