Drive shaft issue after rear lt done..
Discussion in 'Long Travel Suspension' started by BMiller421, Jan 6, 2013.
  1. Jan 6, 2013 at 4:18 PM
    BMiller421
    BMiller421 [OP] FMLYHM
    Brandon
    Bakersfield, CA
    05 Pre-runner
    LT, Kings, Fabricated Trucks Worldwide For The Win, K&N and Doug Thorley LT Headers
    So i finished my rear lt..took it down the street and hear a horrible grinding noise..
    This is what i found..
    Carrier bearing grinding on shaft ring..
    Pretty sure that should be within the carrier housing..
    Pretty sure this is ok..
    Any experts please chime in..
    Thanks in advance..
  2. Jan 6, 2013 at 4:25 PM
    dirtymike
    dirtymike Well-Known Member
    mike
    orlando fl
    2nd gen
    Fiberglass,spindles, coils, 4"leafs, gears&locker, no skids :-/
    That's not good
  3. Jan 6, 2013 at 4:28 PM
    bmpskir
    bmpskir Well-Known Member
    Dover, NH
    2010 TRD sport DCLB 4.0 auto
    I am new to the tacoma world but what that looks like to me is the slip yoke slid out of the TC when the rear was hanging and didn't slide back in when you dropped it... gotta get that to slide back in...
  4. Jan 6, 2013 at 4:30 PM
    Oowen
    Oowen Goes through trucks faster then underwear
    Owen
    Elko, NV
    15 DCSB
    Garage Queen
    Thank you captain obvious!
    Op it may be too short. Could have been pulled apart if you drooped the suspension.
  5. Jan 6, 2013 at 4:30 PM
    Hiatt1991
    Hiatt1991 Well-Known Member
    Hiatt
    Ventura, CA
    2022 Toyota Tacoma SR5 DCSB 4x4
    4" Bodylift 20" Offroad shock spacers Turbo Encabulator
    That is absolutely NOT ok. You need to add a slipyoke to your driveshaft. If you drive it like that you will destroy your carrier bearing and your driveshaft will pop out.
  6. Jan 6, 2013 at 4:31 PM
    52motorhead
    52motorhead Well-Known Member
    Your steady bearing is shot, will need to replace that.
  7. Jan 6, 2013 at 4:32 PM
    dirtymike
    mike
    orlando fl
    2nd gen
    You're welcome. Seeing that in his post he said he thinks it's ok. I was informing him it wasnt good.
  8. Jan 6, 2013 at 4:34 PM
    Oowen
    Owen
    Elko, NV
    15 DCSB
    Garage Queen
    I cant read..
  9. Jan 6, 2013 at 7:09 PM
    AmeriMotor
    AmeriMotor Well-Known Member
    American Motorsports
    Vista
    Offroad Fabrication
    Here's your problem and this is just looking at your pictures. Picture #2 (im assuming this is when the truck is sitting on its wheels at ride hiegth after you installed your Lt kit.) Your measurements are off and your axle is to far away from the transmission and you've extended your wheel base unintentionally. Meaning when you installed you Lt kit you pushed the rear axle backwards, probably caused by your spring hanger location, most likely the front but it can be the rear. Also the distance between the 2 spring hangers is so critical and it has to be perfect. A slip yoke wont fix this problem. Now if picture 2 is at full drop then yes a slip yoke will fix this, but a temporary fix is limit your drop off with your limit straps to prevent your axle from dropping to far. Check your wheelbase and check your distance from spring mount to spring mount before you start cutting or moving things around. PM if you need more help. American Motorsports
  10. Jan 6, 2013 at 7:13 PM
    jandrews
    '09 FourDubDee TRD OR
    Longer driveshaft needed immediately.
    Carrier bearing will need to be replaced.
    You plainly have more suspension travel than the driveshaft can handle.
  11. Jan 7, 2013 at 8:33 AM
    05TacoRunner
    05TacoRunner You say tomato.......... I say fuck you!
    Jason
    Peoria, Az
    Aftermarket nuts and bolts
    The axle is going to swing forward upon droop and back at bump. Right now his axle is pulling the drive shaft back. If he installs a slip yoke into the rear drive shaft section it will take the pressure off the front drive shaft allowing it to slide back into the trans and and stop the rubbing. The slip yoke will also allow the axle to swing back at full bump and allow the drive shaft to grow.
  12. Jan 7, 2013 at 9:09 AM
    AmeriMotor
    Vista
    Offroad Fabrication
    I understand the concept of a slip yoke and suspension travel. But when you install a rear Lt leaf pack this shouldnt happen. When its at ride hit the drive shaft should be in its normal position, when you are full bump you should hit in the same bump stop location as your stock leafs did, hence no change in driveshaft needed. You only need a slip yoke for full drop out. So there is a problem with his axle location.
  13. Jan 7, 2013 at 11:13 AM
    05TacoRunner
    Jason
    Peoria, Az
    I agree this problem shouldnt happen, But a slip yoke will still allow him to take the tension off the front shaft an fix this issue. What he needs to do is cut off the hanger remeasure and re install in the proper location.
  14. Jan 7, 2013 at 12:16 PM
    Defined
    Defined Well-Known Member
    mike
    southern california
    looks like you pulled the bearing out of the carrier housing. that would usually be caused by over extension of the shaft at full bump. the 2wd driveshafts arent ideal for running a longtravel kit. my kit puts it at the limits. but all the 62" packs have too much forward - aft movement of the axle to use the stock shaft , no matter where full bump is set at.
    you want to upgrade to a slipjoint in the rear section of the driveshaft ,not only to stop what happened above . but so the carrier bearing stays in one place while the suspension cycles and to keep the maximum spline engagement at the transmission.
  15. Jan 8, 2013 at 9:18 PM
    BMiller421
    Brandon
    Bakersfield, CA
    05 Pre-runner
    Took the drive shaft off..adding a slip yolk by the weekend..
    And a new carrier bearing and greasable u-joints..
  16. Jan 9, 2013 at 8:29 AM
    Hiatt1991
    Hiatt
    Ventura, CA
    I would just upgrade the bearing while you are at it. The stock one sucks ass.
  17. Jan 9, 2013 at 1:16 PM
    BMiller421
    Brandon
    Bakersfield, CA
    05 Pre-runner
    I'll see what my drive line buddy recommends..but I will eventually get this..
  18. Jan 9, 2013 at 1:21 PM
    noSKills858
    noSKills858 battlescars
    Alex
    Poway, CA
    2003 5-lug Prerunner
    Couple shocks, some old tires, and a bad paint job
    Looks like you put your front hangers too far back to begin with too. Did you buy it as a kit or just put it together in pieces?
  19. Jan 9, 2013 at 2:37 PM
    BMiller421
    Brandon
    Bakersfield, CA
    05 Pre-runner
    I fabbed it myself..(hangers..shackles..)
    So..in theory..if I cut off the front hangers and move them forward..everything should go back to normal?
  20. Jan 9, 2013 at 5:29 PM
    05TacoRunner
    Jason
    Peoria, Az
    you will need to move both front and rear to keep the 52.5 mounting distance. You will still need a slip yoke for the added travel
