Go Back   Tacoma World Forums > Vendors > Marion Bumper2Bumper
2nd Gen Tacoma electrical system upgrade is now available!!
Old 03-18-2014, 08:11 PM   #62
bunk is on a distinguished road
bunk's Tacoma Gallery
It looks like 3 or 4 connections, what gauge are they?
Old 03-18-2014, 10:28 PM   #63
qnyla is one of the sharper tools in the shedqnyla is one of the sharper tools in the shedqnyla is one of the sharper tools in the shedqnyla is one of the sharper tools in the shedqnyla is one of the sharper tools in the shedqnyla is one of the sharper tools in the shedqnyla is one of the sharper tools in the shedqnyla is one of the sharper tools in the shedqnyla is one of the sharper tools in the shedqnyla is one of the sharper tools in the shedqnyla is one of the sharper tools in the shed
qnyla's Avatar
qnyla's Tacoma Gallery
Originally Posted by BamaToy1997 View Post
So here is what the Stage 1 Kit comes with:
  • High quality battery terminals with built-in voltage gauge for "at-a-glance" reading of your battery status.
  • Heavy-duty 2 gauge primary cables for starter and vehicle grounds using welding cable with over 2000 strands of copper.
  • Heavy-duty 4 gauge alternator cable, and vehicle power cable made of the same welding cable style, with over 1000 strands of copper.
  • Heavy-duty 4 gauge power point draw with 130A fuse
  • Performance Stereo 8 gauge wire for body ground
  • Instructions on installation
I have a couple of questions:
  1. The 4 AWG power point draw with 130A fuse. This is what a aux fuse block, such as my Blue Sea aux fuse block, would be connected to, correct? Is the cable length fixed, or can the length be customized to accommodate the specific location of the aux fuse block?
  2. Are the starter, vehicle ground and alternator cables long enough to reach the main posts on a Die Hard Platinum Group 31M battery as shown in this photo? (not my photo or truck, I just grabbed it from another thread for illustration).
  3. Are the 200A and 250A alternators Toyota OEM Denso units that have been upgraded to 200A or 250A? Looking for the same quality as the Denso OEM alternator, and wondering about these. Photo?
  4. Can you provide a photo of the finished Stage 1 assembly sitting on a table so we can visualize the various cables?
Thanks for offering this package!
2nd Gen Tacoma electrical system upgrade is now available!!-img_4375-copyweb.jpg
Old 03-19-2014, 05:27 AM   #64
ASE Master Tech
BamaToy1997's Avatar
BamaToy1997's Tacoma Gallery
The largest connection can fit 2 or 0 gauge cables. It might be able to fit larger, but I have not built one with anything bigger than 2 gauge. Then there is a 4 gauge connection, and two 6-8 gauge connections. There are adapters available if there are more connections needed. The price to be adjusted accordingly. I can build just about any power draw system.
Thanks for your interest.
1. The 150A power point can be built to any length. It is used for powering things such as a Blue Sea or similar fuse block, as well as a power point for car stereo applications that require a large fuse.
2. Since these are custom built to order, the cable lengths can be adjusted accordingly to fit any post location.
3. Yes, the alternators are Nippindenso alternators that have been completely rebuilt, and the core parts upgraded. Many high output alternators only replace the stator for the higher output. These replace the stator AND the field coil as well. If you check my 1st gen kits there are photos similar to what they look like. I do not have a 2nd gen alternator at the shop to give you an exact picture of one of them since these kits are made-to-order. When I get my next kit built for the 2nd gen I will post photos of that kit. In general everything is identical to the ones I build for the 1st gen.
If anyone has any other questions feel free to post them up. I will be happy to answer them.
Old 03-30-2014, 11:43 PM   #67
FMF FMF is online now
FMF is one of the sharper tools in the shedFMF is one of the sharper tools in the shedFMF is one of the sharper tools in the shedFMF is one of the sharper tools in the shedFMF is one of the sharper tools in the shedFMF is one of the sharper tools in the shedFMF is one of the sharper tools in the shedFMF is one of the sharper tools in the shedFMF is one of the sharper tools in the shedFMF is one of the sharper tools in the shedFMF is one of the sharper tools in the shed
FMF's Avatar
Navy: FMF Hospital Corpsman
FMF's Tacoma Gallery
I would like to order the base kit for a 2013 Tacoma.
Old 04-09-2014, 10:05 AM   #68
HARD CAAAAAAARRRRRRRL
Papa Taco is one of the sharper tools in the shedPapa Taco is one of the sharper tools in the shedPapa Taco is one of the sharper tools in the shedPapa Taco is one of the sharper tools in the shedPapa Taco is one of the sharper tools in the shedPapa Taco is one of the sharper tools in the shedPapa Taco is one of the sharper tools in the shedPapa Taco is one of the sharper tools in the shedPapa Taco is one of the sharper tools in the shedPapa Taco is one of the sharper tools in the shedPapa Taco is one of the sharper tools in the shed
Papa Taco's Avatar
Papa Taco's Tacoma Gallery
sub'd..... for future monies
Old 04-11-2014, 01:54 PM   #69
dirty Nissan driver
gravedgr is one of the sharper tools in the shedgravedgr is one of the sharper tools in the shedgravedgr is one of the sharper tools in the shedgravedgr is one of the sharper tools in the shedgravedgr is one of the sharper tools in the shedgravedgr is one of the sharper tools in the shedgravedgr is one of the sharper tools in the shedgravedgr is one of the sharper tools in the shedgravedgr is one of the sharper tools in the shedgravedgr is one of the sharper tools in the shedgravedgr is one of the sharper tools in the shed
gravedgr's Avatar
gravedgr's Tacoma Gallery
I'm pretty sure I want to get one of these in the future, but I'm not exactly sure what for. We'll be adding some front (driving) and side/rear (camping, packing/unpacking) LEDs at some point, but I'm mostly putting it all off because I know nothing about electrical and it all makes me nervous.
Its much harder to screw up something that only involves a wrench, hammer, pliers or socket.
Old 04-11-2014, 01:58 PM   #70
ASE Master Tech
You can install this kit with a wrench, pliers, sockets, and a hammer.
Hmmmm. I may offer you a killer deal on the kit and install if you bring my RTT to me when they arrive....
Old 04-11-2014, 02:28 PM   #71
dirty Nissan driver
gravedgr's Avatar
Its not the kit I'm worried about installing, its all the stuff that would require having it in the first place.
Old 04-11-2014, 03:10 PM   #73
wuzzy121 is one of the sharper tools in the shedwuzzy121 is one of the sharper tools in the shedwuzzy121 is one of the sharper tools in the shedwuzzy121 is one of the sharper tools in the shedwuzzy121 is one of the sharper tools in the shedwuzzy121 is one of the sharper tools in the shedwuzzy121 is one of the sharper tools in the shedwuzzy121 is one of the sharper tools in the shedwuzzy121 is one of the sharper tools in the shedwuzzy121 is one of the sharper tools in the shedwuzzy121 is one of the sharper tools in the shed
wuzzy121's Avatar
wuzzy121's Tacoma Gallery
So is my math right with shipping and handling for a 2nd stage 200 amp kit it's $400?
Old 04-11-2014, 03:11 PM   #74
wuzzy121's Avatar
I have noticed when winching from idle everything bogs down and I have the off road package.
Old 04-11-2014, 03:20 PM   #75
ASE Master Tech
That is correct! I will tell you that you still will have some engine bogging with the 200A alternator. The average winch draws upwards of 400 amps under load. The difference will be that more of the power draw with the winch will come from the alternator, and less from the battery. At 400 amps you are drawing (at idle) 70 amps from the alternator and 330 from the battery. With this kit you would be drawing about 120 amps from the alternator, and 280 amps from the battery.
Old 04-11-2014, 04:41 PM   #76
tacoma16 is one of the sharper tools in the shedtacoma16 is one of the sharper tools in the shedtacoma16 is one of the sharper tools in the shedtacoma16 is one of the sharper tools in the shedtacoma16 is one of the sharper tools in the shedtacoma16 is one of the sharper tools in the shedtacoma16 is one of the sharper tools in the shedtacoma16 is one of the sharper tools in the shedtacoma16 is one of the sharper tools in the shedtacoma16 is one of the sharper tools in the shedtacoma16 is one of the sharper tools in the shed
tacoma16's Avatar
tacoma16's Tacoma Gallery
Thanks for putting this together. Subd for future project and write up
Old 04-12-2014, 09:13 AM   #77
NegativeCambre is on a distinguished road
NegativeCambre's Tacoma Gallery
Do you offer a 2nd gen, 4 cylinder kit? I'm very interested if so--thanks.
Steve
Old 04-12-2014, 09:27 AM   #78
ASE Master Tech
Yes we do offer a 4 Cyl kit. Same price as the V6 because the starters are in the same location.
Old 04-12-2014, 10:39 AM   #79
wuzzy121's Avatar
I can't wait to get the money for this, cause once I do we have some things to talk about with this kit.
1st Gen (and upcoming 2nd Gen) electrical system upgrade! BamaToy1997 Marion Bumper2Bumper 191 02-28-2015 11:39 PM
1st Gen Electrical system power upgrade BamaToy1997 1st Gen Tacoma Marketplace 20 01-29-2014 02:13 PM
WTB Tacoma 2nd Gen Bed Rail System Railin 2nd Gen Tacoma Marketplace 1 01-22-2013 09:25 AM
WTB OEM touchscreen radio/gps system for 2nd gen tacoma firefighteru7 2nd Gen Tacoma Marketplace 4 03-05-2012 05:32 PM
Newbie with gen 1 tacoma wanting to upgrade to 2nd Tdubliture 2nd Gen. Tacomas 9 03-26-2011 09:21 PM
