Cr125 2 stroke help !!!!
Discussion in 'Motorcycles' started by Unknown, Nov 25, 2010.
  1. Nov 25, 2010 at 9:34 PM
    #21
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Power wise, almost. But its way easier to be fast on a 250f.
  2. Nov 26, 2010 at 5:53 AM
    #22
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    i have a 93 kx250 worked to the balls....
    i have rebuilt the top end 4 times takes me like 1 hour no joke......
    this bike has been under water numerous times...and i mean like under under...
    and this bitch is redlined balls to the b=wall when i do ride it.....
    lovin pwer band you better hold the fuck on......
    if you had to work on a 4 stroke better break out the wallett
    granted my bike is better started with a squirt of starting fluid untill she warms up but then
    she start all day long
  3. Nov 26, 2010 at 7:14 AM
    #23
    Mod
    Mod Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    Cr125's are a whipcrack, hang onto that beyatch!!. lightswitch powerband,,you'll have nothing down low,,then KABOOM!!,,your doing the superman imitation trying to hold on.
    I had a YZ-250 that was set up for desert riding, Steahly flywheel weight, 5.5 gal tank, Moose seat, reworked forks, Trailtech digital gauge for speed, distance, and ride time ,ect,ect,ect.
    Jump/google online with your kickstarter question, your answer is out there easily. might be a simple,fix,,might not.
  4. Nov 26, 2010 at 3:42 PM
    #24
    Unknown
    Unknown [OP] He who angers you conquers you
    Brian
    Los Angeles
    Unknown
    Unknown
    lol im going to use this as a quote in my sig mmk
  5. Nov 26, 2010 at 7:21 PM
    #25
    Unknown
    Brian
    Los Angeles
    Unknown
    Unknown
    do you guys think it could be the spark plug?
  6. Nov 26, 2010 at 7:24 PM
    #26
    brutalguyracing
    F.U> GUYZ
    broken mods
    what as in the reason it wont start???
    have u taken it out???
    have u used starting fluid???
  7. Nov 26, 2010 at 7:27 PM
    #27
    Unknown
    Brian
    Los Angeles
    Unknown
    Unknown
    i dont know the reason, no & no :eek:.
  8. Nov 26, 2010 at 10:10 PM
    #28
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    I would try bump starting it first, if it wont then pull the plug and see if its wet. If it is try a new plug. If it still doesn't start it could be compression or the jets could be pluged with varnished gas.
  9. Nov 26, 2010 at 10:15 PM
    #29
    Unknown
    Brian
    Los Angeles
    Unknown
    Unknown
    i'll try that tomorrow, heres a pic of it
  10. Nov 27, 2010 at 4:09 AM
    #30
    brutalguyracing
    F.U> GUYZ
    broken mods
    go back to basics make sure it has spark and gas......
    there is not too much to go wrong with a 2 stroke
  11. Nov 27, 2010 at 4:28 AM
    #31
    Toyo_Jet
    Toyo_Jet Well-Known Member
    Shane
    Flatlands of Indiana
    10 4X4 V6 SR5 access Cab
    As some of the guys have stated, it could be a number of things.
    worn rings
    broken or stuck rings
    hole in piston from leaning out
    blown head gasket
    broken rod (not likely, and you would hear it clanking or it would jam up)
    I'd probably be most concerned about broken rings because that can score the bore and a holed piston because that splatters molten aluminum into the bottom end and should be cleaned out. If it is a holed piston you need to find the cause (dirty carb or intake leak) since it could do it with your new piston.
    Did you get the service / owners manual. It will tell you how to do the top end and all of your spec's including torque.
    BTW, whatever is wrong with it, it will be cheaper than the same problem with a 4-stroke.
    Tear the top end offa that sucker and let us know what it looks like.
  12. Nov 27, 2010 at 4:49 AM
    #32
    Mod
    CR, WA
    stock
    I wouldn't hand your cousin a dime, until you figure out what is wrong and the cost to fix. it might be a mailbox holder.
  13. Nov 27, 2010 at 5:08 AM
    #33
    Toyo_Jet
    Shane
    Thats a good strategy, if it turns out bad, he benefits by knowing exactly whats wrong with it for free.
  14. Nov 27, 2010 at 9:16 AM
    #34
    Airun
    Airun Well-Known Member
    Aaron
    Show Me State
    TRD sport, DCLB, 4wd
    Debadged, custom emblem, Husky liners, custom bedrail Yak Trak setup with load bars, , BakFlip Fibermax, OME 3" lift with LightRacing UCAs
    2 strokes are awesome and simple to work on. Top end rebuilds are a breeze, no valves, cam, cam chains etc. Just pull the jug and take a look.
  15. Dec 1, 2010 at 2:49 AM
    #35
    Unknown
    Brian
    Los Angeles
    Unknown
    Unknown
    ok so heres the plug, what you guys think? it was running rich?
  16. Dec 1, 2010 at 8:22 AM
    #36
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    looks like it was running pretty good actually. Did it start?
  17. Dec 1, 2010 at 2:20 PM
    #37
    Unknown
    Brian
    Los Angeles
    Unknown
    Unknown
    Nope :(, Going to buy another plug just to test that one out.
  18. Dec 1, 2010 at 2:28 PM
    #38
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    So did you check for compression? this is what you do if you havent, remove the plug and place your hand/ thumb over the hole, if you can have somebody kick it and you hand does not come off the compression is too low.
    Also if your compression is low you wont be able to kick it but you might be able to still bumpstart it if it isnt too low.
    Check the basics first, you need air fuel spark and compression, then get fancy. Post up what you do and I can help you from there.
    before you do anything get a can of ether, spray it into the airfilter and then try kicking it, if it doesnt start like that, move on to bump start.
    If that doesnt work check to make sure you are getting a spark.
    If you are then its compression if you arent its an electical problem.
  19. Dec 1, 2010 at 2:29 PM
    #39
    ktmrider
    Junk
    Oh and it wouldnt be a bad idea to replace that plug, but check for a spark first just to rule it out.
  20. Dec 1, 2010 at 3:03 PM
    #40
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    yeah, and just FYI, the easiest way to do this is to have the plug out, but pluged into the plug wire. Then hold the electrode against the cylinder of the engine and have someone kick the engine over. You should see a small spark.
