Go Back   Tacoma World Forums > Off-Topic > Motorcycles
2009 Yamaha R1 (with 2013 R1 Factory Traction Control) and More...
Old 04-02-2013, 11:11 AM   #1
OmegaQuest [OP] OmegaQuest is offline
OmegaQuest is on a distinguished road
OmegaQuest's Avatar
Army: 1st Battalion 3rd US Infantry (TOG)
OmegaQuest's Tacoma Gallery
Here are some photos of my 2009 Yamaha R1 Track/street bike with 2013 electronics (Factory Traction Control) and a ton of other modifications I have done.
------ 2013 R1 OEM Traction Control Conversion ------
2013 R1 Complete Engine Wire Harness (OEM)
2013 R1 Left Handle Bar Switch with Traction Control Switch (OEM)
2013 R1 Front Wheel Speed Sensor Ė Traction Control (OEM)
2013 R1 Front Rotor Sensor Ė Traction Control (OEM)
2013 R1 Speedometer / Cluster (MPH) (OEM)
2013 R1 ECU (OEM)
2013 R1 Starter Relay
White Headlight Assembly Mod
All Balls Tapered Steering Stem Bearings
Annitori Racing Quickshifter
Antigravity Li-Ion Battery
Ariete 90 degree valve stems (Gold)
Brembo RCS 19 Master Cylinder
Brembo RCS Foldable Brake Lever
Brembo RCS Foldable Clutch Lever
Brembo RCS Reservoir Kit
Bridgestone Battlax BT003 Tires
CNC Front Fork Sliders (Red)
CNC Rear Axle Sliders (Red)
Custom Race Number Plates
Driven D-Axis Fuel Base
Driven D-Axis Fuel Cap (Red)
Ek ZZZ 520 Chain (Gold)
Euro Airbox Mod
Flash-Tune Interface (2012 Version)
Galfer Stainless Steel Front Brake Lines
GB Racing Clutch Cover
GB Racing Engine Cover
GB Racing Pulse Cover
GP Shift Modification
GPR V4 Steering Stabilizer
Graves Billet Aluminum Bar Ends
Graves Carbon Fiber Slip-ons
Graves Carbon Heat Shield
Graves Cat-Eliminator Y-Pipe
Grave Frame Sliders
Graves Smog Block-off Plates
Graves Swingarm Spools
Graves Rear Brake Return Spring
Hotbodies Racing Smoked Headlight Covers
Integrated Sequential LED Tail Lights (Clear)
K&N Air Filter
K&N Oil Filter
MotoDynamicís Flush mount LED Turn Signals
Motul 300V Motor Oil
Motul RBF 600 Brake Fluid
Ohlinís FGRT 206 Front Forks (2013 Version with Wheel Speed Sensor Hole)
Ohlinís YA-931 Rear Shock
Power Commander AutoTune
Power Commander V
Zero Gravity Double Bubble Racing Windscreen (Red)
Rear Brake Reservoir Bracket
Rear Seat Cowl (White)
Renthalís 50mm Clip-ons
Rizoma Oil Cap (Red)
Speed Bleeders
Supersprox Stealth 520 Rear Sprocket Ė 47 Teeth (Gold)
Supersprox 520 Front Sprocket - 17 Teeth
T-Rex Motorcycle Stands (Red)
Vesrah RJL Brake Pads
Vortex Mirror Block-Off Plates
Vortex V2 Adjustable Rearset
Yoshimura - Axle Adjuster Blocks
Yoshimura - Steering Stem Nut
2009 Yamaha R1 (with 2013 R1 Factory Traction Control) and More...-150493_10200967216922210_1518106235_n.jpg   2009 Yamaha R1 (with 2013 R1 Factory Traction Control) and More...-dsc_6188.jpg   2009 Yamaha R1 (with 2013 R1 Factory Traction Control) and More...-dsc_6186.jpg   2009 Yamaha R1 (with 2013 R1 Factory Traction Control) and More...-dsc_6187.jpg   2009 Yamaha R1 (with 2013 R1 Factory Traction Control) and More...-dsc_6938.jpg
2009 Yamaha R1 (with 2013 R1 Factory Traction Control) and More...-dsc_6872.jpg   2009 Yamaha R1 (with 2013 R1 Factory Traction Control) and More...-dsc_6904.jpg   2009 Yamaha R1 (with 2013 R1 Factory Traction Control) and More...-977749_10200280221387347_1119849421_o.jpg
Old 04-02-2013, 11:19 AM   #2
Low and slow
dually is one of the sharper tools in the sheddually is one of the sharper tools in the sheddually is one of the sharper tools in the sheddually is one of the sharper tools in the sheddually is one of the sharper tools in the sheddually is one of the sharper tools in the sheddually is one of the sharper tools in the sheddually is one of the sharper tools in the sheddually is one of the sharper tools in the sheddually is one of the sharper tools in the sheddually is one of the sharper tools in the shed
dually's Avatar
Army: 14S
dually's Tacoma Gallery
Price?
Old 04-02-2013, 11:20 AM   #3
Superior Member
707tothe907 is one of the sharper tools in the shed707tothe907 is one of the sharper tools in the shed707tothe907 is one of the sharper tools in the shed707tothe907 is one of the sharper tools in the shed707tothe907 is one of the sharper tools in the shed707tothe907 is one of the sharper tools in the shed707tothe907 is one of the sharper tools in the shed707tothe907 is one of the sharper tools in the shed707tothe907 is one of the sharper tools in the shed707tothe907 is one of the sharper tools in the shed707tothe907 is one of the sharper tools in the shed
707tothe907's Avatar
707tothe907's Tacoma Gallery
Originally Posted by dually View Post
Price?
It's not a for sale thread.
Old 04-02-2013, 12:27 PM   #5
Red
Large's Tacoma Gallery
Damn nice bike..
Old 04-02-2013, 06:05 PM   #6
Low and slow
dually's Avatar
Army: 14S
Thats what I get for browsing on my phone, whoooooops!
Old 04-02-2013, 06:08 PM   #7
MightyMouse-SCT is one of the sharper tools in the shedMightyMouse-SCT is one of the sharper tools in the shedMightyMouse-SCT is one of the sharper tools in the shedMightyMouse-SCT is one of the sharper tools in the shedMightyMouse-SCT is one of the sharper tools in the shedMightyMouse-SCT is one of the sharper tools in the shedMightyMouse-SCT is one of the sharper tools in the shedMightyMouse-SCT is one of the sharper tools in the shedMightyMouse-SCT is one of the sharper tools in the shedMightyMouse-SCT is one of the sharper tools in the shedMightyMouse-SCT is one of the sharper tools in the shed
MightyMouse-SCT's Tacoma Gallery
Never knew you could do so many mods to a street bike .
Old 04-02-2013, 06:11 PM   #8
CDSurfPhotography is one of the sharper tools in the shedCDSurfPhotography is one of the sharper tools in the shedCDSurfPhotography is one of the sharper tools in the shedCDSurfPhotography is one of the sharper tools in the shedCDSurfPhotography is one of the sharper tools in the shedCDSurfPhotography is one of the sharper tools in the shedCDSurfPhotography is one of the sharper tools in the shedCDSurfPhotography is one of the sharper tools in the shedCDSurfPhotography is one of the sharper tools in the shedCDSurfPhotography is one of the sharper tools in the shedCDSurfPhotography is one of the sharper tools in the shed
CDSurfPhotography's Avatar
CDSurfPhotography's Tacoma Gallery
Anymore pics of the bike, it looks super clean
Old 07-01-2013, 09:38 PM   #11
He bowls overhand
fastguy95 is on a distinguished road
fastguy95's Tacoma Gallery
Send a message via Yahoo to fastguy95
I love the white/red color schemes for the R1's/R6's! Great looking bike man.
And, I absolutely love the fact that you list all your mods in alphabetical order! Reading that in order made my ocd skip a beat.
Any moar pics?
Old 07-02-2013, 03:03 AM   #12
OmegaQuest's Avatar
Any moar pics?
I just posted some more pics on the first post above.
2007 Yamaha R1 2wheelnut Buy / Sell / Trade - Other 1 11-05-2012 12:48 AM
2004 Yamaha R1 dragon129 Buy / Sell / Trade - Other 3 10-21-2011 01:41 PM
Looking for a first bike, Suzuki SV650S vs Yamaha R1 1000 StaticFilter Motorcycles 64 02-20-2011 12:04 PM
Special Edition Yamaha R1 kcrob1 Buy / Sell / Trade - Other 4 01-27-2011 08:59 PM
yamaha r1 offroad paintdiddy Sports, Hobbies & Interests 18 01-29-2010 03:28 AM
