SecretSquirrel's 2005 Tacoma w/ All-Pro Bumper, Satoshi Grille, Cooper 305 STTs & more...
Go Back   Tacoma World Forums > Tacoma Discussion > Off-Roading & Trails
SCUBA MOD - Relocating Front & Rear Diff, Tranny, Transfer Case and E-Locker Breather
Products Referenced Thread Tools Search this Thread Display Modes
Old 09-24-2008, 08:13 AM   #1
Shadow-Warrior is a jewel in the roughShadow-Warrior is a jewel in the roughShadow-Warrior is a jewel in the rough
Shadow-Warrior's Avatar
Army:
Shadow-Warrior's Tacoma Gallery
This should also work for the TACO's too.
Historic Background For Doing This MOD
Toyota has moved the Front Differential and Front Actuator breathers up high in the engine bay already for you, but neglected to move the Rear Differential breather, E-Locker breather, Transsmission & Transfer Case Breathers. Those with the MT will only have one breather in the engine bay area, you don't have the front actuator like the AT's do. I decided to relocate the breathers up high too, I would normally run all breathers inside the vehicle, but since the front is already in the engine bay. I decided to run the rear differential & Locker there too. I want to say this has been a collective effort by many on doing this Breather MOD.
Check out this video on Diff Breathers
Diff Breathers for 4x4
"IF YOU DON'T TRAVEL IN HIGH WATER, YOU DO NOT HAVE TO DO THIS MOD"
I will start off with my own way of accomplishing this first. I have added Blackcherry's & Dukeofjuke’s MOD location at the end of this post. This is mainly do to mine being a little more complete and clear as far as following along with directions, pictures and tools needed to do this MOD.
To do my way of the Filter location in the engine bay you will need the following items:
Need to Purchase
1. 15’ of ¼” Fuel line. (Shop around, I paid .85 cents a foot, I have seen it for 1.85 a foot)
2. You will need to order a Toyota Camry Fuel Line Union Part # 90404-51026 ($3.50)
3. You will need to buy (3) small ¼ inch Hose clamps
4. You will need some plastic Zip Tie’s for securing the hose from the rear to the engine bay.
5. You will need a small piece of 16ga steel (This can be purchased from Lowe’s or Home Depot)
6. Rustolem Flat Black paint (If you don’t have any, Check with Dragon I’m sure he has plenty lying around. He's the undisputed “Rattle Can King”. J/K
7. You will need to buy a small 1/4" x 1/4" x 1/8" “T” for tying in the E-Locker hose to the Rear Differential Hose. This can be purchased at any Automotive store for under a dollar.
Tools Needed
1. You will need a standard screw driver (for Hose clamps)
2. You will need a Dremel Tool with Cut-off wheels or a Hand held Grinder with cut-off wheel.
3. Knife to cut the fuel hose to length
4. Your going to need some sand paper and metal file to smooth out the edges of the bracket.
The Following are some pictures of the items as listed above.
This is a 1/4" x 1/4" x 1/8” “T” You can pick these up at any Automotive store for under $1.00
Here is a picture of the Toyota Camry “Union” part number # 90404-51026
I found a nice small air breather from AutoZone, $9.95 It’s made by “Spectre” Part number 3992, they come in different colors, Silver, Blue, Red, Yellow,etc. The following are pictures of the small colored Filters, they are very similar to a K&N filter. I used a little oil on mine to keep it water proof too.
I went ahead and did the leg work for everyone for the small colored breathers.
Here is the following part numbers for the colored filters
Specter Part number # 3992 Red Breather
Specter Part number # 3994 Yellow Breather
Specter Part number # 3995 Silver Breather
Specter Part number # 3996 Blue Breather
Specter Part number # 3998 White Breather
Here is the web site : Spectre Performance - Official Site
You can also find them in your local automotive store too.
I decided to stay with the TRD theme, (Red). I also purchased 20 feet of ¼ fuel line for running the hose to the engine bay. I shopped around a bit for it, Pep Boys wanted $1.85 a foot, I found it at O’Reillys for .85 cents a foot.
I had some 16ga steel left some from my CB mount MOD and Fuse box MOD, so I used this material for making my breather bracket. You can purchase this at Lowe’s or Home Depot for under $10.00 I decided along the drivers side close to the firewall for the breather location.
I measured a 2” wide, 5” long would be just right for the bracket. I also decided to make one end round. I used my dremmel tool with cut-off wheel to cut the shape out; you can use a handheld grinder, etc. I then drilled out a ¾ inch hole for the filter. I then bent the bracket 2.5 inches back from the top of the bracket. My wife had the camera so, I couldn’t take any pics of the bracket at this stage.
I then sprayed the bracket with gray primer, then a coat of flat black.
I bought a self tapping metal screw with lock washer for attachment to the firewall.
I attached the breather to the bracket, then the hose to the breather, then ran the hose along the bottom under the vehicle.
I attached the hose with tie wraps along the frame.
In this pic you can see I left a good portion of the hose and then cut it off, tie wrapping it to the cross bar. Please don not cut the hose off to short, you want to leave enough room for your rear axel to be able to articulate without pulling out the hose from the Union.
The new Union installed.
This is a pic of the existing E-Locker location, This is what we are going to remove and install the “T” to. You need to cut about 3-4 inches from the locker hose breather end off. See the "CUT Line in the above pic. Then push the "T" into the small locker hose. I then used (2) small ties wraps for securing it, hose clamps are to small.
The newly installed "T" run from the Rear Differential Hose & E-Locker then into the Main hose which runs all the way to the engine bay.
Finished Rear Differential & E-Locker Breather location in the engine bay.
Auto Transmission & Transfer case breather location & information for relocation of breathers.
A new member Jim (007FJ) took the time to wade through hundreds of pages of the Repair manual to find the Transmission Breather and Transfer case breather locations. I new they were there, but never took the time to go find them since they were located higher up inside under the vehicle. With that being said, I too will be relocating these too just like the rear differential and E-Locker breathers. If your running in deep water it pays to take the time and relocate all your breathers up high to prevent damage to the drive train. Thanks again Jim and to the others that have helped to make us all water tight out the on the trails.
Here are the following Schematics of the locations of the AT Transmission & Transfer Case breathers.
Auto Transmission Breather Location (MT doesn't have this Breather)
Here is the MT (Manual Transmission Breather Location)
Transfer Case Breather Location
These will need to be relocated up high also either in the engine bay, rear jack storage area or somewhere up high out of the way of any water getting to them.
Transmission & Transfer Case Breathers:
If you open the hood and along the passenger side towards the rear of the the top of the engine, you need to reach down inside and feel. You will find (2) breathers right on top, a plastic one (this is the Automatic Transmission Breather) and a small silver cap one like the E-Locker breather. Both of these need to be removed and placed higher inside the engine bay.
I reached down between the firewall and the rear of the engine and squeezed the hose clamp holding the Plastic AT breather on, I slid it downwards out of the way. I then twisted and pulled on the plastic breather, it pulled off pretty easily.
The AT Transmission Breather after removal
I then took some ¼” hose with a ¼” brass coupling and attached it to one end of the hose, securing with a tie wrap. I then sprayed WD 40 on the other exposed end of the brass fitting to allow an easy transition on to the hose. It slid on nicely, I then used another tie wrap to secure that end on to the hose.
New Hose & Coupling to run the breather up into the engine bay higher.
Newly installed Coupling coming from the the Transmission.
I then reached down between the firewall and the rear of the engine and grasped hold of the Transfer Case Breather, it is the metal one like the locker. This one is very easy to remove, just pull firmly and it will slide right off. I then put together another brass 1/8” coupling and installed it on one end of the 1/8” hose. I secured it with another tie wrap. I reached down and slid this one on to the remaining hose. I again secured it with another tie wrap to keep it from coming off.
New 1/8" Hose and Coupling to run the breather up into the engine bay higher.
Newly Installed Coupling coming from the Transfer Case.
The finshed run of both hoses located higher in the engine bay. I will at a latter date replace the stock valves with a Filter like the Rear Differential and E-Locker.
The new relocated Rear Differential, E-locker, Transmission, Transfer Case breathers completely installed and ready for some SCUBA Driving . I hope this will help others that do any kind of water crossings.
Breather Cost $9.95
Fuel Line Cost $15.00
Hardware Cost $ 1.50
“T” Cost $.50
Leftover Metal $ Free
Union Cost $3.75
Knowing that water can’t get in and damage your rear differential; Priceless
So, for under $30.00 I have the piece of mind of no contamination to the Rear Differential & E-Locker and it looks good too
Good luck to all you SCUBA Drivers out there
SCUBA Drivers Unite!
__________________________________________________ _______________________________
Blackcherry’s Location MOD
New location for the breather is in Fuel Door Opening.
Dukeofjuke’s Location MOD
I took a different approach to relocating my rear differential breather. I popped out the rubber seal/plug just behind the driver's side mud flap and ran the rubber hose into the access panel where the jack is stored. I cut a small circular hole in the rubber seal/plug and then applied some silicon.
__________________
"Good people sleep peacefully at night safe in the knowledge that rough men stand ready to do violence on their behalf" (George Orwell)
TLCA Member : #18084
Honorary AZFJ Club Member
Honorary SoCal Club Member
FJ Cruiser Club Member
Meet The RAPTOR 2007 TRD SE
Old 09-24-2008, 08:26 AM   #3
Army:
Originally Posted by luk8272 View Post
You are on a roll.
LOL...Yeh, I thought I should also give to this forum also. So I decided to post some info I thought others here may use too. Just trying to be helpful
I got to pull my own weight around here LOL.
__________________
Old 09-24-2008, 06:47 PM   #5
mjp2 has a reputation beyond reputemjp2 has a reputation beyond reputemjp2 has a reputation beyond reputemjp2 has a reputation beyond reputemjp2 has a reputation beyond reputemjp2 has a reputation beyond reputemjp2 has a reputation beyond reputemjp2 has a reputation beyond reputemjp2 has a reputation beyond reputemjp2 has a reputation beyond reputemjp2 has a reputation beyond repute
mjp2's Avatar
mjp2's Tacoma Gallery
You are good to have around. Excellent contributions so far!
Old 09-24-2008, 07:40 PM   #6
Nighttime.. DAYTIME!!!
Kilted Chiken has a reputation beyond reputeKilted Chiken has a reputation beyond reputeKilted Chiken has a reputation beyond reputeKilted Chiken has a reputation beyond reputeKilted Chiken has a reputation beyond reputeKilted Chiken has a reputation beyond reputeKilted Chiken has a reputation beyond reputeKilted Chiken has a reputation beyond reputeKilted Chiken has a reputation beyond reputeKilted Chiken has a reputation beyond reputeKilted Chiken has a reputation beyond repute
Kilted Chiken's Avatar
Coast Guard: Petty Officer First Class, IT1
Kilted Chiken's Tacoma Gallery
Shadow...
i thought that post looked familiar. I am over on FJCruiserforums under Kilted Chiken.
Recently did this mod on my FJ but i didn't use the breather you did, I reused the one off of the e-locker.
anywho welcome to TW
Old 09-24-2008, 08:39 PM   #7
Off-Road Enthusiast S.W.Region
timmer has a reputation beyond reputetimmer has a reputation beyond reputetimmer has a reputation beyond reputetimmer has a reputation beyond reputetimmer has a reputation beyond reputetimmer has a reputation beyond reputetimmer has a reputation beyond reputetimmer has a reputation beyond reputetimmer has a reputation beyond reputetimmer has a reputation beyond reputetimmer has a reputation beyond repute
timmer's Avatar
timmer's Tacoma Gallery
Awe some work Bud!! this is what a mod write up should look like.
major props to you
timmer
__________________
Smokey Bear sez, Hear it again here Kids !!! http://www.vom.com/wesford/SBHA/SONG...ySONG_ga.shtml
I give my pledge as an American to save and faithfully to defend from waste the natural resources of my country - its soil and minerals, its wildlands, waters and wildlife.
Old 09-24-2008, 09:16 PM   #8
Army:
I believe you have more than started.
Thank You sir
Originally Posted by Banshee View Post
Shadow...
Thanks, yeh you can use the stock breather too or any other item that you like. Glad it could help.
major props to you
timmer
Thanks, I try
__________________
Old 09-24-2008, 10:21 PM   #9
Casey05Taco is just really niceCasey05Taco is just really niceCasey05Taco is just really niceCasey05Taco is just really niceCasey05Taco is just really nice
Casey05Taco's Avatar
Casey05Taco's Tacoma Gallery
Send a message via AIM to Casey05Taco
man shadow you are everywere now lol
Old 09-24-2008, 10:21 PM   #10
Army:
Just trying to help others out
__________________
Home > Tacoma Discussion > Off-Roading & Trails
Display Modes
Related / Mentioned Products
K&N Air Filter - $29.87
diff and t case breather mods timmer Off-Roading & Trails 5 06-29-2009 02:32 PM
Transfer Case Breather Extension Monkeysuncle 2nd Gen. Tacomas 4 09-02-2008 12:09 PM
Transfer case leak!?! *PICS* Help! TacoNL Technical Chat 5 07-21-2008 07:12 PM
1997 transfer case Ben E Buy / Sell / Trade 0 05-29-2008 07:40 PM
Rear Diff, Trans and Tansfer Case Breather tube mod lightmup Technical Chat 7 05-18-2008 03:51 AM
Copyright © 2009 Tacoma Forum
