Go Back   Tacoma World Forums > Tacoma Discussion > Off-Roading & Trails
Solution for tire air up on the trail?
Old 10-01-2009, 04:54 PM   #21
Solo Member
kilo is one of the sharper tools in the shedkilo is one of the sharper tools in the shedkilo is one of the sharper tools in the shedkilo is one of the sharper tools in the shedkilo is one of the sharper tools in the shedkilo is one of the sharper tools in the shedkilo is one of the sharper tools in the shedkilo is one of the sharper tools in the shedkilo is one of the sharper tools in the shedkilo is one of the sharper tools in the shedkilo is one of the sharper tools in the shed
kilo's Avatar
Marines: Kilo Battery 3rd Battalion 11th Marines 1st Marine Division
kilo's Tacoma Gallery
Hard wire one in and forget about it. It's always there and waiting.
Old 10-01-2009, 05:08 PM   #22
ruppmeister has much to be proud ofruppmeister has much to be proud ofruppmeister has much to be proud ofruppmeister has much to be proud ofruppmeister has much to be proud ofruppmeister has much to be proud ofruppmeister has much to be proud ofruppmeister has much to be proud ofruppmeister has much to be proud of
ruppmeister's Avatar
Army:
ruppmeister's Tacoma Gallery
Kilo - can you give some detail as to how you did this. I am REALLY wanting to do this with the compressor I have (MV-50?). I would definitely want this if the extra tank is something not too expensive.
A write-up would be AWESOME dude!
Old 10-01-2009, 05:11 PM   #23
I KEEEEEL YOU
Burgman is one of the sharper tools in the shedBurgman is one of the sharper tools in the shedBurgman is one of the sharper tools in the shedBurgman is one of the sharper tools in the shedBurgman is one of the sharper tools in the shedBurgman is one of the sharper tools in the shedBurgman is one of the sharper tools in the shedBurgman is one of the sharper tools in the shedBurgman is one of the sharper tools in the shedBurgman is one of the sharper tools in the shedBurgman is one of the sharper tools in the shed
Burgman's Avatar
Burgman's Tacoma Gallery
Originally Posted by silverback07 View Post
I know a couple guys with that exact Viair setup. You have to stop and take breaks while its working because it overheats. The little Masterflow/Superflow MV-50 is a great cheap alternative. Buy that, hardwire it in under the hood, add a 3-5 gallon tank with a pressure shutoff switch and you have a great little OBA system for relatively low cost.
i have the MV-50 and it did all four tires from 20 up to 35 in like 15 minutes w/o overheating
Old 10-01-2009, 06:29 PM   #24
Duck Killing Machine
Siebler is one of the sharper tools in the shedSiebler is one of the sharper tools in the shedSiebler is one of the sharper tools in the shedSiebler is one of the sharper tools in the shedSiebler is one of the sharper tools in the shedSiebler is one of the sharper tools in the shedSiebler is one of the sharper tools in the shedSiebler is one of the sharper tools in the shedSiebler is one of the sharper tools in the shedSiebler is one of the sharper tools in the shedSiebler is one of the sharper tools in the shed
Siebler's Avatar
Siebler's Tacoma Gallery
I got one of the Sun Performance Compressors in a group buy on CT. 100% duty cycle at 200psi. Its probably one of the best things ive done. I also did a 2.5 gallon tank so airing up is pretty quick.
Old 10-01-2009, 06:47 PM   #25
takern is one of the sharper tools in the shedtakern is one of the sharper tools in the shedtakern is one of the sharper tools in the shedtakern is one of the sharper tools in the shedtakern is one of the sharper tools in the shedtakern is one of the sharper tools in the shedtakern is one of the sharper tools in the shedtakern is one of the sharper tools in the shedtakern is one of the sharper tools in the shedtakern is one of the sharper tools in the shedtakern is one of the sharper tools in the shed
takern's Avatar
Marines: marine corps
takern's Tacoma Gallery
there is always the option of a standard bike pump. i have never tried it, but in theory it would work. the pressure of tires is nothing compared to bike tires. it would take forever, but you would get a good workout. if nothing else, you could do it just enough to get to the nearest gas station
Old 10-01-2009, 08:06 PM   #26
BBC. Bring Back Clarkson
ForeRunner is one of the sharper tools in the shedForeRunner is one of the sharper tools in the shedForeRunner is one of the sharper tools in the shedForeRunner is one of the sharper tools in the shedForeRunner is one of the sharper tools in the shedForeRunner is one of the sharper tools in the shedForeRunner is one of the sharper tools in the shedForeRunner is one of the sharper tools in the shedForeRunner is one of the sharper tools in the shedForeRunner is one of the sharper tools in the shedForeRunner is one of the sharper tools in the shed
Coast Guard: Chief Petty Officer, ITC
ForeRunner's Tacoma Gallery
Originally Posted by chris4x4 View Post
It should. No idea how much power it will draw....If you get it, you may want to make sure the bed outlet has enough juice to power it, befreo takeing it on the trail.
According to Sears it draws 3.3 amps. 3.3x120= 396Watts. Almost the max of the inverter.
Originally Posted by Janster View Post
What's wrong with liquid CO2?
I had one in the back of my 96 tacoma for a few years.
From what I understand at cold temps it becomes pretty useless.
I went with a ARB air compressor (CKMA12 high output) for the FJ and will buy one again for the Tacoma. TRDParts4U has them I think for $230 now. I'm able to air up 4 265/75 16's from 15psi to 36psi in 12 minutes. The compressor comes with the wiring loom, pressure switch, relays and extra connectors to wire in two lockers if need be.
Scroll down some.
Old 10-01-2009, 08:13 PM   #27
chris4x4's Avatar
chris4x4's Tacoma Gallery
Right. Wich is why I suggested he try it before relying on it. Its right there at the max the bed outlet will run.
Old 10-02-2009, 08:50 AM   #28
Masada [OP] Masada is offline
Banned
Masada is one of the sharper tools in the shedMasada is one of the sharper tools in the shedMasada is one of the sharper tools in the shedMasada is one of the sharper tools in the shedMasada is one of the sharper tools in the shedMasada is one of the sharper tools in the shedMasada is one of the sharper tools in the shedMasada is one of the sharper tools in the shedMasada is one of the sharper tools in the shedMasada is one of the sharper tools in the shedMasada is one of the sharper tools in the shed
Masada's Tacoma Gallery
After listening to everyone and trying to compromise I found this at harbor Freight
http://www.harborfreight.com/cpi/cta...emnumber=95275
and then I would get this to go with it.
http://www.harborfreight.com/cpi/cta...emnumber=91860
While it's not the best, I think it might work for what I'm wanting to do...
Any thoughts or comments?
Old 10-02-2009, 08:51 AM   #29
chris4x4's Avatar
Cant argue the price. Try it out, and tell us what ya think.
Old 10-02-2009, 09:07 AM   #30
chris4x4's Avatar
For the same price you can get the Masterflow MF-50 and it puts out more air.
Seems those are starting to fall apart, though....I have heard a few people have the pistons shatter in theirs.
Old 10-02-2009, 09:20 AM   #31
Ban Pending
HBMurphy is one of the sharper tools in the shedHBMurphy is one of the sharper tools in the shedHBMurphy is one of the sharper tools in the shedHBMurphy is one of the sharper tools in the shedHBMurphy is one of the sharper tools in the shedHBMurphy is one of the sharper tools in the shedHBMurphy is one of the sharper tools in the shedHBMurphy is one of the sharper tools in the shedHBMurphy is one of the sharper tools in the shedHBMurphy is one of the sharper tools in the shedHBMurphy is one of the sharper tools in the shed
HBMurphy's Avatar
HBMurphy's Tacoma Gallery
Very Nice!
If you can. Do one tire. Let the compressor cool down. Do another tire. Let it cool down....
As much as many of these talk about 100% duty cycle. They may be - for what life span? 100 cycles? IMO Heat and shock (pouring cold water on a hot compressor) kills these things. If you want to pour water on these things, create a water filed jacket
Old 10-02-2009, 09:21 AM   #32
chris4x4's Avatar
and you think that Harbor Freight compressor will hold up?
My MF-50 was used for about a year and I didn't have any issues.. its actually my backup compressor should something happen to my Oasis.
LOL!! You have a point.
Old 10-02-2009, 09:22 AM   #33
chris4x4's Avatar
True!
Old 10-07-2009, 07:22 PM   #34
Banned
So I went to harbor freight and bought this one.
http://www.harborfreight.com/cpi/cta...emnumber=93796
I'm going to test it out this weekend and let everyone know how it works. So far i plugged it into the bed outlet and it powered up just fine. In about 30 seconds on, it was at 34 psi in the tank. Not too bad, but what do I know...
Old 10-07-2009, 07:27 PM   #35
Ban Pending
HBMurphy's Avatar
Let us know how it goes! Would love to have something that already has regulator, etc.
Old 10-07-2009, 07:37 PM   #36
GASH is a splendid one to beholdGASH is a splendid one to beholdGASH is a splendid one to beholdGASH is a splendid one to beholdGASH is a splendid one to beholdGASH is a splendid one to beholdGASH is a splendid one to behold
GASH's Avatar
GASH's Tacoma Gallery
I have the VIAIR 300P it works well enough for my 265/70/17 DuraTracs, it wasn't very expensive on Amazon.
Old 10-07-2009, 09:07 PM   #37
RelentlessTaco's Avatar
I like the info i've gotten out of this thread. I've been going between a Viair setup, or a 15lb The Source sport CO2 setup but still undecided.
Old 10-10-2009, 06:08 PM   #38
Seasoned Newbie
poff1986 will become famous soon enoughpoff1986 will become famous soon enough
poff1986's Avatar
poff1986's Tacoma Gallery
I recommend this one... quick and easy.... lol
http://www.youtube.com/watch?v=O8iy-IxFWAc
Old 10-10-2009, 06:29 PM   #39
Ban Pending
HBMurphy's Avatar
Now that was impressive. What was that? Starter fluid? Cool! Also, if you remove that image tag you won't get whacked with a falling x!
Old 10-10-2009, 07:08 PM   #40
chris4x4's Avatar
Looks like it deflated perttey quick after the bead was seated....
Water Thru Cabin Air Intake - My Solution 05Moose 2nd Gen. Tacomas 41 03-10-2015 06:10 AM
Is there a worse tire than the BF Goodrich rugged trail tire Joe Taco Wheels & Tires 56 05-15-2010 10:18 PM
Nitto trail grapplers air pressure recommendation DARK TRD Wheels & Tires 8 04-01-2010 08:13 PM
1 tire - BFG Rugged Trail shootermcgavinyo Buy / Sell / Trade 1 08-27-2009 06:06 PM
Spare tire low air solution. PPD934 Wheels & Tires 7 02-14-2008 05:12 PM
