Solution for tire air up on the trail?
Discussion in 'Off-Roading & Trails' started by Masada, Oct 1, 2009.
  1. Oct 1, 2009 at 9:38 AM
    Masada
    Masada [OP] Well-Known Member
    Taylor
    Laveen, AZ
    05 Tacoma 4x4 TRD Off Road
    All Pro Steel Plate Front Bumper| All Pro Light Bar| All Pro IFS Skid Plate| All Pro E-locker guard| PIAA 510 Fog Lights| Hella 700FF| Fox 2.5 Coilover| Bilstein 5100 on the rear| BHLM| Grill Craft MX Series insert| Added two D-rings to bed|AVID Off Road sliders| AFE Dry Flow S| Gibson Cat Back| Custom Bedbar with hilift mount| Camburg 1" Uni-Ball UCA's| Hi-Lift 48" Extreme
    I was thinking of trying to use the bed outlet to power something to air up my tires after I get off the trail, but I haven't found anything that would fit the application yet.
    Does anyone know of such a devise that doesn't run off the batter style jumper cables?
    I would like to avoid hauling a scuba tank around with me or installing a small compressor in the back of my bed. Just something that plugs into a socket and can air up the tires...
    Any help would be nice :)
  2. Oct 1, 2009 at 9:48 AM
    bb609
    bb609 O.F.
    NH
    '09 TRD Sport Access Cab
    FOX 2 1/2" CO's STOCK UCA's - They used to be Icons! Icons suck!!! TSB Rear w/Bilstein 5100's - Air Lift System - Leer 550 Bedcover - Ventshades - Yota Bed Mat - Sheepskins!!! - Weathertechs
    I have one that plugs into the cigarette lighter.
  3. Oct 1, 2009 at 9:51 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Viair and QuickAir have compressors that connect to your battery via a spring clamp type connector (similar to jumper cables), and they both work quite well. Many different sizes availible. You would want the "Portable" design.
  4. Oct 1, 2009 at 9:52 AM
    JDMcQ
    JDMcQ Well-Known Member
    John
    The Mushroom Capital of the World
  5. Oct 1, 2009 at 10:15 AM
    Masada
    Taylor
    Laveen, AZ
    I'm dig'n the craftsman setup, but will this plug into my outlet in the bed of the truck?
  6. Oct 1, 2009 at 10:18 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It should. No idea how much power it will draw....If you get it, you may want to make sure the bed outlet has enough juice to power it, befreo takeing it on the trail.
  7. Oct 1, 2009 at 10:24 AM
    Pster
    Pster Well-Known Member
    Charlotte, NC
    2006 Tacoma 4x4
    Bak Flip bed cover, shorty antenna, Peripheral iPod interface, Garmin 750 mount, add'l bed tie down rings, Westin nerf bars, hitch safe, tailgate lock, Ideal 1 3/4" turn-key clamp to secure tailgate from removal, Spare tire security cable, spare tire stainless air hose extender, Fumoto oil drain valve, Amp Research Bed X-Tender w/Schlage Cable Lock, bed mat, Redline hood struts
  8. Oct 1, 2009 at 10:25 AM
    amaes
    amaes Cuz Stock Sucks
    Alex
    Phoenix, AZ
    2011 FJ Built
    ICON Stage 6, RCI Skids, Blacked out
  9. Oct 1, 2009 at 10:36 AM
    Masada
    Taylor
    Laveen, AZ
    They should work fine though after I get done with the trail right? I mean it not like I'm airing up a flat tire or anything.
    Oh and what is a good trail PSI to keep the tires at? I was thinking around 28-30...
  10. Oct 1, 2009 at 11:29 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Air pressure largely depends on teh trail. What tires your running, etc.
  11. Oct 1, 2009 at 11:30 AM
    JDMcQ
    John
    28-30? Isn't that what you would run on the street?
  12. Oct 1, 2009 at 11:33 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Depending on the tire, and terrain out here, that could be a good pressure. We have alot of rock and such, and with the OEM tires, I would say 28 psi is plenty aired down.
  13. Oct 1, 2009 at 11:43 AM
    JDMcQ
    John
    I never would have thought. I run 28-30 on the road and off road air down to 18-20 for rocky trails.
  14. Oct 1, 2009 at 11:45 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    What's wrong with liquid CO2?
    I had one in the back of my 96 tacoma for a few years.
  15. Oct 1, 2009 at 12:29 PM
    Masada
    Taylor
    Laveen, AZ
    I want something re-usable, and I don't have to go get filled every trip out there.
    Chris, I have Michelin LTX M/S that came with the truck, and I am running 35 PSI on all tires. I cant wait to get rid of these ugly ass tires and get some Yokohama Geolanders A/T-S, I had these on my '94 Pickup and loved them...
  16. Oct 1, 2009 at 12:34 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I read in one of your posts that you wanted to go to Needle Rock (Castle Rock)? Thats a great place to go, and you dont need to air down for it. I wouldnt air down too much with the stock tires, as they are not that strong, and if something gets into a sidewall, it will damage the tire. FWIW, I have found that 20 PSI is a good pressure for most things out here. Unless you are doing some serious rock crawling, or in deep sand, like 7 mile wash, then you may want to consider going a little lower. :)
  17. Oct 1, 2009 at 1:02 PM
    neontrail
    neontrail ✈ ✈ ✈ ✈ ✈ ✈ ✈
    Idaho
    2004 NISSAN XTERRA XE/SE
    De-badged, Tint 20%, Blue 48 LED dome-light, .......
  18. Oct 1, 2009 at 1:34 PM
    hakan
    hakan Active Member
    hakan
    SF
    2002 toyota tacoma 4x4 TRD Off Road 3.4
    trail gear weld on rock sliders, leer camper, OME 883front Dacar springs in back, grey wire mod, rear diff breather mode, maglight mode, deck plate mode, camper shell defrost mode, UWS tool box,( viv air inboard air is coming soon)
    So if we are running
    255-70 r16 geolanders and we are in seriously deep sand how far down we can go do you guys think. keep in mind there is rocks in the sand sometime.
  19. Oct 1, 2009 at 1:58 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  20. Oct 1, 2009 at 2:02 PM
    dysfunctnlretard
    dysfunctnlretard Hi
    Manny
    CA
    2021 Jeep Rubicon
