-   Off-Roading & Trails (http://www.tacomaworld.com/forum/off-roading-trails/)
-   -   Lift Questions (http://www.tacomaworld.com/forum/off-roading-trails/277815-lift-questions.html)
Martinmann21 05-14-2013 12:39 PM
Lift Questions
I don't really want to mess with the current suspension in my '09 quad cab 4x4. Does anyone know if it is sufficient enough of a lift to just add 2inch leveling spacers in the front and adding a leaf to the back? It seems like a simple method.
BradyT88 05-14-2013 02:26 PM
Depends on what your plans are for using the Taco, but yes that is lift. Spacers aren't ideal but they are lift. You will probably want some longer shocks in the rear though, unless you will only be doing street driving and mild offroading.
DeeKay21 05-14-2013 02:33 PM
5100's would be the way to go for a descent cheaper priced lift. Try to stay away from spacers.
BradyT88 05-14-2013 02:35 PM
Sorry should have mentioned that. I am running 5100's on all 4 corners with an add a leaf in the rear. Like DeeKay21 said, 5100's would be a better option than spacers.
