Go Back   Tacoma World Forums > Off-Topic > Off-Topic Discussion
heating issues/ blowing cold air when stopped
Old 01-14-2012, 02:12 PM   #1
the risk is worth the reward
mattmxracer is one of the sharper tools in the shedmattmxracer is one of the sharper tools in the shedmattmxracer is one of the sharper tools in the shedmattmxracer is one of the sharper tools in the shedmattmxracer is one of the sharper tools in the shedmattmxracer is one of the sharper tools in the shedmattmxracer is one of the sharper tools in the shedmattmxracer is one of the sharper tools in the shedmattmxracer is one of the sharper tools in the shedmattmxracer is one of the sharper tools in the shedmattmxracer is one of the sharper tools in the shed
mattmxracer's Avatar
mattmxracer's Tacoma Gallery
a friend of mine has a nissan xterra and the heat is not working properly, When the car is moving the car heats up fine but when she stops at redlight it blows cold air, what could be the issue, bad thermostat or some type of sensor
Old 01-14-2012, 02:25 PM   #2
LostRebel is one of the sharper tools in the shedLostRebel is one of the sharper tools in the shedLostRebel is one of the sharper tools in the shedLostRebel is one of the sharper tools in the shedLostRebel is one of the sharper tools in the shedLostRebel is one of the sharper tools in the shedLostRebel is one of the sharper tools in the shedLostRebel is one of the sharper tools in the shedLostRebel is one of the sharper tools in the shedLostRebel is one of the sharper tools in the shedLostRebel is one of the sharper tools in the shed
LostRebel's Tacoma Gallery
The first thing I'd check is the coolant level. Too low a level might not circulate through the heater at low RPM, but could at higher RPM. There may also be a bleeder somewhere on the top side of the engine that might have to be bleed to purge air in the system. I'm just throwing these ideas out. I have no direct knowledge of Nissans, but have had both these issues with previously owned vehicles that suffered the same problem.
Old 01-14-2012, 02:28 PM   #3
I am checking these right now, thank you
Old 01-14-2012, 11:11 PM   #4
surfsupl is one of the sharper tools in the shedsurfsupl is one of the sharper tools in the shedsurfsupl is one of the sharper tools in the shedsurfsupl is one of the sharper tools in the shedsurfsupl is one of the sharper tools in the shedsurfsupl is one of the sharper tools in the shedsurfsupl is one of the sharper tools in the shedsurfsupl is one of the sharper tools in the shedsurfsupl is one of the sharper tools in the shedsurfsupl is one of the sharper tools in the shedsurfsupl is one of the sharper tools in the shed
surfsupl's Avatar
surfsupl's Tacoma Gallery
Tell him to get rid of the Nissan and buy a Toyota and he wont have these kind of problems
Old 01-14-2012, 11:26 PM   #5
joes06tacoma is one of the sharper tools in the shedjoes06tacoma is one of the sharper tools in the shedjoes06tacoma is one of the sharper tools in the shedjoes06tacoma is one of the sharper tools in the shedjoes06tacoma is one of the sharper tools in the shedjoes06tacoma is one of the sharper tools in the shedjoes06tacoma is one of the sharper tools in the shedjoes06tacoma is one of the sharper tools in the shedjoes06tacoma is one of the sharper tools in the shedjoes06tacoma is one of the sharper tools in the shedjoes06tacoma is one of the sharper tools in the shed
joes06tacoma's Tacoma Gallery
Low on coolant, clogged heater core, weak water pump. Most likely a clogged heater core. Might try back flushing it.
Old 01-14-2012, 11:27 PM   #6
rdm197aps is one of the sharper tools in the shedrdm197aps is one of the sharper tools in the shedrdm197aps is one of the sharper tools in the shedrdm197aps is one of the sharper tools in the shedrdm197aps is one of the sharper tools in the shedrdm197aps is one of the sharper tools in the shedrdm197aps is one of the sharper tools in the shedrdm197aps is one of the sharper tools in the shedrdm197aps is one of the sharper tools in the shedrdm197aps is one of the sharper tools in the shedrdm197aps is one of the sharper tools in the shed
Law Enforcement: Officer
rdm197aps's Tacoma Gallery
could be a vacuum problem, maybe (big maybe) there is not enough vacuum produced when the engine is idling. most vehicles use vacuum to work the actuator that closes the flap between the heat and cool side of the heater box under the dash (or where ever it is located, usually near the blower motor.) just an idea...
AC on my 02 tacoma suddenly stopped blowing cold skatehawaii Toyota Trucks & SUVs 2 10-04-2011 10:08 PM
Blowing Cold Air Bullet1850 2nd Gen. Tacomas 1 02-10-2011 05:31 AM
Replacement AC not blowing cold air Jhorn Technical Chat 4 12-01-2010 12:34 PM
One vent blowing cold air... smolo2000 Technical Chat 0 01-01-2009 11:00 AM
Installed Cold Air Intake--check Engine And Shift Point Issues MATTRESS Technical Chat 28 02-04-2008 11:57 PM
