Go Back   Tacoma World Forums > Off-Topic > Off-Topic Discussion
need some help. changing struts.
Old 02-28-2010, 12:48 PM   #1
First I derp.. then I herp
mntbiker2008 is one of the sharper tools in the shedmntbiker2008 is one of the sharper tools in the shedmntbiker2008 is one of the sharper tools in the shedmntbiker2008 is one of the sharper tools in the shedmntbiker2008 is one of the sharper tools in the shedmntbiker2008 is one of the sharper tools in the shedmntbiker2008 is one of the sharper tools in the shedmntbiker2008 is one of the sharper tools in the shedmntbiker2008 is one of the sharper tools in the shedmntbiker2008 is one of the sharper tools in the shedmntbiker2008 is one of the sharper tools in the shed
mntbiker2008's Avatar
Firefighter:
mntbiker2008's Tacoma Gallery
Hey all, I am changing the struts on the santa fe. The struts are actually connected to the knuckles. Ive got the sway bars disconnected from the struts and everything. Have one of 2 bolts that connect strut to knuckle out but the bottoms are not budging. even hitting them with a hammer and punch doesnt get it. i will post a pic here in a few. What do you guys recommend? Ive also pulled the rotors and callipers off thinking maybe the weight from the brakes might be putting some strain on the bolt but thats not the case.
thanks!
all that liquid on the strut is just pb blaster.
cv is under the towel
Old 02-28-2010, 02:24 PM   #2
O.F.
bb609 is one of the sharper tools in the shedbb609 is one of the sharper tools in the shedbb609 is one of the sharper tools in the shedbb609 is one of the sharper tools in the shedbb609 is one of the sharper tools in the shedbb609 is one of the sharper tools in the shedbb609 is one of the sharper tools in the shedbb609 is one of the sharper tools in the shedbb609 is one of the sharper tools in the shedbb609 is one of the sharper tools in the shedbb609 is one of the sharper tools in the shed
bb609's Avatar
Army: JFK Center, Fort Bragg, NC
bb609's Tacoma Gallery
Is that bolt threaded into the knuckle? For tough bolts, I have a 4' length of 2" cast pipe that slides down over my 24" 1/2 drive breaker bar. Not much that it won't move....or break.
Edit - Just noticed the first pic was the other end of the bolt which is probably frozen to the aluminum knuckle. I'd go with ^^^^
Good luck!
Old 02-28-2010, 02:55 PM   #3
Firefighter:
i was able to get it finally... i just took a heavy ass hammer and pounded the livin crap outta it. its only threaded at the end of the bolt. once i got the end inside the knuckle, i just took a big punch and pounded it in there. it was under a little bit of pressure from the spring for some reason.
need struts matt01yota Suspension 0 08-08-2011 04:43 PM
changing struts...... brelandt Suspension 27 04-25-2011 05:21 PM
changing struts wildjerseyfirefighter Technical Chat 11 07-27-2010 11:19 AM
Stock struts and springs vs Trd blistein struts and springs?????? Taco Man 06 2nd Gen. Tacomas 10 06-14-2010 07:16 PM
new struts T_Witt 1st Gen. Tacomas 5 06-14-2009 01:58 AM
