Devin's 05 Tundra Limited LT Build
Discussion in 'Other Builds' started by 05tundra13, Nov 16, 2011.
  1. May 1, 2013 at 2:35 PM
    #301
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    running an air bump off the lower arm is dumb and not really worth it, but if you're going to do it anyways then yes, it's where it should be in terms of placement
  2. May 1, 2013 at 2:36 PM
    #302
    RJALLDAY702
    RJALLDAY702 U MAD? OH U MAD
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    There are better ways to do it (bump off the upper) But not worth it? Now thats just silly.
  3. May 1, 2013 at 2:39 PM
    #303
    shawnphoto
    shawnphoto Well-Known Member
    MT
    First Gen Tundra
    First Gen Tundra Linked and Long Travel
    Makes sense, I just didnt get why a fabricator would do it "wrong" persay, or let it roll out like that with their name on it. I mean it only takes 20 minutes a side to pull and chop the shafts... But that's just me I guess.
    Yah asking a question about an improperly set up front end makes me a "fucking newb"... Thaks for changing it up Adam
  4. May 1, 2013 at 2:41 PM
    #304
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    the bumps are already shortened
  5. May 1, 2013 at 2:42 PM
    #305
    nelson18matt
    Goodyear, Arizona
    *SOLD*
    it isn't worth it... why run a bump if you're going to be riding it at ride height? run a triple secondary, get it dialed in, particularly the bump zone, run a poly bump simply to prevent metal on metal and you'll save the time and money of wasting the time and money running an improperly utilized air bump :thumbsup:
  6. May 1, 2013 at 2:42 PM
    #306
    RJALLDAY702
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    Same thing happened with mine. They need to be shortened to 2"
    Ah, So you're saying it isnt worth it if your bumping at ride height? I agree with this obviously because beentheredonethat. The bump oil is already tapped out because its hitting durring cycle, And then when you need it for exactly what its designed for its not gonna be there for that hard hit. But counting out the bump from the start is silly. But I agree with you
  7. May 1, 2013 at 2:44 PM
    #307
    05tundra13
    05tundra13 [OP] Well-Known Member
    Devin
    Simi Valley
    05 tundra doublecab
    When I can get the money for a engine cage ill bump it off the upper/spindle.
  8. May 1, 2013 at 2:44 PM
    #308
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    bumps are touching strike pad at ride height so owner can either shorten bumps are increase preload on shocks, or do nothing. Riding on bumps at ride height will only affect the ride at, you guessed it, ride height. Which means, if you spent a shit load of money building a desert rig only to complain about how it rides on the street, then this may be a problem for you. Once you are in the desert and start cycling the suspension like what the truck is supposed to do (operate off road), then there really isnt a ride height, and the bumps are doing their job by adding more dampening and bottoming out just before the primary shocks bottom out.
  9. May 1, 2013 at 2:45 PM
    #309
    05tundra13
    Devin
    Simi Valley
    05 tundra doublecab
    They are already 2"s
  10. May 1, 2013 at 2:45 PM
    #310
    RJALLDAY702
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    And thats jenga!
    :eek: :eek: More preload or heavier spring :thumbsup:
  11. May 1, 2013 at 2:49 PM
    #311
    05tundra13
    Devin
    Simi Valley
    05 tundra doublecab
    Double jenga. Lets go with the more pre load.
  12. May 1, 2013 at 2:50 PM
    #312
    jberry813
    Jason
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
  13. May 1, 2013 at 2:52 PM
    #313
    05tundra13
    Devin
    Simi Valley
    05 tundra doublecab
    If anyone gets in a reck...who's gonna be there to open the cab??? Me with my hi-lift. Totally worth it.
  14. May 1, 2013 at 2:53 PM
    #314
    RJALLDAY702
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
  15. May 1, 2013 at 2:56 PM
    #315
    shawnphoto
    MT
    First Gen Tundra
    I totally understand I wasnt complaining about ride height or anything, it just seemed odd to have that much bump that early, there is still a nice amount of uptravel that is going all against the bumps, instead of just hitting the bump on full compression and preventing metal on metal contact. I get that bumps are part of the suspension cycle, but with secondary bypasses installed is it necessary to have it so low? It would seem like half of the travel is operating on the bump, which would hypothetically fuck with the way it rides on or off road?
    now this makes sense to me... it almost seems like he would be better off without that bumpstop... but what do i know
  16. May 1, 2013 at 3:05 PM
    #316
    RJALLDAY702
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    But having bypasses and bumps is so fucking race car shawn.
  17. May 1, 2013 at 3:06 PM
    #317
    shawnphoto
    MT
    First Gen Tundra
    yah and once your on the track nothing matters.... especially a few inches of uptravel and hot ass bumpstop oil
  18. May 2, 2013 at 6:57 AM
    #318
    dirty dangler
    dirty dangler GFO DMC LBR
    adam
    simi valley,ca
    86 4runner bone stock
    wiper blades and a new battery
    bottom line is devin wanted bump stops. Yes i let it roll out of my garage like that cause thats exactly what devin wanted and an engine cage wasn't an option. and shawn " chop the shafts" haha your kidding right? also if you notice there is basically zero pre load on the springs(just enough to keep em in place at droop) because thats what devin asked for so he could still fit it under his car port deal. Ideally he needs to add some pre-load ( although the front will be a bit high with the solo spindles and the lift they provide) and shorten the bump to 1". having a 1" bump that far inboard will still bump out the last 3-4 inches of travel just like a bump off the upper would do. shawn you have a lot to learn and i would suggest doing some research before you start running your mouth and making stupid comments. Thats all...good day
  19. May 2, 2013 at 9:48 AM
    #319
    blackhawke88
    SGV, CA
    07 TRD Offroad
    ^ I was worried for a second because your post sounded so nice and pleasant in the beginning, then I got to the end and it reaffirmed for me that is was indeed Adam behind the keyboard :laugh:
  20. May 2, 2013 at 10:00 AM
    #320
    RJALLDAY702
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    Dont you remember? Adam has turned over a new leaf.. He is no longer an asshole all the time.. Only when provoked.
