Heather's 92 Pickup Build
Discussion in 'Other Builds' started by H Bomb, Feb 11, 2012.
  1. Nov 29, 2012 at 1:13 AM
    #241
    RussellG
    RussellG Well-Known Member
    Russell
    Firestone
    87 DLX/00taco everything except the FJ bits
    Diamond Axle SAS, TRD FJ calipers and brembo rotors on all 4, FJ rear axle, 5.29's and elockers in both, 3rz swap and dual cases,4.7 rear case,00 taco dash, bobbed bed,soft topper,raceline beadlocks, fj cruiser steering wheel and clinometer, super white paint and 37'' kevlars. Much more but i will keep it simple.
    Nice swap! Its nice to see Girls building rigs too! I have the TG 4'' springs and like em. the springs will settle a lot so be ready for the front to come down. If you set the shacke straight up like that in a few months it will be 15-20deg.
    My truck had 4"fronts and 5" rears planning on getting a carrier and weight for tools. i also had a hard topper at set up.
    When i went to wider axles i grabbed 4" rears and now it a tiny bit low in the rear with the carrier. Set up the shackles were straight. 2 months and 2 decent trips my shackles are back about 16deg now. in the rear. The fronts match
    Both are old pics..I need to get new ones. and both pics have 37's
  2. Nov 29, 2012 at 5:24 PM
    #242
    H Bomb
    H Bomb [OP] Well-Known Member
    SAS'd 92 Pickup/08 SR5 Tacoma
    ^^^ That's a nice looking truck! Those 37s are bad ass.
    That spot worked perfectly for the radio! I was worried about cutting up the inside of my truck, but I guess I'm too far past the point of returning it to stock now... Lol
  3. Nov 29, 2012 at 5:44 PM
    #243
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    did you ever get the ass end up??
  4. Nov 29, 2012 at 5:53 PM
    #244
    H Bomb
    Nope--not yet. I quit my job then started a new job, so I haven't had any time to work on the truck. I will probably start on the rear lift here soon...
  5. Nov 29, 2012 at 7:57 PM
    #245
    higherlux
    higherlux Well-Known Member
    Blake
    middle of S.C.
    1998 tacoma 2.7l 4wd/1986 POS
    Mall crawler status
    love your build, ive been following it over on yotatech. im pretty much basing my 86 off of your build, they both started out the same too (gray, single cab, long bed)
  6. Nov 29, 2012 at 9:43 PM
    #246
    RussellG
    Russell
    Firestone
    Thanks! My vote is 37s for yours. My buddy ran 35 on his 95 sas like yours and went 37s this time and likes it much better
    Thanks man! I posted it here too. If you wanna see anything else let me know. I can snap some pics if I don't have em.
  7. Nov 30, 2012 at 5:53 PM
    #247
    H Bomb
    37's would be cool! But, too many reasons to stick with the 35s--I don't want to start breaking stuff, and I worry it would be too underpowered on the highway.
  8. Nov 30, 2012 at 7:33 PM
    #248
    RussellG
    Russell
    Firestone
    I honestly think you will be fine you don't have a heavy foot. My stock toy axle never had issues, now on diamonds with mini truck knuckles and stuff I'm still having fun and not blowing it up.... Knock on wood. I ran 36's no gears on a 22r in Colorado for 3+ years. I know underpowered.
    What other reasons are you meaning?
  9. Dec 1, 2012 at 10:48 AM
    #249
    H Bomb
    Yeah--underpowered sucks. I had giant tires on a 4 banger Tacoma for a while, and it was impossible to get on the freeway. Lol
    Mostly I don't want to go to 37s because of the cost. (The tires are more expensive and I'd need to upgrade to longfields and chromolys.) Also, if it got any taller it wouldn't fit in my garage. And, I drive it on the street a bunch and really don't want to be underpowered--can't really upgrade from 5.29s.
  10. Dec 1, 2012 at 2:30 PM
    #250
    RussellG
    Russell
    Firestone
    I can understand that. I don't think with 5.29s you will have much trouble. I have 5.29s and 37s and even with the heavy beadlocks and tires I still can do 100+. If your front diff is open you won't have to worry about going 30splines jut don't beat the snot out of it and you will be fine. Keep in mind I'm also in co so elevation is not helping my power any.
    As for cost I wanted 35s when I was first looking but going to a 36 the cost went down a bit. It got me over the 35" tire hump right away my buddy went from 35's to 37's on his truck and said he didn't notice. The axles made more differance due to wind on the highway fighting the big blocks of tread. If your looking used once over 35s its all about the same. I was looking at going to 42's and the cost is the same as a nice set of 35s if its all used. I'm sure you will like whatever you do I'm just sayin I think you will wish you went bigger
  11. Dec 16, 2012 at 11:13 AM
    #251
    H Bomb
    Finally took the truck offroad to try out the new suspension:
  12. Dec 16, 2012 at 11:17 AM
    #252
    92shawman
    92shawman Person
    K
    The Americas
    1992 Toyota Pickup
    Lots...see build
    :yay: How'd it do?!?!
  13. Dec 16, 2012 at 11:20 AM
    #253
    H Bomb
    Awesome! The rear locker might be the best money I have put into the truck. Destroyed a u-joint, but that wasn't a huge issue. It is much more capable than it was before the SAS!
  14. Dec 16, 2012 at 11:22 AM
    #254
    92shawman
    92shawman Person
    K
    The Americas
    1992 Toyota Pickup
    Lots...see build
    Niiiice! Yeah rear locker is probably the next mod after suspension.
    How'd you destroy the u-joint?
  15. Dec 16, 2012 at 11:26 AM
    #255
    H Bomb
    Yeah, the rear locker made the mud puddles way too easy! I'm not certain how I destroyed the u-joint--Just started clunking on my way off the mountain. I think I probably just did a terrible job of installing the u-joint in the first place. I really don't want to deal with it, so I will probably just have a shop fix it (some things are worth paying for... LOL.)
  16. Dec 16, 2012 at 11:42 AM
    #256
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
    Glad to see you finally got to have some fun with it!
  17. Dec 16, 2012 at 1:50 PM
    #257
    alove0750
    alove0750 Well-Known Member
    Adam
    Concord, NC
    2015 DCSB 4x4
    Icon coilovers, shocks and springs SPC Upper Control Arms SCS Ray 10’s w/ 265/70R17 BFG KO2’s Leer 100XR shell
    :thumbsup: more pics please lol
  18. Dec 16, 2012 at 2:56 PM
    #258
    H Bomb
    Me too--Poor truck sat in the garage way too long! Can't wait to take it back out again now.
    Two more pics... But, that's all I got... :D
  19. Dec 22, 2012 at 10:02 AM
    #259
    H Bomb
    New front driveline:
    42E228E2-0B91-4C2B-BE6F-2DE20EA39D47-311_c326704811a6652abbeca1f4f6b34a1ad21aafa7.jpg
  20. Dec 22, 2012 at 8:06 PM
    #260
    Slodgetto
    Slodgetto Ăśber Posre
    Silas
    Looks strong. :cool:
    And seahawks... :thumbsup:
