Go Back   Tacoma World Forums > Tacoma Garage > Builds > Other Builds
Jerretxx: Something out of nothing, my 84 build
Old 09-10-2012, 06:20 AM   #241
jerretxx [OP] jerretxx is offline
Some do, others talk
jerretxx is one of the sharper tools in the shedjerretxx is one of the sharper tools in the shedjerretxx is one of the sharper tools in the shedjerretxx is one of the sharper tools in the shedjerretxx is one of the sharper tools in the shedjerretxx is one of the sharper tools in the shedjerretxx is one of the sharper tools in the shedjerretxx is one of the sharper tools in the shedjerretxx is one of the sharper tools in the shedjerretxx is one of the sharper tools in the shedjerretxx is one of the sharper tools in the shed
jerretxx's Avatar
jerretxx's Tacoma Gallery
Originally Posted by BallisticTaco View Post
I'm down to make a run next weekend if everyone else is.
Haha theirs a slight bit of work needed to run saturday
Old 09-10-2012, 06:21 AM   #242
jerretxx's Avatar
Originally Posted by ajohnson View Post
So I got curious and just went out and looked at my reg. card. On the card it read "shipped weight: 3190 lbs." and " gross weight: 4000 lbs.". So in that case I can't tell you how many times I have been over the tag weight with a load in the bed. I'm not gonna worry about it.
Shipped weight is how much te truck weighed (factory) gross weight is how much it would weight if it were loaded Down in the bed, trunk, or whatever
Old 09-10-2012, 06:36 AM   #243
Glamour Shot
ajohnson is one of the sharper tools in the shedajohnson is one of the sharper tools in the shedajohnson is one of the sharper tools in the shedajohnson is one of the sharper tools in the shedajohnson is one of the sharper tools in the shedajohnson is one of the sharper tools in the shedajohnson is one of the sharper tools in the shedajohnson is one of the sharper tools in the shedajohnson is one of the sharper tools in the shedajohnson is one of the sharper tools in the shedajohnson is one of the sharper tools in the shed
ajohnson's Avatar
ajohnson's Tacoma Gallery
Yea I know all that. I'm curious how your registration compares, take a look at it when you get a chance.
Old 09-10-2012, 07:38 AM   #244
BallisticTaco is on a distinguished road
BallisticTaco's Avatar
BallisticTaco's Tacoma Gallery
Not too much work but yea there is work to be done
Old 09-10-2012, 09:18 AM   #245
jerretxx's Avatar
On which truck
Old 09-10-2012, 09:58 AM   #246
Glamour Shot
ajohnson's Avatar
On which truck
The taco
Old 11-25-2012, 04:14 PM   #247
figured i would give an update on this thing.. got it all put back together new brakes, master cylinder, some new tread and got 4.7 case gears on the way.
Old 11-25-2012, 04:20 PM   #248
Glamour Shot
ajohnson's Avatar
Did you use the bigger 1" bore master cylinder? I put in a dual diaphram booster, 1" master, and blocked the LSPV and installed a manual proportioning valve for the rear. All that made a huge difference.
Old 11-25-2012, 04:26 PM   #249
the axle that i got to put back under it the brakes were ceased up so i put 88 pickup rotors and calipers on it and they wouldnt bleed properly so i had to replace a wheel cylinder in the rear and put a oem master cylinder back in and everything seems to be working fine now.
Old 11-25-2012, 05:12 PM   #250
jerretxx's Avatar
I had just put a new master cyl on, that's odd it needed another..
Old 11-26-2012, 02:40 AM   #251
Yea man I guess whenever the seals came in contact with air when we disconnected the lines it just ruined them because it wouldn't build pressure to bleed.
Old 01-30-2013, 12:58 PM   #252
valon5150 will become famous soon enough
valon5150's Avatar
valon5150's Tacoma Gallery
Nice truck man. do you have the 4.7 in it yet?
jerretxx impulse build jerretxx 2nd Gen. Builds 107 04-01-2013 09:50 PM
csuviper's Junktrk (84 Yota Pickup) Build csuviper Other Builds 92 11-18-2012 11:40 PM
jerretxx build! jerretxx 2nd Gen. Builds 76 03-08-2012 01:38 PM
ATTN: jerretXX (background) theTupper Photography 2 01-11-2012 06:56 PM
the ole 84 baggedhilux Street Trucks 16 07-01-2010 11:06 PM
