Scan Guage alternative (far better) for under $40
Discussion in 'Performance and Tuning' started by pyro13g, Jan 21, 2011.
  1. Jan 21, 2011 at 12:58 PM
    pyro13g
    pyro13g [OP] Well-Known Member
    Will
    Florida
    07 Tacoma Access Cab 4-CYL 5-Lug
    2.5" Lift, Add A Leaf, ridding on 30's, Sound Mat in floors and doors
    So I read about this app online on Lifehacker and did this mod on my Tacoma and I love it! So heres the idea.
    Parts needed:
    • ODB II Bluetooth (ebay for under $30 [ ships from China :mad:] ):eek:
    • Smart phone (android based)
    Thats it!
    Program Used:
    • Torque (free version!) from the app store or market on andriod
    The Build:
    Get the bluetooth module and hook it up, it should be located under the dash around the e-break for the 05+ Tacomas and near the fuse panel. Just plug it in its that simple. On your cell phone, download the app, turn on blue tooth and connect to the device. Password is usually 1234. Turn the app on and enjoy, the nice thing is it has so much data that you can use from your engine and the great part is the gauges are totally customizable! Pick what you want and where it goes on the screen!
    I recommend a window mount for your phone so your not staring at the gauges all day long, I have been looking at them non stop!
    App Details, What it can do:
    See what your car is doing!!
    Torque is a vehicle / car performance / diagnostics tool that uses Bluetooth ELM/OBD/PLX adapters to connect to your OBD2 engine management / ECU
    It can use the GPS to provide tracker logs with engine logging so you can see what you were doing at any point in time
    It can also show and reset a DTC / fault code like a scantool.
    ... Read More/>It also has:
    * Dyno / Dynomometer and Horsepower/HP
    * 0-60 timings - see how fast your car is (or truck :))
    * Massive fault code database for allowing lookup of fault codes from many different manufacturers
    * Send logging information to web or email CSV/KML for analysis via excel / openoffice
    * Heads up display / HUD
    * GPS Speedo/Tracking - see what you were doing and your engine, at a point in time
    * Turbo boost feature for vehicles that support MAP sensors
    * Alarms (for example if your coolant temperature goes over 120C!)
    Works on any vehicle that supports the OBD2 standard (most vehicles built after 2000 (diesels after 2004) but can work for vehicles as far back as 1996) - if in doubt check with your manufacturer first or look for 'OBD2' on written on a big white label in your engine bay
    Has been reported to work on vehicles made by GM/Vauxhall/Opel, Ford, Chrysler, Mercedes, Volkswagen, Audi, Jaguar, Citroen, Peugoet, Skoda, Kia, Mazda, Lexus, Daewoo, Renault, Mitsubishi, Nissan, Honda, Hyundai, BMW, Toyota, Seat, Dodge and many more vehicle makes
    If you buy one of the cheap china OBD2 bluetooth adapters from ebay/Amazon, then make sure you have a good returns policy with the seller as quite a few of the cheap units are defective and 'stop working'/etc.
    Some of the best reliable OBD2 adapters are the Scantool.net adapter, the OBDKey adapter, and PLX Devices Kiwi Bluetooth - search on google for where to get them!
    More features added every release - there are forums at http://torque-bhp.com/ - if you want something added then let me know and I'll try to add it if it is possible!
    Recent changes:
    * Ability to trim 'Boost' readings
    * Fixed missing dial backgrounds
    * More settings including hiding the title bar and turning off GPS warnings
    * MPG dials may need to be deleted and re-created with this release if they stopped working.
    This is the cheapest and in my opinion far superior multi gauge than scan gauge. If you want help with setup pm me. I will add pics of my personal rig soon...
  2. Jan 21, 2011 at 1:05 PM
    uood8
    uood8 If You Search...You Shall Find.
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    Torque is not for iphone. boooo
  3. Jan 21, 2011 at 5:47 PM
    pyro13g
    Will
    Florida
    yea sorry about that I just tried to find it on my ipad so i could make use of the larger screen, but sadly not for ios
  4. Jan 22, 2011 at 7:35 AM
    pyro13g
    Will
    Florida
    Yes it will work for the 04 as long as you have an odb2 connector under the dash which you should
  5. Jan 22, 2011 at 8:31 AM
    SmoothFox
    SmoothFox Well-Known Member
    John
    DFW TEXAS
    2010 TRD OFFROAD 4x4
    CBI Sliders,PIAA Lights, 5100's, 4 leaf pack.
    This work w/iphone? I just ordered a Ultra Gauge 2 days ago.:confused:
  6. Jan 22, 2011 at 10:27 PM
    pyro13g
    Will
    Florida
    Not for iPhone yet :(
  7. Jan 29, 2011 at 12:36 PM
    ten80
    ten80 Active Member
    Christophe
    AK
    SR5
    But iPhones can get Rev, a very complete and well thought out product, although it requires a WIFI OBDII adapter.
  8. Feb 3, 2011 at 9:30 AM
    PacNWgen1
    PacNWgen1 NewHere
    Adam
    Oregon
    96' Tacoma Reg Cab 2.7l 4x4 5-speed 150,000+
    DynoMax ST, Deck Plate, Full Syn, Soon Header and Slotted Rotors
    AWESOME!!!!! I just got my PLX bluetooth OBD2 and it is amazing. Plug and play easy set up. You can make a dial gauge or graph for about any function/sensor on the truck. I have already diagnosed trouble code. And the bluetooth works so good I can tell how hot or cold my truck is from in the house. Anybody with a droid phone should have one.
  9. Feb 4, 2011 at 5:20 AM
    pyro13g
    Will
    Florida
    PacNWgen1: Glad you liked it! I think its a freakin bad a$$ tool for the truck especially since its cheaper than the Scan Gauge...
    Honestly I thought it was going to be a load of Garbage, but i was so surprised by all the functions it is capable of. This thing freakin rules!
    Did you see the load gauge? Do you think its pretty accurate that your engine load is around 80-90% when accelerating?
  10. Feb 25, 2011 at 7:16 PM
    SlimDigg
    SlimDigg We Back!!
    Calgary, AB
    Coming Soon....
    Is your chinese scanner tool still working?
  11. Feb 25, 2011 at 7:23 PM
    tacomarotto
    tacomarotto "Change is inevitable, but growth is optional."
    Jon
    Jacksonville
    Audi S3
    x2
  12. Feb 25, 2011 at 7:24 PM
    SlimDigg
    SlimDigg We Back!!
    Calgary, AB
    Coming Soon....
    I pm'd him, hopefully he responds...
    I'm quite interested in torque
  13. Feb 25, 2011 at 8:13 PM
    SlimDigg
    SlimDigg We Back!!
    Calgary, AB
    Coming Soon....
    ahh f it. For 20 bucks i'm gonna get one.
  14. Feb 25, 2011 at 8:40 PM
    SlimDigg
    SlimDigg We Back!!
    Calgary, AB
    Coming Soon....
    Woohoo I won the first ebay auction I entered.
    Winning bid: US $0.06 :D
    Shipping: $19.99 Standard Int'l Shipping :(
    Will report back in a month when it gets here from China lol
  15. Feb 25, 2011 at 11:19 PM
    pyro13g
    Will
    Florida
    Chinese scanner has been working great no troubles what so ever I'm very happy with it. For the money you can beat it.
    So I finally looked on the mini cd that came with it and woah! Wish I did it sooner, there is lots of software with diagnostic tools and code scanners and you can even reset codes....
  16. Feb 25, 2011 at 11:49 PM
    SlimDigg
    SlimDigg We Back!!
    Calgary, AB
    Coming Soon....
    Ummm torque resets codes...
  17. Feb 26, 2011 at 12:00 AM
    RelentlessFab
    Eric
    Sparks, NV
    Seth (Prerunnerseth) has one of these setups in his FJ running off his droid-x. Its pretty trick... might have to get me one too.
  18. Feb 26, 2011 at 12:07 AM
    SurfInferno
    SurfInferno Dont be stupid, its not smart.
    Dylan
    Littleton, CO
    2001 DC
  19. Feb 26, 2011 at 1:10 AM
    JONNY TACO
    JONNY TACO Well-Known Member
    PA.
    DARK METALLIC GRAY -DOUBLE CAB SHORT BED
    ADVANTAGE TONNEAU COVER,TOYOTA BED LINER, POP&LOCK TAILGATE LOCK, SIDE TUBES, WIFE IN PASSENGER SEAT
    Does it work with any cell phone or does it have to be an iphone????
  20. Feb 26, 2011 at 4:51 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Sounds sweet!!
