True speed after regear formula.
Old 05-03-2012, 08:20 PM   #21
since87 is on a distinguished road
Navy: Nuc, Attack Subs
since87's Tacoma Gallery
Did any of you guys try using a GPS to compare "real" vs. speedo. Can also use same technology to compare odometer.
Old 06-14-2012, 06:26 AM   #22
spithead051 is one of the sharper tools in the shedspithead051 is one of the sharper tools in the shedspithead051 is one of the sharper tools in the shedspithead051 is one of the sharper tools in the shedspithead051 is one of the sharper tools in the shedspithead051 is one of the sharper tools in the shedspithead051 is one of the sharper tools in the shedspithead051 is one of the sharper tools in the shedspithead051 is one of the sharper tools in the shedspithead051 is one of the sharper tools in the shedspithead051 is one of the sharper tools in the shed
spithead051's Avatar
spithead051's Tacoma Gallery
How difficult is it to regear from 3.73 to 4.10 on a 2nd gen? My mpg sucks with 33"s because most of my driving is done in rush hour traffic each week.
Old 06-26-2012, 11:19 PM   #23
tacowhore is on a distinguished road
tacowhore's Avatar
tacowhore's Tacoma Gallery
looking to maybe drop a turbo kit to my 1st gen 4 banger tacoma. (2wd), i was wondering if re gearing is a good idea and if it will help performance and if there is a certain gear set up i should be looking at. my truck is also lowered.
Old 07-28-2012, 12:26 PM   #24
Its tha Southern Way
LBFD2005 is a splendid one to beholdLBFD2005 is a splendid one to beholdLBFD2005 is a splendid one to beholdLBFD2005 is a splendid one to beholdLBFD2005 is a splendid one to beholdLBFD2005 is a splendid one to beholdLBFD2005 is a splendid one to beholdLBFD2005 is a splendid one to behold
LBFD2005's Avatar
LBFD2005's Tacoma Gallery
i have the 3.73 in my 11' running 33's if i switched to the 4.10 would that throw my rpm's higher?
Old 10-08-2012, 05:46 PM   #25
Tayysere is on a distinguished road
Tayysere's Tacoma Gallery
So does this mean since I am running 275/65/18 I am actually getting better mpg than I think? Would that also mean since I am at stock gearing, my speedo is registering "less miles" than it should be?
Old 10-08-2012, 07:09 PM   #26
You say tomato..........I say fuck you!
05TacoRunner is one of the sharper tools in the shed05TacoRunner is one of the sharper tools in the shed05TacoRunner is one of the sharper tools in the shed05TacoRunner is one of the sharper tools in the shed05TacoRunner is one of the sharper tools in the shed05TacoRunner is one of the sharper tools in the shed05TacoRunner is one of the sharper tools in the shed05TacoRunner is one of the sharper tools in the shed05TacoRunner is one of the sharper tools in the shed05TacoRunner is one of the sharper tools in the shed05TacoRunner is one of the sharper tools in the shed
05TacoRunner's Avatar
05TacoRunner's Tacoma Gallery
Yes. If you go to tire size calculator under the mods&tutorial tab at the top you can plug in new tire and old tire size. It will tell you the difference in revolutions per mile.
Old 05-03-2014, 07:49 AM   #27
fulleraj is on a distinguished road
fulleraj's Avatar
fulleraj's Tacoma Gallery
Y
Old 03-25-2015, 03:18 AM   #28
AZ Sun Lover is one of the sharper tools in the shedAZ Sun Lover is one of the sharper tools in the shedAZ Sun Lover is one of the sharper tools in the shedAZ Sun Lover is one of the sharper tools in the shedAZ Sun Lover is one of the sharper tools in the shedAZ Sun Lover is one of the sharper tools in the shedAZ Sun Lover is one of the sharper tools in the shedAZ Sun Lover is one of the sharper tools in the shedAZ Sun Lover is one of the sharper tools in the shedAZ Sun Lover is one of the sharper tools in the shedAZ Sun Lover is one of the sharper tools in the shed
AZ Sun Lover's Avatar
AZ Sun Lover's Tacoma Gallery
Originally Posted by Cortland View Post
Everyone that has 4.10's and 33's said they saw an increase in fuel efficiency. Lets get some more responses from those guys.
Hmm... I'm still running a 30.5" tires and I'm re-gearing to 4.10's!
The V6 motor should be turning @ 2500 to 2600 rpm's @ top cruising speed or @ 75 to 80 mph. I will be @ 2370 rpm's w/ 4.10's @ 75 mph. With stock size tires & 3.73 gears the rpm's are 2155 @ 75 mph. 215 rpm's are not much but should help this truck a lot and should also help performance & gas milage.
I had a 2013 2.7L w/ a 5 speed manual w/ 3.31 gears and was just getting about 21 mpg daily driving. I changed the tire size to a 1.6" taller tire and the truck turn completely GUTLESS and suck a lot more gas. Went to 3.58 gears and the truck ran just a little better then stock and I was getting 22.95 mpg with daily driving. I then went to 3.73's the milage went to just over 25 mpg with daily driving but it was still on the slow side and was sold to buy the 2015 DCSB with a damn WTF automatic! *I hate automatics* but it's the only way one can get a V6 Tacoma in a 4x2. I should have installed a set of 3.90's in the 2013 but it's history now. Time to start all over!
With the 4.10's, an URD Y-pipe and a quite cat-back the V6 DCSB should run a lot better and get better milage. I also ordering light weight wheels ( for 6 lug wheels they are light weight )
AZ
Old 03-25-2015, 03:27 AM   #29
Dog slave
Erik65 is one of the sharper tools in the shedErik65 is one of the sharper tools in the shedErik65 is one of the sharper tools in the shedErik65 is one of the sharper tools in the shedErik65 is one of the sharper tools in the shedErik65 is one of the sharper tools in the shedErik65 is one of the sharper tools in the shedErik65 is one of the sharper tools in the shedErik65 is one of the sharper tools in the shedErik65 is one of the sharper tools in the shedErik65 is one of the sharper tools in the shed
Erik65's Avatar
Erik65's Tacoma Gallery
Or you can get this:
and not do math while you're driving
Old 03-25-2015, 03:45 AM   #30
Red
Large's Tacoma Gallery
I don't think it's a good idea to regear for MPG. The savings is miniscule vs cost of gear installation.
Old 03-25-2015, 09:42 AM   #31
What about performance?
Fuel will count when gas goes over $7 a gal. when the Middle East quits playing with oil prices. Yes they are just playing with the USA oil prices to drive out the smaller competition, most Americans are just blind to this fact.
Plus I can re-gear for a lot less than most.
AZ
Recovery Formula... gjbonner Off-Roading & Trails 61 03-05-2015 07:09 PM
2TR w/33's and regear/no regear info wanted 08pretaco 4 Cylinder 147 01-29-2011 02:01 PM
Formula 1 in Austin, TX NAAC3TACO Sports, Hobbies & Interests 0 05-25-2010 01:53 PM
Formula One FearNothing321 Sports, Hobbies & Interests 4 11-04-2009 07:34 AM
