35 Inch Tire regear
Old 08-16-2011, 02:16 PM   #1
taylorholt5 is on a distinguished road
taylorholt5's Avatar
taylorholt5's Tacoma Gallery
35 Inch Tire regear
01 trd prerunner 3.4 v6 stock gearing makes it run like shit, i have heard from some that it will never run good even with a re gear, and others say a regear is a must!
What gears should i run?
And how much will it cost?
any help is great!
Old 08-16-2011, 03:07 PM   #3
Fodder4U is on a distinguished road
Fodder4U's Avatar
Fodder4U's Tacoma Gallery
Well I am familiar with Jeeps and on them when going to a 35" tire you would want to regear with 488s. 33" would be geared with 456s or could get away with 410s. Not 100% sure if the same applies to our Tacos
Old 08-16-2011, 05:31 PM   #5
rcfreak201 is one of the sharper tools in the shedrcfreak201 is one of the sharper tools in the shedrcfreak201 is one of the sharper tools in the shedrcfreak201 is one of the sharper tools in the shedrcfreak201 is one of the sharper tools in the shedrcfreak201 is one of the sharper tools in the shedrcfreak201 is one of the sharper tools in the shedrcfreak201 is one of the sharper tools in the shedrcfreak201 is one of the sharper tools in the shedrcfreak201 is one of the sharper tools in the shedrcfreak201 is one of the sharper tools in the shed
rcfreak201's Avatar
rcfreak201's Tacoma Gallery
im running 35s with 4.88s and i love it, i had 33s with the gears and it was revving pretty high but with the 35s it dropped a bit and its perfect, i say either 4.56 or 4.88s
Old 08-16-2011, 07:28 PM   #6
How is your bottom end with those gears?
Is there anything lower i could do for more bottom end?
Old 08-16-2011, 07:32 PM   #7
mall crawler
Rebel Taco 22 is one of the sharper tools in the shedRebel Taco 22 is one of the sharper tools in the shedRebel Taco 22 is one of the sharper tools in the shedRebel Taco 22 is one of the sharper tools in the shedRebel Taco 22 is one of the sharper tools in the shedRebel Taco 22 is one of the sharper tools in the shedRebel Taco 22 is one of the sharper tools in the shedRebel Taco 22 is one of the sharper tools in the shedRebel Taco 22 is one of the sharper tools in the shedRebel Taco 22 is one of the sharper tools in the shedRebel Taco 22 is one of the sharper tools in the shed
Rebel Taco 22's Tacoma Gallery
4.88 is about as low as you want to go if you plan on keeping it on the highway. If I have a crawl bo by the time i regear i will go to 4.56
Old 08-16-2011, 08:48 PM   #8
This might be alot to ask, but is there any way you have an acceleration video of 0-60 or so with 488s, when i had 33s my truck was fast but now with 35s it lags big time.
Old 08-16-2011, 10:57 PM   #9
rcfreak201's Avatar
its pretty good, on the freeway prior to gearing i would give some gas and it would shift into 4th but now it stays in 5th and still moves
if i come out to gorman i can give you a ride and we can do some 0-60 runs, something is wrong with my truck for sure, its not as quick as it used to be since i went to el mirage and the rear end vibrates weirdly when i take off hard but its still pretty quick, still peels out when i step on it
Old 08-16-2011, 11:06 PM   #10
Banned
97yota4wd is one of the sharper tools in the shed97yota4wd is one of the sharper tools in the shed97yota4wd is one of the sharper tools in the shed97yota4wd is one of the sharper tools in the shed97yota4wd is one of the sharper tools in the shed97yota4wd is one of the sharper tools in the shed97yota4wd is one of the sharper tools in the shed97yota4wd is one of the sharper tools in the shed97yota4wd is one of the sharper tools in the shed97yota4wd is one of the sharper tools in the shed97yota4wd is one of the sharper tools in the shed
97yota4wd's Tacoma Gallery
with 35s you will want 4.88s as said above
Old 08-17-2011, 12:53 PM   #11
well that sounds great hopefully you can make it out, i know the 3.4 isnt as quick as the 4.0 but i want some of my power back
Old 08-17-2011, 03:13 PM   #12
How much would 4.88s with install cost on a 2wd truck?
Old 08-17-2011, 03:14 PM   #13
Banned
call around, it varies
Old 08-17-2011, 03:24 PM   #14
rcfreak201's Avatar
around 250 for gears and another 2-300 for install, depends on the shop
Old 01-13-2015, 04:58 PM   #15
BlackedOutTacoma8 is on a distinguished road
BlackedOutTacoma8's Tacoma Gallery
Where do you find cheap gears like this?
Need Advice on 6inch and 35 inch tire TacomaMtnMan Suspension 22 09-27-2014 03:09 AM
3 inch lift with 35's???? francis1291 Suspension 38 10-13-2011 10:03 PM
New member that wants 6 inch with 35's!! TotheMAX 4 Cylinder 21 09-19-2011 10:35 PM
Do I need to regear with a 3inch lift and 33 inch tires? anasseef 2nd Gen. Tacomas 3 05-27-2011 08:43 PM
2TR w/33's and regear/no regear info wanted 08pretaco 4 Cylinder 147 01-29-2011 03:01 PM
