Truck of the Month April 2013: Spoonman's 2006 SuperWhite Long Travel Tacoma
All (4) O2 sensors replaced. Still have check engine light
Old 09-01-2011, 07:25 AM   #1
surfsupl [OP] surfsupl is online now
surfsupl is one of the sharper tools in the shedsurfsupl is one of the sharper tools in the shedsurfsupl is one of the sharper tools in the shedsurfsupl is one of the sharper tools in the shedsurfsupl is one of the sharper tools in the shedsurfsupl is one of the sharper tools in the shedsurfsupl is one of the sharper tools in the shedsurfsupl is one of the sharper tools in the shedsurfsupl is one of the sharper tools in the shedsurfsupl is one of the sharper tools in the shedsurfsupl is one of the sharper tools in the shed
surfsupl's Avatar
surfsupl's Tacoma Gallery
Like the title sais^^^^^^^^^^^^^
Codes P0031 & P0051
I have also checked and its the A/F heater relay and its good.. Any suggestions?
Old 09-01-2011, 05:35 PM   #2
surfsupl's Avatar
No one?
Old 09-01-2011, 05:40 PM   #3
Roll Tide
HondaGM is one of the sharper tools in the shedHondaGM is one of the sharper tools in the shedHondaGM is one of the sharper tools in the shedHondaGM is one of the sharper tools in the shedHondaGM is one of the sharper tools in the shedHondaGM is one of the sharper tools in the shedHondaGM is one of the sharper tools in the shedHondaGM is one of the sharper tools in the shedHondaGM is one of the sharper tools in the shedHondaGM is one of the sharper tools in the shedHondaGM is one of the sharper tools in the shed
HondaGM's Avatar
HondaGM's Tacoma Gallery
fuses?
__________________
Old 09-01-2011, 05:43 PM   #4
5th. It's where the magic happens.
Steves104x4 is one of the sharper tools in the shedSteves104x4 is one of the sharper tools in the shedSteves104x4 is one of the sharper tools in the shedSteves104x4 is one of the sharper tools in the shedSteves104x4 is one of the sharper tools in the shedSteves104x4 is one of the sharper tools in the shedSteves104x4 is one of the sharper tools in the shedSteves104x4 is one of the sharper tools in the shedSteves104x4 is one of the sharper tools in the shedSteves104x4 is one of the sharper tools in the shedSteves104x4 is one of the sharper tools in the shed
Steves104x4's Avatar
Steves104x4's Tacoma Gallery
I'm sure you did but I'll ask anyway; you disconnected the battery to reset the codes?
Check fuses.
Check the wiring running to the sensors that an animal hasn't eaten your wiring for dinner.
Check for pinched or burned wiring especially around the EGR Valve or anywhere that gets hot.
Check ground wires that connect to frame.
__________________
Old 09-01-2011, 05:55 PM   #5
This is my derpawayinator!!!!!
NelsonTacoma is one of the sharper tools in the shedNelsonTacoma is one of the sharper tools in the shedNelsonTacoma is one of the sharper tools in the shedNelsonTacoma is one of the sharper tools in the shedNelsonTacoma is one of the sharper tools in the shedNelsonTacoma is one of the sharper tools in the shedNelsonTacoma is one of the sharper tools in the shedNelsonTacoma is one of the sharper tools in the shedNelsonTacoma is one of the sharper tools in the shedNelsonTacoma is one of the sharper tools in the shedNelsonTacoma is one of the sharper tools in the shed
NelsonTacoma's Avatar
NelsonTacoma's Tacoma Gallery
Originally Posted by Steves104x4 View Post
Check fuses.
This is exactly what I was going to say. According to my diagnostic flow chart, the only things that can cause these codes are bad wiring, bad o2 sensors, bad relay, or bad pcm. Since you've already replaced the o2 sensors and tested the relay, we know that's not the problem, so I'm guessing at a bad wire somewhere, cause I don't even want to think that it's the pcm. If you need help with the wiring diagrams or connector end diagrams let me know.
__________________
Old 09-02-2011, 11:55 AM   #6
surfsupl's Avatar
Check fuses.
Pretty much have done all mentioned above . As far as fuses are their any for these besides the relay?
Old 09-02-2011, 04:22 PM   #7
Have you actually ohm checked all the wires related to the o2 sensor system with a digital multimeter? Just because you inspected the wiring visually does not mean its not messed up somewhere inside that you can't physically see. I'll find a wiring diagram for you and post it up, maybe that can help you diagnose it a little better.
__________________
Old 09-02-2011, 04:27 PM   #8
:POOPCORN:
98tacoma27's Avatar
Marines:
98tacoma27's Tacoma Gallery
http://ncttora.com/fsm/05+/data/ilea...ta/0050015.pdf
I'd test the relay coil and contacts
__________________
Originally Posted by Martie View Post
I think it's going to be thick pastrami on rye with swiss, coleslaw, bacon, and russian dressing. .
That’s no reason to cry. One cries because one is sad. For example, I cry because others are stupid, and that makes me sad.
Old 09-02-2011, 04:36 PM   #9
__________________
Display Modes
Cat. concerter or O2 sensor causing check engine light Huntgrrl 1st Gen. Tacomas 31 12-13-2012 06:51 AM
Check Engine Light/O2 sensor?? 95TacoChick 1st Gen. Tacomas 47 09-15-2011 09:58 AM
Check Engine Light/O2 sensor?? 95TacoChick Technical Chat 0 08-20-2011 04:48 PM
Check engine light (maybe O2 senser) Huntr Pat 1st Gen. Tacomas 9 05-15-2011 02:41 PM
Check engine light not fixed by replacing o2 sensor?? sbvaughn88 Technical Chat 21 02-12-2009 05:14 PM
Copyright © 2013 Tacoma Forum
