96 Tacoma V6 Engine Quits
Old 05-22-2012, 07:11 PM   #1
nomadd [OP] nomadd is offline
nomadd is on a distinguished road
nomadd's Tacoma Gallery
Truck runs normal at 0 to45 mph with rpms below 2000. As soon as I accelerate with rpms over 2000 engine sputters and dies. After 2 or 3 minutes engine starts right up again and runs fine till I accelerate over 2000
+ rpms and then dies again. I took it out the other day and drove it 50+ miles, accelerating slowly,keeping rpms under 2000 and it ran normal,but as soon as I stepped on the gas to speed up it dies.
I appreciate any guesses
nomadd
Old 05-22-2012, 07:16 PM   #2
He is The STig
mick478 is one of the sharper tools in the shedmick478 is one of the sharper tools in the shedmick478 is one of the sharper tools in the shedmick478 is one of the sharper tools in the shedmick478 is one of the sharper tools in the shedmick478 is one of the sharper tools in the shedmick478 is one of the sharper tools in the shedmick478 is one of the sharper tools in the shedmick478 is one of the sharper tools in the shedmick478 is one of the sharper tools in the shedmick478 is one of the sharper tools in the shed
mick478's Avatar
mick478's Tacoma Gallery
well, could be a lot of things, for starters, any sheck engine lights? code could point, vaguely, in the proper direction. this could be anything from a broken vaccume line to a faulty fuel pump. If no cels, check fuel pressure at injectors, i hear 5-10psi will define a good pump from bad, thats all i got, good luck!
--bott
Old 05-22-2012, 07:17 PM   #3
He is The STig
mick478's Avatar
also, had a dude who has a rebaged s-10 who had a faulty maf sensor go bad, but hopefully that would throw a cel,
Old 05-22-2012, 07:19 PM   #4
Thermonuclear Protection
478DblSport is one of the sharper tools in the shed478DblSport is one of the sharper tools in the shed478DblSport is one of the sharper tools in the shed478DblSport is one of the sharper tools in the shed478DblSport is one of the sharper tools in the shed478DblSport is one of the sharper tools in the shed478DblSport is one of the sharper tools in the shed478DblSport is one of the sharper tools in the shed478DblSport is one of the sharper tools in the shed478DblSport is one of the sharper tools in the shed478DblSport is one of the sharper tools in the shed
478DblSport's Avatar
478DblSport's Tacoma Gallery
I once had an old truck that acted just like that. Starting with the easiest remedy, I replaced the inline fuel filter and it ran fine afterwards. Good luck!
Old 05-22-2012, 07:21 PM   #5
He is The STig
mick478's Avatar
Clogged fuel filter or injectors also
Old 05-22-2012, 07:39 PM   #6
I had a cel a couple of times when it started to die and I stepped on the gas. It died anyway. After a couple of minutes it started. I cleared the cel and it stayed off. I thougth cel came on because I had drowned the engine.
Thanks for your quesses
Old 05-22-2012, 07:42 PM   #7
He is The STig
mick478's Avatar
hook it up to one of them doodads that reads the zeros and ones, and see if the code is still stored, worth a shott
Old 05-22-2012, 07:58 PM   #8
Tor-nication
Torspd is one of the sharper tools in the shedTorspd is one of the sharper tools in the shedTorspd is one of the sharper tools in the shedTorspd is one of the sharper tools in the shedTorspd is one of the sharper tools in the shedTorspd is one of the sharper tools in the shedTorspd is one of the sharper tools in the shedTorspd is one of the sharper tools in the shedTorspd is one of the sharper tools in the shedTorspd is one of the sharper tools in the shedTorspd is one of the sharper tools in the shed
Torspd's Tacoma Gallery
If you have a ScangaugeII or Ultra Gauge, use that to see if you have any codes. I doubt that you have codes, and or have either of those gauges. Other wise, stop by Autozone, and ask them to check and see if you have any codes.
Next, how many miles do you have on your truck? When is the last time that you replaced the fuel filter?
When is the last time that you changed your oil and spark plugs?
Old 05-23-2012, 07:40 AM   #9
I blew fuel filter out with air. It didn't seem to be plugged. Oil is new. Spark plugs are 7 yrs. old . I have 172,000 miles on it. O'Riellys checked battery and alternator. Thy're ok. I'll try new plugs and fuel filter.
Old 05-26-2012, 08:43 AM   #11
A new fuel filter seems to have solved my problem.
thanks again!
nomadd
'96 Tacoma 4x4, 5 speed, v6, 286k, One Owner - $5,000 MachineGun 1st Gen Tacoma Marketplace 2 02-13-2012 06:38 AM
Wanted: 96-99 Tacoma Ext Cab 4x4 V6 edcanfield Buy / Sell / Trade 3 04-06-2010 04:31 PM
96 tacoma engine ticks now.. wildjerseyfirefighter 1st Gen. Tacomas 31 12-31-2009 01:16 PM
