PLX gauge install
Old 11-15-2012, 07:15 PM   #1
jarhead0313 is on a distinguished road
Marines: 3rd LAR 0313
jarhead0313's Tacoma Gallery
PLX gauge install
So I just got my plx gauges in the mail today and was looking for suggestions on where to get my power from and where to mount the modules in the engine compartment.
Old 11-15-2012, 07:26 PM   #3
Originally Posted by Casey05Taco View Post
Casey I saw that install but I am installing afr and boost gauges and would like to just run wires from the engine compartment to the gauge. If I do it the other way I will have to run wires both ways...from the cab to the engine compartment and vice virsa.
Old 11-15-2012, 07:38 PM   #4
Casey05Taco has a brilliant futureCasey05Taco has a brilliant futureCasey05Taco has a brilliant futureCasey05Taco has a brilliant futureCasey05Taco has a brilliant futureCasey05Taco has a brilliant futureCasey05Taco has a brilliant futureCasey05Taco has a brilliant futureCasey05Taco has a brilliant futureCasey05Taco has a brilliant futureCasey05Taco has a brilliant future
Casey05Taco's Avatar
Casey05Taco's Tacoma Gallery
ahh ok, just searched and found that so figured id throw it your way. I dont really have an answer, but heres another bump for ya to get some answer.
Old 11-16-2012, 09:26 AM   #5
Is anyone running plx gauges with afr or boost?
Old 11-18-2012, 03:17 PM   #6
DOUBLEJTACOMA is on a distinguished road
DOUBLEJTACOMA's Tacoma Gallery
I would also appreciate some info on this. My concern is where to locate the sensor modules. I will be doing an afr gauge and and dm6 obdii. 2 gauges 2 modules.
Old 11-19-2012, 12:21 PM   #7
It was suggested for me to put my modules under my seat. I was thinking in the engine compartment but that is probably not a good idea because of moisture and dust. So I am in progress of installing under the drivers seat. I was using an add a fuse to power them but I could smell something funny so I have to figure another route. Hate to burn anything up. I might just run it strait to the battery and add a switch...but I hate to do that cause if I forget my battery my go dead.
Any ideas or suggestions?
Old 11-19-2012, 05:22 PM   #8
I think add a fuse would be the way to go. One thing I'm considering is having them being hooked up to the driving light circuit, so that I would be able to have them on only when I wanted. I have a pretty short commute to work and I have a feeling these gauges have a somewhat lengthy boot time (if they are anything like my Kenwood headunit). Maybe not want to power then up just to power then down all the time. Maybe this will work for you as I believe that circuit gets cut when the key is removed. My driving lights do for sure
Old 11-19-2012, 07:49 PM   #9
Dave M is a jewel in the roughDave M is a jewel in the roughDave M is a jewel in the rough
Dave M's Tacoma Gallery
Hey fellas,
So I installed my gauges (dm-6, dm-100, obd II module, A/F module, Boost module), completely, only to find that mine were DOA. I'll do a real write up when I re-install this weekend. Here's the quick version.
I ran my modules under the driver's seat. The reason is that the only wires that went through my firewall and into the engine bay were the wideband sensor and 1/8" vacuum line. I pulled power from all 3 modules by using an add-a-circuit on the 15 amp ignition circuit. I put a 15 amp fuse on the new circuit since I was running 3 modules (5 amps each). I ran the power wires through the center console and under the seat. My ground was done under the seat as well. I ran my grey wire on my A/F (the narrow-band feed) to the ecu through the center console, under the passenger side carpet, and down the passenger trim to splice into the ECU. If you need the pinout for the 2012, let me know and I'll get it to you. I'll post up once I do my real write up.
Old 11-19-2012, 09:41 PM   #10
Originally Posted by Dave M View Post
Hey fellas,
Pic please of your add a circut config
Old 11-19-2012, 10:06 PM   #11
Hey fellas,
What would be the benifit of running the wire to the ECU?
Old 11-20-2012, 04:45 PM   #12
See pics:
View at the fuse box, notice the add a circuit in the top left
Add a circuit removed.
The grey wire gives a narrowband feed from the new sensor to the ECU, which means the ECU still functions like normal, no check engine codes or strange running conditions.
My gauges came back from PLX today. The following was done:
Reflash of the DM-100 module firmware
Replacement of DM-6 Screen
Replacement of Vac-Boost Module
A/F module: No change
I'll be installing them again this weekend. I'll make sure I document it and I'll do a write-up for you guys.
Old 11-20-2012, 05:44 PM   #13
See pics:
Thanks for the pics. Quick question...did you just splice all three power wires onto the add a circuit without individual 5 amp fuses?
Old 11-20-2012, 05:50 PM   #14
See pics:
I see why you needed to do the wire to the ecu, I have dtlt headers witch have an extra bung in each long tube for wideband, so I don't need to run the wire to my ecu...I was confunsed on that one(happens often)
Thanks for the help, I will wire it all up tonight , tommorw off to get a dyno.
Old 11-20-2012, 05:53 PM   #15
Yes, I spliced the three together without individual fuses, probably not the most correct way to do it, but 3 separate fuse holders would be a pain in the ass.
I read somewhere that you could power up to 3 modules off the same power source. Just an FYI.
Old 11-20-2012, 06:03 PM   #16
Thanks Dave,
Install tonight, just hope my boost gauge not working was a error on my configuration.
Old 11-20-2012, 06:17 PM   #17
Thanks Dave,
Me too man, mine was replaced due to bad readings being sent. Even if it powers up, make sure that the numbers it displays are realistic, I want to say mine was showing like 14 psi vacuum at idle or something. Good luck! I'm watching your thread for the new dyno numbers.
Old 11-21-2012, 05:14 PM   #18
So I got it all in last night. Looks like my configuration was wrong before. This time it worked just fine! Thanks Dave for all your help. On a side note I ended up having to run a ground to my battery because I couldn't get it to ground properly in the cab. I would be driving and they would lose the connection with the modules... all better now.
PLX gauge install-20121121_035715.jpg   PLX gauge install-20121121_035859.jpg   PLX gauge install-20121121_055113.jpg   PLX gauge install-20121121_055147.jpg
Old 11-24-2012, 05:02 PM   #19
I was able to ground mine to the cab, but I sanded a patch down to bare metal and secured with a sheet metal screw and washer.
I started my install, but I need to clean it up next time I go out to my storage unit. Will post info.
Pro-tip: if you have to run the A/F sensor cable through the firewall, remove the pins from the plastic connector, it makes running that cable 100x easier. I did it with a couple of bent staples.
Old 11-26-2012, 07:10 PM   #20
Dave,
Post up some pics!
Installed a PLX gauge SpaceMonkey 2nd Gen. Tacomas 14 03-11-2013 10:44 PM
Better than ScanGauge! WTT: PLX Kiwi *WiFi* dongle for PLX Kiwi *Bluetooth* dongle Mach375 Buy / Sell / Trade 13 12-29-2012 07:51 AM
PLX Kiwi vs Scan Gauge WV150 2nd Gen. Tacomas 4 01-08-2012 01:06 AM
PLX Gauge Shroud & Flexpod Not Compatible SManZ Performance and Tuning 0 07-02-2010 09:50 PM
PLX gauge. virgilus11 Performance and Tuning 4 01-19-2010 05:44 AM
