no pipes/straight pipe does damage???
Old 02-02-2013, 11:22 AM   #21
UNDEAD1153 is a splendid one to beholdUNDEAD1153 is a splendid one to beholdUNDEAD1153 is a splendid one to beholdUNDEAD1153 is a splendid one to beholdUNDEAD1153 is a splendid one to beholdUNDEAD1153 is a splendid one to beholdUNDEAD1153 is a splendid one to beholdUNDEAD1153 is a splendid one to behold
UNDEAD1153's Avatar
UNDEAD1153's Tacoma Gallery
I know I may get flamed for this but I'm running all 4 cats and no muffler with a custom Y-pipe out to dual 3.5" tips. Sounds good in my, and my friends opinions. Just got it routed to duals yesterday so I'm hoping once it breaks in a little it'll get deeper in tone. My buddy has a 2001 v6 Tacoma with no muffler ran out before the rear tire and it honestly sounds like a small v8. I love it, as well as most people that hear it. His is pretty loud while mine on the other hand is not loud at all (IMO). I felt a loss of HP at first but now it seems to have gained it back. If you want to see what it sounds like no muffler, just unbolt it at the cat back flange. It's fairly loud with it exiting under the truck but when you exit it anywhere else, it's not that loud in the cab at all. Let me know if you have any questions.
Old 02-02-2013, 05:40 PM   #22
AirForceTacoma08 is on a distinguished road
AirForceTacoma08's Avatar
Air Force: 2 MXS
AirForceTacoma08's Tacoma Gallery
do u smell the exhaust in the cab real bad?? or is the smell noticeable??
Old 02-02-2013, 05:57 PM   #23
drinking whats on sale
92dlxman is one of the sharper tools in the shed92dlxman is one of the sharper tools in the shed92dlxman is one of the sharper tools in the shed92dlxman is one of the sharper tools in the shed92dlxman is one of the sharper tools in the shed92dlxman is one of the sharper tools in the shed92dlxman is one of the sharper tools in the shed92dlxman is one of the sharper tools in the shed92dlxman is one of the sharper tools in the shed92dlxman is one of the sharper tools in the shed92dlxman is one of the sharper tools in the shed
92dlxman's Avatar
92dlxman's Tacoma Gallery
you wouldn't notice it driving, but idling, your going to get some. guaranteed.
never dump exhuast under cab with any dd vehicle. just not a good idea.
i (without any first hand experience) doubt that headers will help you much at all. save some money, and just cut the factory muffler off and replace it with something you like. run some tailpipe to dump in a concealed location under the bed.
most brap for your buck
Old 02-02-2013, 07:30 PM   #24
UNDEAD1153's Avatar
Don't smell any now, didn't when I had it under the cab.
Old 02-02-2013, 07:44 PM   #25
Pavement Princess
Warputer is one of the sharper tools in the shedWarputer is one of the sharper tools in the shedWarputer is one of the sharper tools in the shedWarputer is one of the sharper tools in the shedWarputer is one of the sharper tools in the shedWarputer is one of the sharper tools in the shedWarputer is one of the sharper tools in the shedWarputer is one of the sharper tools in the shedWarputer is one of the sharper tools in the shedWarputer is one of the sharper tools in the shedWarputer is one of the sharper tools in the shed
Warputer's Avatar
Army: The Big Red 1 - vet sense 93
Warputer's Tacoma Gallery
I have somewhat of the same set up.....except mine is turned down at the rear axle.
Old 02-02-2013, 07:45 PM   #26
UNDEAD1153's Avatar
If only I had the same lift and tires you had!
Old 02-02-2013, 07:47 PM   #27
Pavement Princess
Warputer's Avatar
Yours looks pretty badass as is Weston!
Old 02-02-2013, 07:51 PM   #28
UNDEAD1153's Avatar
Thanks man! but I'm workin for a 6" lift, wheels, 35's, and re-gear at the moment. Itll be a while
Old 02-02-2013, 08:26 PM   #29
Rich91710's Avatar
Rich91710's Tacoma Gallery
Originally Posted by chris4x4 View Post
Shoudlnt hurt the valves, but power would suffer greatly, as there would be no scavenging affect.
I was referring to NO headers or manifold... just open exhaust ports.
That'll warp valves.
People have run open long tube headers on hot rods for a couple of generations and it's not damaging.
Hey, sometimes life gets in the way of life. When you had plenty of spare time, you were able to put together some very informative projects.
Now you're entertaining as hell
Old 02-02-2013, 08:26 PM   #30
Rich91710's Avatar
Carbon monoxide has no smell.
Old 02-02-2013, 08:35 PM   #31
Rich91710's Avatar
Originally Posted by Rackster View Post
It's my understanding that having some backpressure (e.g. cat restriction) causes the pulses of exhaust to blend, improve flow (syphoning), and low end torque. Is this incorrect?
Two different things.
Scavenging is when the length of the header tubes cause the exhaust pulses to align and an outgoing pulse into the header collector (expanding diameter) assists in drawing the following pulse out.
Backpressure is in a 2-stroke tuned exhaust.
The exhaust stroke is also the intake stroke... the exhaust scavenges some of the fresh intake charge out into the header. In a properly tuned system, just as the piston is about to close the port, a reversion wave comes back up the header and "slams" that extracted fresh charge back into the cylinder.
It's called being "on the pipe"
Both of these aspects cover a fairly narrow RPM range, and for our engines, the impact of scavenging is negligible.
Even top-fuel dragsters run open straight pipes... no scavenging at all.
Old 02-02-2013, 10:32 PM   #32
chris4x4's Avatar
chris4x4's Tacoma Gallery
Scavenging plays a large roll in 4 stroke NA engines. Top fuel dragsters are FI, and any time you force air into an engine, you dont need to worry about the scavenging affects. the reason variable valve timing is so affective in a 4 stroke engine, is that it allows different scavenging characteristics at various RPM's.
Old 02-03-2013, 02:12 PM   #33
Rackster is a splendid one to beholdRackster is a splendid one to beholdRackster is a splendid one to beholdRackster is a splendid one to beholdRackster is a splendid one to beholdRackster is a splendid one to beholdRackster is a splendid one to behold
Rackster's Tacoma Gallery
Thanks for the explanation guys. Also - seconding the motion on the CO being odorless. CO is a silent killer, so as noted by a few here, exit the exhaust in a safe location. Better safe than sorry.
4 cyl straight pipes/ no muffler? 1da4 4 Cylinder 7 01-06-2013 07:49 PM
Tacoma Straight Pipes (pulling the cats baby!!) Jeffman1991 2nd Gen. Tacomas 36 08-13-2011 12:10 PM
Straight pipe! Forster46 4 Cylinder 3 10-11-2010 04:49 PM
Straight pipe toytaco85 4 Cylinder 7 06-18-2009 01:56 PM
straight pipes? kris219 Performance and Tuning 16 10-06-2008 06:53 PM
