4.0 throttle body specs?...
Old 08-21-2013, 12:39 PM   #21
tooter [OP] tooter is offline
play every day
tooter's Avatar
Army: CH47 Chinook mechanic
tooter's Tacoma Gallery
Originally Posted by lemon177 View Post
you could always up the compression
I actually like that the engine runs fine on cheap regular 87 octane gas, and already gets excellent gas mileage. So it doesn't make any sense to go through the considerable expense of tearing the engine apart to mill the head, or replace pistons, and then to be stuck with an engine that only runs on more expensive premium gas.
The throttle body only meters air, so running one with a larger bore and butterfly just makes the throttle more responsive.
Old 08-30-2013, 08:08 AM   #22
colby8100 is on a distinguished road
colby8100's Tacoma Gallery
Nitrous=more compression
Old 08-30-2013, 09:16 AM   #23
play every day
tooter's Avatar
Yeah, it does. But I'm speaking within the practical context of normal day to day driving.
Still haven't made it out to the wrecking yard (going to the dyno shop today ), but I highly suspect that the 4.0 throttle body bolt pattern is 65mm square just because so many other Toyota throttle bodies are also square.
Old 08-30-2013, 09:47 AM   #24
lemon177 is on a distinguished road
lemon177's Avatar
lemon177's Tacoma Gallery
Im getting 9.6cr from my searches, which leads me to say you've got lots of room for improvement there. I used to run 87octane on a 12.8cr daily driver with a conservative tune. It'll wake up the entire rpm range. It does sound like a hassle to do but like you mentioned, milling the head wouldn't be too bad. Maybe pick up a spare head at the autowreckers
Old 08-30-2013, 09:58 AM   #25
nfs257 is one of the sharper tools in the shednfs257 is one of the sharper tools in the shednfs257 is one of the sharper tools in the shednfs257 is one of the sharper tools in the shednfs257 is one of the sharper tools in the shednfs257 is one of the sharper tools in the shednfs257 is one of the sharper tools in the shednfs257 is one of the sharper tools in the shednfs257 is one of the sharper tools in the shednfs257 is one of the sharper tools in the shednfs257 is one of the sharper tools in the shed
nfs257's Avatar
Navy: GSM1
nfs257's Tacoma Gallery
not sure if this was mentioned, but URD has a tb conversion for the 4.0 in our trucks to mount the slightly larger tb found on the newer 1gre's with dual vvti in the fj/4runner. if you could get in contact with them im sure theyll have numbers and pix for you
Benefits from this?
Old 08-30-2013, 01:11 PM   #26
lemon177's Avatar
Raising the compression ratio or larger throttle body?
As op said, bigger diameter(with some exceptions) will allow more air to flow at pretty much all throttle positions and should give you gains.
Raises cr will create a more compact explosion to happen in the chamber and push the pistons down harder(in a nutshell).
While one thing alone may not show drastic results, everything working together will provide great results.
Old 08-30-2013, 01:34 PM   #27
nfs257's Avatar
Navy: GSM1
Sorry that ^^^^ was what I was asking.
Anyone ever seen this on their throttle body, why??? mr.mike8525 2nd Gen. Tacomas 9 06-22-2013 01:06 AM
throttle body torque specs? rs5 2nd Gen. Tacomas 2 11-24-2012 05:17 PM
throttle body?? xnanner Performance and Tuning 7 07-24-2011 02:39 PM
Throttle Body 2006_TOY_TACO 2nd Gen. Tacomas 3 09-04-2010 05:55 PM
throttle body Blaise22 2nd Gen. Tacomas 2 07-04-2010 04:46 PM
