S/C Coolant Pumps
Old 08-27-2013, 10:15 AM   #1
KingKoda [OP] KingKoda is offline
Never Satisfied
KingKoda is one of the sharper tools in the shedKingKoda is one of the sharper tools in the shedKingKoda is one of the sharper tools in the shedKingKoda is one of the sharper tools in the shedKingKoda is one of the sharper tools in the shedKingKoda is one of the sharper tools in the shedKingKoda is one of the sharper tools in the shedKingKoda is one of the sharper tools in the shedKingKoda is one of the sharper tools in the shedKingKoda is one of the sharper tools in the shedKingKoda is one of the sharper tools in the shed
KingKoda's Tacoma Gallery
S/C Coolant Pumps
Some of you may or may not have this situation - when my truck is off, after an unspecified amount of time the S/C coolant pumps come on. I am under the assumption from reading other posts that this is due to the S/C pump wiring being connected to the Fuel Pump circuit; and since the ECM will activate the Fuel Pump when the truck is off at times for testing that this causes the S/C coolant pumps to activate as well during the self tests.
It's not a big deal and I only notice occasionally when in the garage that my truck is "alive" by the whirring sound of the S/C pumps coming on randomly.
So I happened to be looking at the main fuse block in the engine compartment and I am assuming (bad) but need clarification that the yellow wire in my photos is that of the S/C pumps/etc being connected to the EFI 10A fuse.
What I am thinking is if the empty fuse slot above the EFI fuse is an option that if I put a 10A fuse there and change the yellow wire to run off of that if it will put an end to my S/C coolant pumps randomly coming alive when the fuel system self tests.
I plan on testing this out, but if there is someone that knows I absolutely should not, speak up. I am planning to add a 10A fuse the to black slot where the green arrow is.
My concern is also that, in changing this yellow wire to the empty 10A circut that the pumps will not function properly while the truck is running resulting in an overheat situation with the S/C.
Yay or Nay?
Old 08-27-2013, 06:35 PM   #2
Fortified with horsepower-adding goodness...
WHPLSH3 is one of the sharper tools in the shedWHPLSH3 is one of the sharper tools in the shedWHPLSH3 is one of the sharper tools in the shedWHPLSH3 is one of the sharper tools in the shedWHPLSH3 is one of the sharper tools in the shedWHPLSH3 is one of the sharper tools in the shedWHPLSH3 is one of the sharper tools in the shedWHPLSH3 is one of the sharper tools in the shedWHPLSH3 is one of the sharper tools in the shedWHPLSH3 is one of the sharper tools in the shedWHPLSH3 is one of the sharper tools in the shed
WHPLSH3's Avatar
WHPLSH3's Tacoma Gallery
I'd leave it. Toyota specified the fuel pump fuse for a reason... probably, so if the pump screws up, it'll blow the fuse & the truck will stall so you don't hurt it by filling it with hot compressed air (detonation, melted pistons...)
It's not like it'll kill the battery- mine only ever runs for 1 minute max (probably a lot less, actually)
Old 08-28-2013, 07:57 AM   #3
Never Satisfied
I'm probably going to err on the side of caution then and leave it as it was installed.
Old 08-30-2013, 05:53 AM   #4
colby8100 is on a distinguished road
colby8100's Tacoma Gallery
If your that worried about it you could unhook it. Then use a fused power source to a new relay, then to the sc pump and install a switch wire to the relay (recommend using the key switch so your don't forget to cut it on) that way its only on when the truck is on/off when off. If its not killing the battery I wouldn't mess with it.
Old 09-01-2013, 09:13 AM   #5
Tor-nication
Torspd is one of the sharper tools in the shedTorspd is one of the sharper tools in the shedTorspd is one of the sharper tools in the shedTorspd is one of the sharper tools in the shedTorspd is one of the sharper tools in the shedTorspd is one of the sharper tools in the shedTorspd is one of the sharper tools in the shedTorspd is one of the sharper tools in the shedTorspd is one of the sharper tools in the shedTorspd is one of the sharper tools in the shedTorspd is one of the sharper tools in the shed
Torspd's Tacoma Gallery
Ford Lighting uses a similar pump. However, it is better. Also, if you inspect your pump closely, it might still have the "Ford" symbol on it. Earlier models did, while not sure if the later models do. They pumps on the TRD s/c have been known to stop pumping, even though they are energized. Some just plain stop working.
Even though it is off topic, since you mentioned the pump, I figure it relevant for you in the possible future. .
Old 09-01-2013, 10:38 AM   #6
mike92y has a brilliant futuremike92y has a brilliant futuremike92y has a brilliant futuremike92y has a brilliant futuremike92y has a brilliant futuremike92y has a brilliant futuremike92y has a brilliant futuremike92y has a brilliant futuremike92y has a brilliant futuremike92y has a brilliant futuremike92y has a brilliant future
Army: SFC,  19 years, 5 to go.
mike92y's Tacoma Gallery
Thanks, I was wondering about that. My pump is still working but the sound of it pumping has changed since it was new and I really think offroading is a little rough on it, bouncing around and all.
Belts, chains and water pumps... silvertrd09 Technical Chat 8 06-09-2013 09:20 AM
fuel offroad pumps mason Wheels & Tires 8 03-07-2013 02:31 PM
Compressor or pumps noise after being off for hours... Jholder70 2nd Gen. Tacomas 5 01-04-2013 01:25 PM
How many pumps of grease for the slip-yolk? Glenn54 1st Gen. Tacomas 9 09-15-2012 04:34 PM
Spotted this at the pumps on the way home. Matic General Automotive 19 09-24-2010 10:51 PM
