oil catch can
Old 01-25-2014, 04:15 PM   #1
Bam-Ba-Lam
Detective_Dan is one of the sharper tools in the shedDetective_Dan is one of the sharper tools in the shedDetective_Dan is one of the sharper tools in the shedDetective_Dan is one of the sharper tools in the shedDetective_Dan is one of the sharper tools in the shedDetective_Dan is one of the sharper tools in the shedDetective_Dan is one of the sharper tools in the shedDetective_Dan is one of the sharper tools in the shedDetective_Dan is one of the sharper tools in the shedDetective_Dan is one of the sharper tools in the shedDetective_Dan is one of the sharper tools in the shed
Detective_Dan's Avatar
Air Force: SSgt - A.G.E. Mechanic
Detective_Dan's Tacoma Gallery
oil catch can
hey gents,
just finished installing my Add W1 oil catch can. i bought it off amazon, free 2 day shipping for $89 at my door. I ordered it on a Thursday evening and it was at my door at 10am on Saturday.
it seems to be pretty damn high quality. all machined aluminum parts, with 15mm and 9mm fittings. i used the 9mm fittings and bought 8ft of 7/16" fuel line because the line that comes with it is kinda shitty.
just a fore-warning to those of you who cant tell from the pictures; no, i dont have massive hands, this can is just pretty tiny. even though it is small, there is no need to worry because the amount that i caught over a 5000 mile period can be held in the reservoir with room to spare.
whats in the box? everything you need (unless you want different line like i did)
the can even has a sealed dipstick so you can check the oil level without having to unscrew the whole can.
i put an o-ring on the dipstick just to re-assure myself that it is sealed, so bust out your handy dandy o-ring kit if you have one
i mounted it above the driver wheel well behind the battery. also, make sure you use teflon tape to seal the tube fittings on the can
then remove your PCV, run your lines and hose clamp them. FROM engine goes to the inlet, TO intake goes on the outlet.
then start her up, and check for a seal and no CEL's.
you can hear the tight seal and vacuum when i pull out the dipstick
http://www.youtube.com/watch?v=0fMFJ...ature=youtu.be
ill update this thread every so often to show the amount of oil that has been caught
EDIT: 31 January 2014
after only 4 days and 100 miles of driving, it has caught about 3 tablespoons of oil. the unit has already paid for itself in my eyes
UPDATE as of 26 April 2014:
heres what ive got after 2,500 miles exactly. this is a normal sized nestle water bottle. (duct tape is on it so it doesnt leak because im moving lol)
UPDATE as of 30 June 2014
this is what ive got after 5000 miles on the dot. 16.9 fl oz water bottle
UPDATE: as of 14 Sep 2014
probably the last "oil amount" update ill do, as im sure you all get it by now.
10,000 miles on the dot, and heres what ive saved from being pushed back into the motor
Old 01-25-2014, 07:41 PM   #3
TXPRO4X4 is a glorious beacon of lightTXPRO4X4 is a glorious beacon of lightTXPRO4X4 is a glorious beacon of lightTXPRO4X4 is a glorious beacon of lightTXPRO4X4 is a glorious beacon of lightTXPRO4X4 is a glorious beacon of light
TXPRO4X4's Avatar
TXPRO4X4's Tacoma Gallery
Originally Posted by wing103 View Post
can you tell me what is it good for? better gas mileage?
it catches gases and oil vapor that is recirculated back into the intake. look for more threads at the bottom.
Old 01-25-2014, 08:11 PM   #4
Bam-Ba-Lam
It replaces your pcv hose. Positive crankcase ventilation. All of the blowby gases that would normally be injected back through your intake after the throttlebody, get trapped in the can, instead of being "burned off" by the motor. It causes gunk buildup in the motor so this prevents that from happening. You just empty it every few thousand miles or so
Old 01-25-2014, 08:47 PM   #5
Lord Helmet is one of the sharper tools in the shedLord Helmet is one of the sharper tools in the shedLord Helmet is one of the sharper tools in the shedLord Helmet is one of the sharper tools in the shedLord Helmet is one of the sharper tools in the shedLord Helmet is one of the sharper tools in the shedLord Helmet is one of the sharper tools in the shedLord Helmet is one of the sharper tools in the shedLord Helmet is one of the sharper tools in the shedLord Helmet is one of the sharper tools in the shedLord Helmet is one of the sharper tools in the shed
Lord Helmet's Avatar
Marines: 1st Mar Div
Lord Helmet's Tacoma Gallery
blow by gases. keeps the combustion chamber, throttle body, and maf clean
BTW nice write up Detective Dan, I plan to add the other one on the passenger side too
Old 01-26-2014, 05:43 AM   #6
resident Apple Pie Monster
Justus is one of the sharper tools in the shedJustus is one of the sharper tools in the shedJustus is one of the sharper tools in the shedJustus is one of the sharper tools in the shedJustus is one of the sharper tools in the shedJustus is one of the sharper tools in the shedJustus is one of the sharper tools in the shedJustus is one of the sharper tools in the shedJustus is one of the sharper tools in the shedJustus is one of the sharper tools in the shedJustus is one of the sharper tools in the shed
Justus's Avatar
Justus's Tacoma Gallery
Butterfly catcher
Old 01-26-2014, 11:24 AM   #8
Bam-Ba-Lam
i put a chunk of stainless steel scrub brush in the baffle so that the oil vapor has something to stick and condense to. no pic of it but you get the idea. the baffle unscrews so you can put whatever filter media you want in it.
Old 01-27-2014, 06:18 PM   #10
Bam-Ba-Lam
Originally Posted by Torspd View Post
Dang. That is a pretty nice piece. Good find Dan.
Thanks toe. For $89, I couldn't not give it a try. I've bought cans almost twice this much with equal or lesser build quality on them. You're basically paying for a name brand at that point
Old 01-27-2014, 06:22 PM   #11
Bam-Ba-Lam
I would absolutely recommend this can to anyone. Great quality at good price. Plus it doesn't have those shitty sight tubes or draincocks at the bottom that are prone to leaking
Old 01-29-2014, 06:36 PM   #12
Bam-Ba-Lam
after EXACTLY 100 miles of driving, i popped it open to check what has been collected. quite a bit for only 100 miles. cant wait to see what it will catch in the next few thousand
Old 02-06-2014, 12:20 AM   #13
RedLantern is on a distinguished road
RedLantern's Avatar
RedLantern's Tacoma Gallery
Nice one Dan. I think i have their older can on my truck. I have yet to see if it will collect anything once i get my truck back from the shop lol.
Old 02-06-2014, 07:03 AM   #14
Bam-Ba-Lam
Does the older model have the baffle to put mesh in? If so I recommend it. It's catching more now that the vapor has something to condense on.
Don't use anything really fibrous like steel wool. Really small stuff has the capabilities of breaking apart and going into your intake
Old 02-06-2014, 09:22 AM   #15
RedLantern's Avatar
no baffle..ill end up modifying it at work tho.
Old 02-12-2014, 11:14 AM   #16
BlackSportD has much to be proud ofBlackSportD has much to be proud ofBlackSportD has much to be proud ofBlackSportD has much to be proud ofBlackSportD has much to be proud ofBlackSportD has much to be proud ofBlackSportD has much to be proud ofBlackSportD has much to be proud ofBlackSportD has much to be proud of
Navy: EM1 Coastal Warfare
BlackSportD's Tacoma Gallery
Send a message via AIM to BlackSportD
Very good looking can, looks to catch very well too.
Googleing around, I can't find the actual companies home page or website... anyone have their homepage?
Old 02-12-2014, 01:32 PM   #17
Bam-Ba-Lam
this is the exact one i ordered from the exact same company. just make sure to get some new 7/16'ths fuel line because you need to use the smaller nipples with this can on our engines. + the hose that comes with it is crap
http://www.amazon.com/ADD-W1-Univers...+oil+catch+can
Old 02-12-2014, 02:23 PM   #18
I ask because I'm curious about the company itself. They seem to make air fuel gauges, HUDs etc, but I had never heard of them before and its now very interesting to me that I can't find any info on them.
Old 02-12-2014, 03:56 PM   #19
Bam-Ba-Lam
ive never heard of them before either, but im very impressed with the quality and finish of it for the price
Old 02-28-2014, 01:12 PM   #20
Sacrifice is one of the sharper tools in the shedSacrifice is one of the sharper tools in the shedSacrifice is one of the sharper tools in the shedSacrifice is one of the sharper tools in the shedSacrifice is one of the sharper tools in the shedSacrifice is one of the sharper tools in the shedSacrifice is one of the sharper tools in the shedSacrifice is one of the sharper tools in the shedSacrifice is one of the sharper tools in the shedSacrifice is one of the sharper tools in the shedSacrifice is one of the sharper tools in the shed
Sacrifice's Avatar
Sacrifice's Tacoma Gallery
oil catch can
Did you fab up a bracket for this? I see the two holes that are there from factory but I see you still used the two small bolts that came with the can? Just received mine today so hopefully installing it tomorrow.
Edit: saw there were nuts for those two, so I take it you just drilled two holes and then bolted through the fender wall?
Install an oil catch can!!!! fyremanpat 2nd Gen. Tacomas 21 01-22-2014 05:09 PM
Oil catch can surprise! ailll1 2nd Gen. Tacomas 14 11-17-2013 08:00 PM
DIY: Oil Catch Can mattgecko 2nd Gen. Tacomas 24 11-03-2012 03:40 PM
Oil Catch Can chaddawkins 4 Cylinder 6 11-01-2012 10:50 PM
Oil Catch Can Install.Need Help. black_magic2010 2nd Gen. Tacomas 35 10-19-2012 11:02 PM
