2.2" pulley with a TRD 7th?
Old 03-04-2014, 10:34 PM   #1
JoshBovaird is on a distinguished road
JoshBovaird's Tacoma Gallery
Im curious if i could run a 2.2 pulley on my 3.4 with the TRD 7th injector. And if possible what plugs should i be using. Im currently running dense IK20 and have the will be doing the plugs this week.
Old 03-04-2014, 10:57 PM   #2
NW4RUNNER is one of the sharper tools in the shedNW4RUNNER is one of the sharper tools in the shedNW4RUNNER is one of the sharper tools in the shedNW4RUNNER is one of the sharper tools in the shedNW4RUNNER is one of the sharper tools in the shedNW4RUNNER is one of the sharper tools in the shedNW4RUNNER is one of the sharper tools in the shedNW4RUNNER is one of the sharper tools in the shedNW4RUNNER is one of the sharper tools in the shedNW4RUNNER is one of the sharper tools in the shedNW4RUNNER is one of the sharper tools in the shed
NW4RUNNER's Avatar
NW4RUNNER's Tacoma Gallery
yes I think that is the most ideal set up. I am running the Iridium plugs that came with the 7th injector kit from URD. And URD sells the 2.2 pulley but I am still using the stock pulley.
Old 03-05-2014, 07:42 AM   #3
All the info i find is for the urd 7th
Old 03-05-2014, 02:49 PM   #4
joemauma has a brilliant futurejoemauma has a brilliant futurejoemauma has a brilliant futurejoemauma has a brilliant futurejoemauma has a brilliant futurejoemauma has a brilliant futurejoemauma has a brilliant futurejoemauma has a brilliant futurejoemauma has a brilliant futurejoemauma has a brilliant futurejoemauma has a brilliant future
joemauma's Tacoma Gallery
I'm running that same setup and everything seems happy.
Old 03-05-2014, 03:26 PM   #5
Do you have a wideband, and if so hows it look.
Old 03-05-2014, 08:14 PM   #6
NW4RUNNER's Avatar
Here is my setup. I have the stock pulley. I'm happy with my setup so I don't plan on upgrading. I'm running stock air box as that is what was recommended. Supercharger already runs super lean. With 7th injector it made everything perfect for me. No ping, plenty enough power.
Old 03-05-2014, 08:49 PM   #7
Yea I'm pretty much running the same setup. I planned on buying the URD 7th before I realized the truck had the TRD 7th. Anyone else running a URD 2.2" pulley with a TRD 7th?
Old 03-05-2014, 08:52 PM   #8
NW4RUNNER's Avatar
Looks like Joemauma is from that pic.
Old 03-05-2014, 10:40 PM   #9
Yea I seen his but he's the only one so far. I pulled one of my plugs while i have the truck stripped down and it has the denso K16TR11s in it. I know it says to run the IK20s and thats what the boxes i had from the original owner but inside the box and motor were the TR11s. I picked up some IK20s for it on my lunch break.
Old 03-14-2014, 02:51 PM   #10
hoenah808 will become famous soon enough
hoenah808's Tacoma Gallery
ik22 I believe and I ran the urd 7th kit stock pulley. go smaller pulley 7th injector kit and meth kit...should be cherry
Old 03-14-2014, 08:54 PM   #11
from Dirt bike to Dezert Couch
SDSam has much to be proud ofSDSam has much to be proud ofSDSam has much to be proud ofSDSam has much to be proud ofSDSam has much to be proud ofSDSam has much to be proud ofSDSam has much to be proud ofSDSam has much to be proud ofSDSam has much to be proud of
SDSam's Avatar
SDSam's Tacoma Gallery
URD 7th and 2.2 for the streets is a good set up, for the desert i think the stock pulley is plenty and probably safer.
and i run the 1st gen S/C and 2.2 now
Old 03-15-2014, 08:02 AM   #12
muffly20 is on a distinguished road
Army: 82nd
muffly20's Tacoma Gallery
can someone post a close up of the injector? i have an 03 that the guy before me installed a SC himself and did it all janky. don't think the 7inj is working properly.
Old 03-15-2014, 10:50 AM   #13
what makes you think its not working? ru running a wideband a/f?
Old 03-17-2014, 06:12 PM   #14
Army: 82nd
they had the wire for the injector spliced to the 4th cylinder. idk if they did that to get more fuel to it or if it wasn't working so they ran it to that.
Old 03-17-2014, 07:17 PM   #15
NW4RUNNER's Avatar
Mine is an 03 as well. Red hose in center is fuel line T'd from the high pressure fuel line on other side of motor. Wires at bottom are going through firewall to the URD ECU in second pic.
Old 03-23-2014, 12:24 PM   #16
is it the trd injector or urd? do you have the urd pcu unit?
Old 03-23-2014, 08:34 PM   #17
NW4RUNNER's Avatar
URD makes the 7th injector for the TRD supercharger. I do not know of another company that offers a 7th injector kit other than URD.
Old 03-23-2014, 09:23 PM   #18
SDSam's Avatar
there is TRD 7th kit and may or may not include a ECU re-flash by a dealer
Old 03-23-2014, 10:58 PM   #19
NW4RUNNER's Avatar
I know nothing of a TRD 7th injector for the 3.4L V6. The 3.4 does not have an ECU that you can flash. That is information I have been told at least. Sounds like you likely know more on the topic than I do. Just wondering if we are both talking about the 3.4 and not the 4.0 S/C.
Any links for info on the TRD 7th injector? I am guessing TRD does not make this any longer for the 3.4L.
Old 03-24-2014, 12:21 AM   #20
trd does have a 7th injector but I have no idea how its set up. I know that urd used to do a pcu with 6 bigger injector kit before the urd 7th came out...
3.4L Black TRD Supercharger, URD 7th kit, 2.2" pulley Ripcord 1st Gen Tacoma Marketplace 11 06-22-2013 08:38 PM
Used TRD Supercharger, URD 7th Injector kit, an URD 2.2" Pulley toyjunky 1st Gen Tacoma Marketplace 10 02-14-2013 08:45 PM
URD 2.825" Pulley for TRD S/C BradleyJ33 Performance and Tuning 47 12-09-2012 10:35 AM
Trd supercharger with 2.8" pulley 05tacoma33 2nd Gen Tacoma Marketplace 22 05-04-2012 01:14 AM
NST Overdrive Pulley set compared to URD 2.8" S/C pulley bcroach78 Performance and Tuning 0 05-13-2011 06:01 AM
