Little research help
Discussion in 'Performance and Tuning' started by JWP6114, May 25, 2014.
  1. May 25, 2014 at 9:18 PM
    JWP6114
    JWP6114 [OP] Well-Known Member
    Jake
    Newnan, GA
    2010 PreRunner SR5 supercharged
    TRD supercharger
    I have searched around a but and can't find any direction on one thing is like to address on my 2010 4.0 Super Charged Tacoma...
    I am not looking to raise the rev limiter hit I am looking to remove whatever causes it not to rev above 3500rpm well...
    Some times it will shoot up to 5k in neutral (auto trans) most of the time it is deprived by the ECU I imagine...is there. Simple fix to remove the engine acceleration limiter?
  2. May 29, 2014 at 4:39 AM
    JWP6114
    Jake
    Newnan, GA
    TRD supercharger
    Anyone?
  3. May 29, 2014 at 5:12 AM
    Bellis
    Bellis friggin rad
    Ben
    mass southshore
    pyrite 6-speed 2012 offroad
    driver mod
    not really sure what your saying here
  4. May 29, 2014 at 5:14 AM
    JWP6114
    Jake
    Newnan, GA
    TRD supercharger
    When I neutral if you attempt to rev the engine it seems sluggish to rise mostly. A lot if newer cars will not let you rev above 3000 or 3500 rpm while in neutral. Is there a way to remove this feature.
  5. May 29, 2014 at 6:13 AM
    Bellis
    Bellis friggin rad
    Ben
    mass southshore
    driver mod
    I have a manual so I don't really know, but I'm pretty sure Tacoma's don't have that feature.
  6. May 29, 2014 at 6:15 AM
    JWP6114
    Jake
    Newnan, GA
    TRD supercharger
    I'll post up a video soon... So your saying if you pin it to the floor it will bounce off the limiter... Not that I seeking this in any way... But most will electronically close the intake valve while at high rpm not under a load
  7. May 29, 2014 at 6:18 AM
    Bellis
    Bellis friggin rad
    Ben
    mass southshore
    driver mod
    yeah in my last one I used to bounce rev limiter like it was a race truck. it was an 09
  8. May 29, 2014 at 7:58 PM
    memario1214
    Colton
    Missoula, MT
    If I'm in neutral and slam the skinny pedal it'll go all the way to redline no hesitation all racetruck style as mentioned above...
  9. May 30, 2014 at 6:39 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Do you have any check engine lights?
    Do you have any idle problems, or vacuum leaks?
    If you have the 90L pedal reflash, which is mandatory on a TRD reflash, that should only take effect during wheel spin. As in trying to do a burn out.
  10. May 31, 2014 at 4:23 AM
    JWP6114
    Jake
    Newnan, GA
    TRD supercharger
    Torspd, thanks for the troubleshooting Q's. No CEL's. No idle problem or vac leaks I'm aware of. As far as the re flash, my SC was installed about a year ago so I'm not sure what software update it is.
    On to the next... I did install the 2.8" pulley and have not made any fuel system upgrades. Is it possible it's not getting fuel fast enough? I do have an afr gauge and don't notice it lean out.
  11. May 31, 2014 at 10:40 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Have you tired resetting the ecu by disconnected the battery? Just for shirts and giggles?
    You will have the 90L pedal reflash.
  12. May 31, 2014 at 10:48 AM
    memario1214
    Colton
    Missoula, MT
    Disconnecting my battery for "shits and giggles" has done pretty well to abolish some gremlins I was experiencing in the past. That's like my go to if I have something just a little bit off.
  13. Jun 1, 2014 at 3:34 AM
    JWP6114
    Jake
    Newnan, GA
    TRD supercharger
    Will do that
  14. Jun 1, 2014 at 5:02 AM
    Shadetree
    Shadetree Well-Known Member
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Locking Tailgate & Gas Cap and extra bed D-rings
    x2
