Warm Air Intake - suggestions
Discussion in 'Performance and Tuning' started by Annolino122, Jun 20, 2014.
  1. Jun 24, 2014 at 10:45 PM
    #41
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    Because its stock. Stock parts are super lame.
  2. Jun 25, 2014 at 10:07 AM
    #42
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    Although I have a 2.7 and not a 4.0, I do run a warm intake for better gas mileage...
    8a098052-48fe-43ec-a082-e93bd8aaf3e0_zps_432e7fed9e245571ffee1f2620ac3b05b5e88170.jpg
    ...and am pleased with the 23 mpg average even with a fully loaded service truck and a lot of third gear driving on rural roads. I'm not concerned with heat soak. Injectors mixing fuel into nice hot intake air is just fine with me. :)
    Greg
  3. Jul 4, 2014 at 12:04 AM
    #43
    98tacoma929
    98tacoma929 Well-Known Member
    Fort Worth, Texas
    98 Tacoma 3.4L SR5
    -In Order- Full Exhaust Cold Air Kit 3" Tuff Country Lift 285/75/16 Cooper Discoverer A/T3 20" Lightbar behind Grill Much More to go...
    If you actually buy a new one in the box, it comes with a dyno sheet proving the whp gain.
  4. Jul 4, 2014 at 12:09 AM
    #44
    memario1214
    Colton
    Missoula, MT
    "proving" :rolleyes: Yeah okay
  5. Jul 4, 2014 at 12:17 AM
    #45
    Annolino122
    Annolino122 [OP] Well-Known Member
    Evansville
    2014 Tacoma TRD off road
    They also don't prove your MAF will be messed up and that any off road and it's an oil lubed dirt catcher
  6. Jul 4, 2014 at 12:26 AM
    #46
    TacoMitch93
    TacoMitch93 Tasty Taco
    Mitch
    Nova Scotia, Canada eh
    09 Tacoma SR5
    I get 26 on average in mine, I do a lot of city driving, some highway. However my truck is never loaded.
    From a Power Engineering standpoint;
    You want the warmest air possible, air goes through air heaters and in big power plants is sucked from the top of the building (hot air rises because its less dense). The closer the combustion air is to the auto-ignition temperature (the temp. at which a given fuel will combust, I believe gasoline is something like 260 degrees C, don't hold me to that though) the more efficient the boiler will run because less energy in the form of heat (kJ, BTU, etc.) is wasted warming up the air in the furnace.
    That being said, you have an IC engine, I don't fully understand how the less dense air helps fuel efficiency, Doesn't the MAF adjust for the warmer temperatures?
    Like it was said before I would roll around with a light foot in a high gear.
    FYI
    The "prime" A/F ratio is 14.7:1 which is called stoichiometric. However, that runs too far too hot and causes burnt valves.
  7. Jul 4, 2014 at 2:28 AM
    #47
    Annolino122
    Evansville
    I'm not in school and don't wanna think about thermodynamics & heat transfer haha :( but the MAF reads the mass of the air. The colder the air, the more dense it is. Which means to keep the A/F ratio correct, it adds more fuel, which results in a "larger" combustion and creates more power. More fuel and power means worse gas mileage essentially. But seeing our trucks come stock with a factory CAI, a better CAI will produce more power but not really a lose in MPG.
    But tooter runs a WAI, so the warmer the air, the less dense it is. Which means it takes less fuel to get the correct ratio. Which less fuel is better fuel economy.
    At least that's my understanding
  8. Jul 4, 2014 at 8:25 AM
    #48
    tooter
    Greg
    Los Angeles
    I'm pretty sure mine would do about the same, as my 23 is with no freeway driving at all. It's also doing a lot of first gear on steep narrow winding canyon roads. Just about the worst driving conditions for gas mileage. So I'm happy with the mileage it gets for how its used. :)
    I'm an economy driver, and that's why my focus is only on low end torque in the 1,000-3,000 rpm range. The few times it gets floored is basically on the dyno or to make a video, and that's only for a few seconds, so I'm not really concerned.
    Greg
  9. Jul 4, 2014 at 8:28 AM
    #49
    tooter
    Greg
    Los Angeles
    There's also another gas mileage advantage to a warm air intake. The engine warms up faster and gets out of the fast idle rich mixture "choke" mode quicker. :)
    Greg
  10. Jul 4, 2014 at 8:30 AM
    #50
    TacoMitch93
    Mitch
    09 Tacoma SR5
    I however am not a economy driver (hehe). A lot of it probably depends on my route to work, I basically coast most of the way and I'm running it around 1900 RPM
    I really appreciate the detail you put into your posts!! It's helped me make future plans for my taco :)
  11. Jul 4, 2014 at 9:29 AM
    #51
    tooter
    Greg
    Los Angeles
    Thanks for your kind words, Mitch. :)
    I enjoy posting. It's way more fun than watching TV.
    Just some off topic trivia...
    I do a lot of coasting down steep narrow rural roads in first gear, and took careful note of exactly when the Deceleration Fuel Cut Off mode cuts in and out.
    As rpms rise, DFCO engages at 1,800 rpms, and as rpms fall it disengages at 1,400 rpms. So you want to coast above the 1,400 rpm threshold, even if it means shifting into a lower gear, so that the ECU doesn't turn on the idle fuel circuit. So in a situation where 5th gear coasting falls below 1,400 rpms, it's more economical to coast in 4th gear. ;)
    In terms of economy, DFCO is your friend, because while it's engaged, your gas mileage is infinite. :)
    Greg
  12. Jul 4, 2014 at 10:17 AM
    #52
    TacoMitch93
    Mitch
    09 Tacoma SR5
    It basically turns the motor into a giant air pump!! Good to know!
  13. Jul 7, 2014 at 1:56 PM
    #53
    gbreezer80
    gbreezer80 Well-Known Member
    Scott
    Dallas, TX
    07 Prerunner SR5
    Volant CAI w/Scoop, Borla Catback Exhaust, URD MAF Sensor Calibrator, Dual 10" LED Lights, Kickass Audio System
    I did a Volant CAI + scoop and URD MAF Sensor. Didn't notice any increase in MPG, maybe slightly better performance when stomping on the pedal, but overall 'noise' was increased. If you want a great look under the hood, go for it. If you want want throw away $$ (mine install was about $500) install a CAI. And, I wouldn't waste your money on the URD MAF.
  14. Jul 7, 2014 at 6:26 PM
    #54
    tooter
    Greg
    Los Angeles
    That's a really neato looking intake. :)
    I'll bet it sounds awesome. Sometimes we do things just for the cool factor, and that's ok. Is that little box a URD MAF sensor or is it their MAF controller? How was it to install?
    Greg
  15. Jul 8, 2014 at 1:40 PM
    #55
    gbreezer80
    Scott
    Dallas, TX
    07 Prerunner SR5
    Hey Greg...it's the MAF sensor calibrator: http://urdusa.com/p1260198051/URD-MAF-Sensor-Calibrator/product_info.html
    Installation was easy - just soldered the leads to the wires on the ECU just under the passenger kick panel. I just keep the black box in the glove compartment.
    Yah, intake does look great and definitely more 'throaty'....helps along with the Borla catback too in terms of great sound.
  16. Jul 8, 2014 at 6:08 PM
    #56
    tooter
    Greg
    Los Angeles
    Thanks. :)
    I just emailed URD to see if it will work with my 2.7.
    My Flowmaster exhaust is so loud, I can't hear my intake any more! :laugh:
    Greg
  17. Jul 8, 2014 at 8:28 PM
    #57
    Blacktaco2042
    Blacktaco2042 Well-Known Member
    wisconsin
    supercharger/trd cat back 3inch lift 265/75/16 duratracs bumper guard led bar
    you like that intake? i was thinking bout getting that one
  18. Jul 8, 2014 at 8:32 PM
    #58
    Aw9d
    Aw9d That one guy
    Warm air intake you say....
    Simple, route a small pipe off your header right into the intake tube.
    Problem solved. Won't get any warmer than that!
  19. Jul 8, 2014 at 10:32 PM
    #59
    tooter
    Greg
    Los Angeles
    Old cars used to do that... :)
    They ducted hot air from the exhaust manifolds right into the air intakes. The intake manifold vacuum operated valves would automatically open for colder air under heavy acceleration. The pic is of a 1978 Chevrolet Corvette...
  20. Jul 9, 2014 at 3:40 AM
    #60
    wdb
    wdb intolerance intolerant
    Dave
    the perimeter
    plain jane
    Hella 4000 eurobeams, Amp Bed Step, IamMrYo mirror riser, Wet Okoles, HomerTaco satoshi, retrofit intermittent wipers & backup camera
    I did it on my recently hailed-to-pieces Honda Fit, in the winter months. The car warmed up faster than the ridiculously long time it took without the mod. Gas mileage was marginally improved too.
