Throttle body spacer worth it?
Discussion in 'Performance and Tuning' started by m3dragon, Oct 18, 2007.
  1. Aug 14, 2012 at 4:00 PM
    #21
    Speed Freek
    Speed Freek Tacoma Whisperer!
    Jason
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    Most cars built today are making as much power as possible and still getting reasonable mileage.
    The answer is NO there is nothing that will add significant power without forced induction period.
    Unless you do the LS1 mod like I did..then you can have 30mpg and 300+ hp, just not both at once, lol.
  2. May 2, 2017 at 4:56 AM
    #22
    TacoDan90
    TacoDan90 New Member
    heres an Idea, for almost the same price. why cant you buy the Holly sinper EFI throttle body (shown here https://www.carid.com/sniper/sniper-efi-throttle-body-326061209.html ) in 92mm and retro fit(not really because its a universal fit) it to the intake. the stock throttle body bore is 65mm, the holly efi bore is 92mm, that's a 27mm jump in size and should suck way more air to provide way more horse power. (and sounds way better than a paper weight)
  3. May 2, 2017 at 5:04 AM
    #23
    Hagendazsss
    Hagendazsss Well-Known Member
    San Diego, CA
    2017 3.5 4x4 sr dcsb
    Just buy it! It will make you feel faster and you can add it to your mod list. It increases the felt air flow and the extra chamber cools down the air before the throttle body! You may get a engine light code for thrown air sensors but it's fine you can reset that light easy. And the best part is that you can customize the color so your engine bay gets a little color!
    Danny72 and TacoDan90 like this.
  4. May 2, 2017 at 5:12 AM
    #24
    iwashmycar
    iwashmycar a lot
    Adam
    Lewis Center, Ohio
    07 FJ 4x4 AT
    33's | 3" | skids | rails | dent | CB | lights | dingus
    This is the only type of throttle body spacer that works.
    whatstcp, TimberTaco298 and mwc273 like this.
  5. May 2, 2017 at 5:15 AM
    #25
    Blais03
    Blais03 Guess I'll bring a spare wheel bearing...
    Nick
    Easthampton MA
    '08 Reg. Cab 4WD + '06 Reg. Cab 2WD
    this is a super old thread guys :notsure:
  6. May 2, 2017 at 5:18 AM
    #26
    Hagendazsss
    San Diego, CA
    Haha just noticed. It came up in the recent threads
    Blais03[QUOTED] likes this.
  7. May 10, 2017 at 8:49 AM
    #27
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Throttle body adapter from URDUSA and the 70mm TB. Better upgrade.
  8. May 10, 2017 at 8:55 AM
    #28
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    As for some of the prior posts, N/A bolt-ons , and some type of tuning, can net the 1GR a little more power than bolting on the TRD/Magnuson in unmodified form, to a stock truck. In both whp and wtq.
    That is a Fact.
  9. May 10, 2017 at 9:14 AM
    #29
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Drop a 6.0 in. Call it a day.
    Biscuits likes this.
  10. May 10, 2017 at 9:21 AM
    #30
    wade9986
    wade9986 Well-Known Member
    Ross
    Stuart, Florida
    2020 TRD Sport 4x4 Supercharged
    Magnuson Supercharger OTT Tune TRD Pro Front End Conversion Old Man Emu Lift 285/70/17 Nitto Trail Grapplers 17x8.5 Black Rhino Duggers Fab Fours Front Bumper Smittybilt X20 Winch Rigid Industries Lightbar
    I had a poweraid throttle body spacer and it did nothing but make a whistling noise at partial throttle. I took it off because my engine cover wasn't lining up right with it on there. It did however make a noticeable difference on my old Chevy S10 with the throttle body injection. With carbs and tbi's the spacer is better able to mix the fuel and air before entering the combustion chamber. In the case of today's fuel injection it does nothing.
  11. Apr 4, 2019 at 2:12 PM
    #31
    RyanMArks
    RyanMArks Member
    California
    1995.5 5Lug
    Hiya from Northern California single cab 1995.5 2wd Tacoma 2rz Intake Header Exhaust short shifter lift spindles lift shackles 31X10.5-15 Teflon shift bushings throttle body spacer k&n 5in cone rear swaybar
    Worth it if used as a plate to hold nitrous nozzles
  12. Apr 4, 2019 at 2:14 PM
    #32
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
  13. Apr 4, 2019 at 2:22 PM
    #33
    RyanMArks
    RyanMArks Member
    California
    1995.5 5Lug
    It can be my friends haha my homemade works just as good as this one.
  14. Apr 4, 2019 at 2:27 PM
    #34
    Styx586
    Styx586 Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2013 Tacoma DCLB TRD Sport, 2001 Tacoma TRD Off-Road
    :rofl::rofl::rofl:
    Triple thread revival! OP in 2007, revived in 2012, 2017, and now 2019.
  15. May 7, 2019 at 11:11 AM
    #35
    iwashmycar
    iwashmycar a lot
    Adam
    Lewis Center, Ohio
    07 FJ 4x4 AT
    Yeah I covered that two years ago.
  16. May 24, 2019 at 8:58 AM
    #36
    Requiem Eternum
    Requiem Eternum Member
    Allan
    2018 Tacoma TRD Sport
    I know it's an older thread but I have some input. I just installed the power aid throttle body spacer on my 18 TRD sport manual transmission. From what I can tell, it pulls a little better in the mid-range now, not a huge difference but enough to where I notice it. No whistling sound is emitted. I also have a 3" cat-back flowmaster installed, and a Japanese D-1 spec super voltage stabilizer and grounding kit. I installed the trd intake yesterday and it pulls a little bit more aggressive with it, with the emphasis on "a little bit". My dealer wanted $515 for the TRD CAI but I found it for $400 shipped at a NH dealership. I don't think its worth the $400 but here in Ca its the only CAI kit that is smog legal, no company will ship any of the other CAI kits to this state. As it is even the throttle body spacer isn't legal in Ca, I was able to get one because I took a trip to VA and just walked into an Autozone and got it. My assessment is that the truck pulls harder throughout all 6 gears with the power coming on the hardest after 3500 rpm, but I think its a combination of all the modifications working in unison. I also ordered the pedal commander yesterday so hopefully I'll see a positive response with that. I did read up on the OVtune but I'm not really comfortable messing with the computer on my truck that isn't even 1 year old yet with less then 3000 miles, I have the 10 year extended warranty and I just don't want to possibly interfere with that in any way. Also, I see all the positive feedback on the OVtune but also there is a number of people who have experienced problems with it. I guess I'm just not totally convinced that the tune is foolproof and has all its bugs worked out. Well this is my experience for what it's worth. Allan..
  17. May 24, 2019 at 9:03 AM
    #37
    NYCTaco52
    NYCTaco52 Half man, half goat
    Somehow known as Stewart, but named Ben
    Ft Lauderdale, FL
    2022 Subaru Ascent
    Huh?
  18. May 25, 2019 at 3:30 AM
    #38
    98tacoma27
    Ben
    Not Beech Creek
    In all honesty, your assessment means nothing without a baseline comparison of actual data. Butt dynos are flawed.
  19. May 25, 2019 at 8:52 AM
    #39
    Requiem Eternum
    Allan
    Like I said it's only my own personal experience. I don't know much about butt dynos, I just know how my vehicle behaved with some modifications. Of course to really know of any measurable difference a dynamometer test would be necessary.
  20. May 28, 2019 at 10:44 PM
    #40
    BarcelonaTrail
    BarcelonaTrail Member
    San Diego CA
    '16 T4R Trail
    AFE Intake, Throttle Body Spacer, & Cat-Back Exhaust - Pedal Commander, Icon Rebound
    *4 Runner not Taco
    I can speak to the trifecta of the AFE throttle body spacer, intake, and cat-back exhaust (as well as the Pedal Commander)
    The truck flat out moves now - and is a ton more fun to drive. It's not the ice cream truck that it used to be
