Found cause of lost compression, need machine shop recommendations
Discussion in 'Performance and Tuning' started by armyoffoo, Nov 29, 2014.
  1. Apr 2, 2015 at 6:03 PM
    #61
    chyknees
    chyknees nomadic wanderer
    So Cal
    05 Tacoma TRD 4x4
    TRD, Total Chaos, Fox, Volk, BFHoodrich
    Nice! Where did you get the heat exchanger and aluminum reservoir from? :)
  2. Apr 2, 2015 at 8:27 PM
    #62
    armyoffoo
    armyoffoo [OP] Scrotie McBoogerballs
    Houston, TX
    2018 Tundra CM TRD Sport
  3. Apr 3, 2015 at 8:31 AM
    #63
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    How's everything running? Since it has been a while now.
  4. Apr 3, 2015 at 1:42 PM
    #64
    armyoffoo
    Houston, TX
    Finally took it for a drive last Sunday to get an alignment, was running bad, multiple misfires, same codes I was getting prior. I'm thinking I got a bad tank of gas, because the ride home after that fill up in October was my last. I have dropped the tank and drained the gas and fuel lines as well. I am about to put the tank back in and fill with 5 gallons of fresh gas to see what happens.
  5. Apr 3, 2015 at 4:17 PM
    #65
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Fingers crossed thst cures it. Just returned from Kozmic Motorsports, after having them tune it. Runs great! A few more things to finish before MSR tomorrow. Hopefully you can still make it!
  6. Apr 21, 2015 at 8:16 AM
    #66
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Did you do the ARP main studs as well? If so, did G&G cut the threads up the shoulders, for you?
  7. Apr 21, 2015 at 10:30 AM
    #67
    armyoffoo
    Houston, TX
    Couldn't find the specs on them. Do you have the info?
    Also, gas was definitely bad, but not the only issue I'm dealing with. My drivers side bank is 90-100 psi, so I'm tearing it apart again. Have it down to the timing chain now, hopefully taking the heads off this weekend. I thing my piston ring gaps are lined up, the compressor I used sucked. Or maybe my head gasket didn't line up right.
  8. Apr 21, 2015 at 10:59 AM
    #68
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    For some reason I thought you had them already. They are 2JZ head studs. Except that the shoulders on the studs needs to be hit with a die to add more threads, or the shoulder needs to be trimmed down. It prevents the studs from being able to be fully installed and bottomed out.
    I have a bad #2 cylinder myself. Literally just recently found out that my torque wrench was messed up by my friend. Unbeknownst to me until just recently. Which means than none of the high torque number parts, in my current spare engine, are properly torque'd down. Including head studs. :facepalm: Mine will be coming apart soon for repairs as well.
  9. Apr 21, 2015 at 12:46 PM
    #69
    armyoffoo
    Houston, TX
    Yeeesh, how did you find out it was not torquing correctly? I bought this one (Kobalt) new before my teardown so I assumed it was accurate.
  10. Apr 21, 2015 at 8:34 PM
    #70
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    He told me, a few days before race day, that he had loosened until it "stopped" Well below the lowest torque number. He was apologetic, as he hadn't known any better until that conversation.
  11. Apr 22, 2015 at 5:17 AM
    #71
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    Good thread! Keep it updated. I enjoy reading these kinda things. Reminds me of the days I spent diagnosing and pulling engines/trans (what seemed like once a week lol)
  12. Jul 5, 2015 at 11:24 AM
    #72
    armyoffoo
    Houston, TX
    In addition to the head studs possibly being lose, the intake cam gear wasn't aligned properly. I had to order a new one and rebuilt the engine again. Primed oil today and tested compression cold, then fired it up! It's running great, very smooth and no leaks or weird noises. Good compression and oil / fuel pressure, need an alignment and inspection / registration. Note to self: less beers when building engine...pay attention! I'm lucky I didn't bend any valves or mess anything else up, I drove it for like 10-12 miles in that condition misfiring on all cylinders on bank 2 and a misaligned cam gear, tsk tsk!
    NEW Intake Cam gear
    OLD Intake Cam gear (Driver's side, bank 2)
    Rebuilt, oil primed, compression tested, ready to fire
    Running, full frontal:
    Look Ma, No Leaks!
    From the side:
    Old School likes this.
  13. Jul 7, 2015 at 11:24 AM
    #73
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Man, I was wondering when there would be a good news update. I am really excited for you, that you were able to not only find the problem, but not have any valve/piston damage as well. It could have been much worse. All turned out well, and thank you for sharing what the problem was. :thumbsup:
    How does it feel to be driving it around now?!
    Damn man, completely forgot to invite you to the car/truck meet on Sunday. Your truck would have stood out, and fit in well with ours.
  14. Jul 7, 2015 at 11:25 AM
    #74
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  15. Jul 7, 2015 at 3:18 PM
    #75
    armyoffoo
    Houston, TX
    Engine is running very nice, smooth steady idle and strong even though I've been taking it easy. I put a good 60+ miles on it today, in Houston traffic no less, and nothing but some minor work to do. Small power steering leak, exhaust leak somewhere...and a minor vacuum leak around the throttle body adapter. Also, not happy with the brakes, but I've got a plan for that.
  16. Jul 8, 2015 at 7:41 AM
    #76
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Punch list items.....
    Which TB do you have?
    Be happy you have the 4 piston calipers instead of the 1 pistons of the 5 lug trucks. It'd be much worse... :eek:
    Have you tried bleeding the brakes for the interim?
  17. Jul 8, 2015 at 7:57 AM
    #77
    armyoffoo
    Houston, TX
    I got the 76mm off eBay and the adapter from URD, the back of the TB wasn't very flat and I have already worked on it some, I may just use a thin layer of gasket material.
    I did a bad thing, despite all the warnings I converted the rear drums to discs...:D
    I have a new MC, some 1/2" plate to make an adapter, as well as a proportioning valve for the rears...just need to do the work.
    #77
  18. Jul 8, 2015 at 8:07 AM
    #78
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Definitely make a gasket for the TB adapter. I had to add it to prevent it from leaking.
    One of these days I'll swap to rear disks as well. With most likely an AP Racing adjustable proportioning valve. Necessary at this point.
  19. Jul 8, 2015 at 10:06 AM
    #79
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
  20. Jul 8, 2015 at 11:01 AM
    #80
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    What the hoot is that all about?
