Found cause of lost compression, need machine shop recommendations
Discussion in 'Performance and Tuning' started by armyoffoo, Nov 29, 2014.
  1. Nov 29, 2014 at 10:58 AM
    armyoffoo
    armyoffoo [OP] Scrotie McBoogerballs
    Houston, TX
    2018 Tundra CM TRD Sport
    So, my truck starting idling rough and running rough after a "spirited" drive home and after some digging found that it was losing compression in Cyl #4.
    Adding oil to the cylinder and repeating the compression test did not help
    So I pulled the engine out hoping it would be a head gasket
    Heads looked great and no issues with the head gasket, so I tested the valve seats by turning the head upside down and pouring kerosene in the head over the valves...they held liquid for over 2 hours
    Next, I pulled the #4 piston and found an issue, the gaps for all the rings were almost lined up...upon further examination, the ring lands were cracked and I was able to pick the pieces of the piston out between the rings...OAif9K_c52d6d9dd3454dafb91724717343f650859fa48f.jpg
    The block is scored, but I can't feel it with my finger nail, got really lucky I think and caught it quick but I need to take it to a machine shop to have it looked at.
    Does anyone have any suggestions of shops in the Houston area that have experience with the 1GR? Torspd? Anyone? HALP!!
  2. Nov 29, 2014 at 8:09 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    As a matter of fact I do know of a shop. Good job having some mechanical sympathy. :thumbsup:
    I just today, dropped off one of my blocks to Kozmic Motorsports. Through them they will be taking it out to their machinist. They will be closed tomorrow and Monday. Ask to speak with David. He knows me well.
    Get you a little hone on there and a new piston. Be good to go.
  3. Nov 30, 2014 at 6:40 AM
    armyoffoo
    Houston, TX
    Cool, thanks man, I'll give them a call on Tuesday. I already ordered new CP pistons from LCE on Friday, and will be ordering Molnar rods from Dezod on Monday along with Clevite bearings and rear main while I'm at it. That should keep my bottom end from needing anything for a while.
  4. Nov 30, 2014 at 7:31 AM
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    2 years old and pulled engine already?!
    How many miles?
  5. Nov 30, 2014 at 7:45 AM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    That's my thought too. WTF?
  6. Nov 30, 2014 at 8:03 AM
    armyoffoo
    Houston, TX
    47K miles.
  7. Nov 30, 2014 at 9:06 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Do not order the Clevite thrust bearings. They don't fit properly. Use the OEM thrust bearings.
    Ask for Omar at Joe Meyer's Toyota, on Eldridge and 290, in the parts department. He's been there through plenty of my engine builds and parts orders.
  8. Nov 30, 2014 at 9:35 AM
    armyoffoo
    Houston, TX
    Sweet, thanks for the heads up on the bearings. I will give Omar a shout, I deal with that dealership all the time since I'm out in Cypress.
  9. Nov 30, 2014 at 9:43 AM
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    Are you not covered under powertrain warranty?
  10. Nov 30, 2014 at 10:49 AM
    armyoffoo
    Houston, TX
    Probably not, I installed my own supercharger last May and a smaller pulley for more boost, on top of every bolt-on available. I do my own upgrades and repairs regardless...have heard too many horror stories about Toyota techs screwing up an oil change, let alone engine work, I wouldn't trust them with my baby.
  11. Nov 30, 2014 at 12:01 PM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 GX550 Overtrail+
    Seems like you're in good hands. Good to see that the problem isn't too bad :thumbsup:
  12. Dec 2, 2014 at 12:49 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Any updates?
  13. Dec 2, 2014 at 12:53 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Is she brunette?
  14. Dec 2, 2014 at 1:10 PM
    BamaToy1997
    Bill
    Navarre, FL
    There are plenty of Toyota techs that do great work out there. Just like there are plenty of aftermarket shops with techs that would ruin your engine. The key is getting word-of-mouth advertizing on a quality tech. As Torspd had done for you. But I still wouldn't rule out Toyota just because you have heard some bad words on them. Of course it is too late now that you have pulled it out! lol.
  15. Dec 3, 2014 at 4:59 AM
    armyoffoo
    Houston, TX
    I dropped off my block at G&G machine shop, they said that I should get it back today or tomorrow. The pistons, rods and bearings are ordered but have not shipped yet.
  16. Dec 3, 2014 at 6:00 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Good deal. Are you having them hone that one cylinder only, or all of them?
    I finally finished disassembly of my stroker engine last night. Going to be taking that in soon, too.
  17. Dec 3, 2014 at 6:04 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Just realized that you had to take your wheels off to pull the engine. I remember those days.
  18. Dec 3, 2014 at 3:33 PM
    armyoffoo
    Houston, TX
    They did all 6, I got the call this afternoon that it was ready for pick up. There was only one real scratch in the cylinder that the piston came apart in, but it's all cleaned up now. Why are you taking your stroker in?
    Yeah, even with the wheels off and the jackstands at the lowest level I still had to swing the motor over the front of the fender to remove it from the side. There's not enough room in these new garages, if I had a 6ft bed I wouldn't fit.
  19. Dec 4, 2014 at 4:12 PM
    armyoffoo
    Houston, TX
    Half of the puzzle has arrived, interesting that these didn't require a signature but the bearings and seals did...
  20. Dec 4, 2014 at 4:49 PM
    Lord Helmet
    Nick
    Nice.... H-beam connecting rods I take it? I'm a Eagle, Manley, and Wiseco type of guy.
