Nst Pulley
Discussion in 'Performance and Tuning' started by SkyHighTacoma, Oct 16, 2009.
  1. Oct 16, 2009 at 12:47 PM
    SkyHighTacoma
    SkyHighTacoma [OP] Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    Ok well i bought a nst crank pulley and recived this with it lmao.
    Has anyone else recived M&M's also? I think its pretty funny.
    But i also got this so im good.:D
    And im going to buy all the other pulleys and will be updateing this thread. Hopefully i get more M&M's..:yay:
  2. Oct 16, 2009 at 12:55 PM
    TexasIslandBoy
    TexasIslandBoy THE RED DRAGON!!
    Andrew
    South Texas. SPI
    07' trd offroad 4X4 (For Sale)
    pro comp 6inch lift 35'' tires moto 950's radfo coilovers magnaflow exhaust 5/16" front skidplate usa spec ipod interface tree pin strip mod dry drop in filter full size BFG KM2 spare
    haha thats bada$$ they gave you a pulley with your order of m&m's hahaha
  3. Oct 16, 2009 at 12:55 PM
    Fire931
    Fire931 Well-Known Member Vendor
    VA
    00 4Runner
    make sure to buy each one separate so you can get more snacks!!!!
  4. Oct 16, 2009 at 12:59 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I belive they include a bag with every purchase. :)
  5. Oct 16, 2009 at 2:38 PM
    roxspin72
    roxspin72 Enjoying my addiction
    NC
    Speedway Blue, TRD, 4X4,
    Oh Yeah!!!
    I need to call Mike and or Shane: Im due two packs of MnM's :D
    The new Power Steering pulley is out. Cant wait til I redeploy... My avatar should spell it all out:cool:
  6. Oct 16, 2009 at 8:09 PM
    SkyHighTacoma
    Josh
    15 DCSB SR5 MGM
    Lol okay i was wandering why i got M&M's lol but its cool. At least i got something to snack on while i put it on lol.
  7. Oct 18, 2009 at 6:18 PM
    SkyHighTacoma
    Josh
    15 DCSB SR5 MGM
    Well, i think i screwed in the pulley holder bolt to much and it now my crankshaft seal in damaged and leaking oil... :( So now i have to buy a new seal and fix it.
  8. Oct 18, 2009 at 7:47 PM
    SkyHighTacoma
    Josh
    15 DCSB SR5 MGM
    And how did yall not damage the crank seal when you put the two bolts in? They line up right under were the seal goes and it pushed it in and up. But i sanded it down real good and put some jb weld on the outside were it took a little chunk out. And then im going to sand it down some more to get it as good as i possibly can. Then put the new seal in refill the oil and check for any leaks.
  9. Oct 18, 2009 at 8:38 PM
    98tacoma27
    Ben
    Not Beech Creek
    Those bolt holes aren't meant to actually pull the pulley in the way you did. They have two purposes:
    one- to keep the pulley/crank from spinning while you remove the crankbolt
    two- You only screw the bolts in far enough to use one of these
  10. Oct 18, 2009 at 8:43 PM
    Anathollo
    Anathollo www.saveadane.org
    Houston
    07 Tacoma TRD Sport
    Icon coilovers, Rear Fox Resi-shocks, 285/70/17 Toyo A/T's, Touchscreen JVC Headunit, Custom Rhino-lined sub box, Rocksford Fosgate components and Dual Rockford Fosgate 10" shallow subs, Pioneer and Rocksford Fosgate amps, 1250 watts total, Autometer Volt and Trans gauges with Lotek A-pillar, K&N Drop-in filter, WO Seat covers, Tint, NST WP pulley, Hi-lift jack, Diff breather mod, horn relocation mod, extra "D" rings, de-pinstriped, carrier bearing drop, Rear backup 886 bulbs, Camburg UCA's, AMW Catch can, BHLM, OME Dakars with AAL, Procomp 7089's, Front single hoop Demello bumper, Superwinch Tiger Shark 9500, Amsteel 3/8th synthetic line
    Yeah take it from sockmonkey and myself. DO NOT buy the alt pulley. It's not worth it and will probably overdrive your alternator to the point that it breaks itself. And if you can actually get the alt pulley off to begin with... Get the water pulley though, it's worth it, as the truck seems to accelerate smoother...
  11. Oct 18, 2009 at 9:38 PM
    SkyHighTacoma
    Josh
    15 DCSB SR5 MGM
    Thanks for the reply, but the pic you posted is a pulley puller that is used after the main 22mm bolt is removed. I was able to remove the pulley from the crank easy with my hands. I needed a method to stop the rotation of the pulley when I torqued the 22mm main bolt loose. I now figured a beltstrap or homemade tool may help me in this. I used an impact that had 150ftlbs on it but it never budged. Maybe a larger impact lol. Any ideas for when i install the nst pulley? :confused:
  12. Oct 19, 2009 at 5:05 AM
    98tacoma27
    Ben
    Not Beech Creek
    That is one purpose of the holes in the pulley, to stop rotation. Put two bolts in the holes, make sure they don't extend behind it too far. Then you use a bar or extension place between the bolts to stop rotation as you torque it down. This pic is of a 3.4L pulley. You can fab up something similar. I have found that strap wrenches don't hold the pulley tight enough when you torque the crank bolt down.
  13. Oct 19, 2009 at 6:26 PM
    j31driver
    j31driver Active Member
    chris
    upstate NY
    09 Tacoma
    Does anybody make pulley's for the 2.7 4 banger?
  14. Oct 19, 2009 at 6:28 PM
    98tacoma27
    Ben
    Not Beech Creek
  15. Oct 19, 2009 at 7:37 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Here is the easiest way to get the pulley bolt loose. Mind if you have a 5 or 6 speed trans. Put it in which ever is your last gear; pull the emergency brake; and then crank on the bolt. It will come right out with a little strength or a nice long breaker bar. Then there is no need to use the "2 bolt" method.
    Athlaos likes this.
  16. Oct 20, 2009 at 4:44 AM
    sockmonkey
    sockmonkey Well-Known Member
    Greg
    Benbrook, SW Fort Worth
    2007 White Dbl Cab Pre-Runner
    Volant Ram Air intake,URD MAF calibrator, Mr Marv 10" sub box, Alpine HU, Alpine Amp, fog light mod, scan gauge II, RAAMmat front and rear doors, Wet Okole seat covers, blacked out dash. blacked out front bumper. American Racing Mojave Teflons wrapped with 265/70/16 Pathfinder AT. NST Lite Pulleys
    or, if you have to have one.....buy mine
    http://www.tacomaworld.com/forum/buy-sell-trade/54299-nst-alternator-pulley.html
  17. Oct 20, 2009 at 5:38 AM
    sockmonkey
    Greg
    i, too, got M&Ms.
    i didn't eat them because it was too wierd
  18. Apr 7, 2010 at 3:36 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    are they difficult to install?
  19. Apr 7, 2010 at 7:24 PM
    roxspin72
    NC
    Oh Yeah!!!
    No... It should take less than 20 min. the Alt pulley is a little harder. I just pulled the alternator out. Used an air rachet to remove and replace. Slapped the Alt back in. Hardest part was driving over to the shop to borrow the air tool...
  20. Sep 1, 2016 at 4:26 PM
    WorldWar546
    WorldWar546 Baja Member
    Anthon
    Utah
    TRD Charged '14 Black TX Baja
    TRD Supercharger And a lot of rice n chrome
    Is a crankshaft pulley and a alternator pulley worth it? What about water pump and power steering pulleys?
