-   -   Synthetic or Natural oil (http://www.tacomaworld.com/forum/performance-tuning/13163-synthetic-natural-oil.html)
sabian 08-20-2008 09:46 AM
I know this topic has probably come up numerous times on this site but I couldnt find a thread on it. Does any one know if there is any real advantage to using synthetic oil? For the price you can change your oil out quite a bit more often using the regular stuff. having just bought a new tacoma I am thinking about changing over right away. Though I am not sure about the warranty issues on the vehicle if I do this. But I have heard all kinds of stuff about changing over later in the life of the vehicle and how it breaks seals and stuff. Don't know if thats just Bull or what. Any thoughts?
Brunes 08-20-2008 10:04 AM
Welcome to TW and check these threads out- There is tons of info about all the different types of oils (diffs, engine, etc)
http://www.tacomaworld.com/forum/sea...searchid=28093
dog tired 03-02-2010 07:57 AM
Yes and most it is hyperbole
All syn oil comes from natural oil base stock
FACT
HondaGM 03-02-2010 08:03 AM
im all natural 5w 30 castrol
sethr21785 03-02-2010 08:04 AM
There is no harm to switching over right away. And you can always switch back if you want. People say once you go synthetic you cant switch back, that is bs
I suggest amsoil full synthetic 5w-30!!
sdirep 03-04-2010 03:31 PM
heres a question i have...i just bought my 2010 tacoma back in oct....im currently at 4500 mi and about to change the oil...would it be okay to change to synthetic now? is that okay? and my maintenance required light just turned on...does that mean i need to do the oil change or is that for something else?
Flugelhornjazz 11-09-2010 07:38 PM
synthetic or o' naturelle
There are many taco benders on TW that run synthetic. I happen to be one of them. I believe the 4 ball wear tests that show synthetic oil to be superior.
I also come from experience: about 20 years running excellent "natural" oils like Castrol and Penns in a variety of vehicles. I've also run 100% synthetic oils about 20 years in a variety of vehicles. My experience shows that synthetic oil does last longer, has a lower pour point, and in some cases quiets noisy lifters, etc.
I bought my '06 (Access cab) brand new. I figure a few dollars more for a synthetic oil change is worth keeping the Tacoma new as long as possible. My '06 now has 63,000 miles on it. I changed the factory oil at 1000 miles with a new filter and Castrol premium petroleum oil. I ran that oil change to 5K, then changed the oil to 100% synthetic w/ a new filter. I wanted to be absolutely sure the rings were seated before I ran synthetic.
Well, I use Amsoil's top of the line synthetic oil (signature series) for 12 month oil changes. I do not add one drop of oil to top the reservoir between changes because the motor doesn't use oil! I am very happy with the results! :cool:
gobias 11-09-2010 11:02 PM
You can switch to and from syn and dino and different brands whenever you want. Won't do any harm.
Synthetic oil allows longer OCIs but dino can typically last 5k miles w/o a problem.
After using dino for the past 9 years I recently switched to Pennzoil Platinum because of all the rave reviews and results it has been getting on bitog.
Main reason why I use synthetic? My truck is my baby and I want to hold on to it as long as humanly and mechanically possible.
ColtsTRD 11-09-2010 11:03 PM
Mobile 1 Synthetic FTW :)
I run this in my engine and the gear oil in my rear diff.
BakoTruck 11-09-2010 11:07 PM
I use all mild weight taco bell sauce in my engine. Did run hot weight, but made my engine run too hot.
ColtsTRD 11-09-2010 11:08 PM
:cookiemonster:
BakoTruck 11-09-2010 11:17 PM
Originally Posted by ColtsTRD (Post 2371201)
:cookiemonster:
Man, I could go for some cookies right about now. Damn diet. lol little off topic.
Series1000 11-09-2010 11:26 PM
Mobile 1 Synthetic 5w30 FTW!
