7th injector, and 8 psi boost
Discussion in 'Performance and Tuning' started by caliKxracer, Nov 16, 2008.
  1. Nov 16, 2008 at 10:36 PM
    caliKxracer
    caliKxracer [OP] Well-Known Member
    kyle
    san diego
    2000 Tacoma Prerunner
    Supercharged, Linked and Caged
    im still pretty new to superchargers but, im looking for getting a 7 injector kit and a 8 psi boost kit if anyone knows where i could pick them up, used or what not let me know, thanks
  2. Nov 17, 2008 at 4:35 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
  3. Nov 17, 2008 at 4:45 PM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
  4. Nov 17, 2008 at 4:47 PM
    HerNameIsLucy
    HerNameIsLucy I miss Lucy. :-(
    John
    Equador. Don't know why.
    RIP Lucy.
    She's gone but not forgotten.
    Question on 7th injector: where does the 7th injector go? There's only 6 holes on the fuel rail, and only six intake ports. Is the name "7th injector" a misnomer, it's not really an injector but just a way to get extra fuel in the engine during high RPM sprints?
  5. Nov 17, 2008 at 4:59 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The 7th injector installs where the EGR block off plate is/was on the supercharger. It is an actual injector and the fuel is fed to it by the installation of a new fuel line connected to the passenger side fuel rail via a double banjo bolt.
  6. Nov 17, 2008 at 5:04 PM
    HerNameIsLucy
    John
    RIP Lucy.
    So it feeds the entire intake air tract? How is it timed, does it squirt 6 times each rev of the crank (to follow six opening intake valve sets), or just feed a steady spray whenever it's computer tells it the engine needs de-leaning?
  7. Nov 17, 2008 at 5:09 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Not sure on how its timmed. I belive its a constant pulsing to keep the AFR's in check. I dont have alot of experiance with the 7th injector set up, and have only installed the TRD ECU when installing the 3.4 supercharger, with no dyno tuning involved. :eek:
  8. Nov 17, 2008 at 5:38 PM
    HerNameIsLucy
    John
    RIP Lucy.
    If I'm doing my math right (and I may not be I bumped my head today) an injector on a V6 spinning at 6000PRM would have to squirt 500 times per second (6000RPM / 6 cylinders / squirt every two crank revs). How it turns on and off and still manages to regulate the fuel flow that fast I don't know.
    But if that's right, an injector trying to keep up with an engine running at 6000RPM would have to turn on and off 6000 times per second...a 12X rate.
    That sounds impossible. So I'm guessing it's a steady stream whenever the ECU says the engine needs it.
    Interesting it replaces the EGR valve and yet remains 50 state legal. When I lived in Cali, ANY mod affecting emissions, even if it made it cleaner, meant instant inspection failure.
  9. Nov 17, 2008 at 5:59 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It doesnt replace the EGR valve. It installes where the EGR plate is on the supercharger. The EGR valve is in the same place as stock.
  10. Nov 17, 2008 at 6:00 PM
    HerNameIsLucy
    John
    RIP Lucy.
    Ah, got it. Domo.
  11. Nov 17, 2008 at 7:23 PM
    XrunnIT
    XrunnIT Well-Known Member
    Austin, TX
    1GR-GZE X-Runner
    Built Motor by LC Engineering Boosted by TRD
    I'm not sure how it installs on the prev gen tacos, but on the TRD S/C for the 4.0L it is placed just behind the throttle body and controlled by a piggy back ecu (APR X-1). So you can have it firing whenever you would like. :thumbsup:
  12. Nov 22, 2008 at 7:38 AM
    Gadget@URD
    Gadget@URD Well-Known Member Vendor
    Southern Maryland USA
    URD Supercharged XRunner
    The URD 7th Injector Kit for the folks with the TRD Supercharger on their 5VZ engines is the ideal add on for that supercharger.
    It solves a few of the issues with installing the supercharger on your engine. It will suppliment the fuel needed to prevent the high RPM lean out problem and does a wonderful job of eliminating the high gear/Low RPM Pinging problems many have.
    The URD Performance Calibration Unit fires the injector 3 times a engine revolution to match the 3 intake events per revolution. The fuel is shot through the blower where it absorbs a good deal of the heat from the compressed air and this combined with the three shots per rev distributes the fuel evenly to all cylinders.
    Once you install the URD 7th Injector kit you can then install the URD 2.2" SuperGrip Supercharger pulley for more power and torque not to mention more fun!!!
    Remember it was the folks at URD that pioneered fuel delivery upgrades for the 5VZ TRD Supercharger. Our efforts started way back in 1997 when I installed TRD Supercharger serial number 32 on my 97 4Runner and serial number 299 on my 96 4Runner. You can see some of the early on problems without fuel upgrades here www.GadgetOnline.com
    Gadget
    www.URDUSA.com
    Mech_Eng likes this.
  13. Nov 22, 2008 at 4:02 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Just courious, but, How soon before the valves open does the injector fire?
  14. Dec 23, 2008 at 9:09 PM
    Gadget@URD
    It is not timed to the valve events. It is synced with ignition events and fires three times a revolution of the engine. That matches the number of valve events on a 6 cylinder Otto cycle engine.
    The fuel goes through the supercharger impellers and gets mixed up very well and it takes some of the heat out of the compressed air for added performance.
    Gadget
  15. Jul 21, 2020 at 8:20 AM
    Ginchicago
    Ginchicago New Member
    George
    Tacoma 3.4
    None
    Hi guys new to this forum and s/c. 7th injector ids something diy it need software and mechanic. I am very mechanically inclined. But dint want to mess with Ecu, thanks
  16. Jul 21, 2020 at 8:21 AM
    Ginchicago
    George
    Tacoma 3.4
    None
    Sorry for spelling I have sausage fingers
