-   -   UltraGauge Set Up- Quick Questions *sigh* (http://www.tacomaworld.com/forum/performance-tuning/258006-ultragauge-set-up-quick-questions-sigh.html)
Jay238 01-13-2013 11:14 PM
*sigh* Please don't kill me, some of us are not as technical as others. Can someone help me with some of the numbers I should plug in to my UG? Been searching the site for an hour or so and keep getting different things. I will highlight what I need in red. BTW, the UG says it cant sensor the fuel tank level, just the partial or full settings can be used..true? Also, if my speedo is off by around 13% due to the large tire size (according to tire size calculator), my miles for the distance function should be 1.13 miles traveled...correct? Thanks a lot for anyone who replies in advance. Please feel free to add anything else I should plug into UG. My truck has 35" tires btw.
So far I have:
Fuel Tank - 21 gl
Engine Size- 4.0L
Torque- ?
HP- 236?
WHAT ELSE?!
ToyComa84 01-14-2013 12:49 AM
well the torque numbers i believe are 266 lb-ft, and the tank size for the v6 is 21.1 gallons. this info i believe is from toyota.com. i use to have an '07
650H1 01-14-2013 01:26 AM
horse power is 245 if using premium gas.
ToyComa84 01-14-2013 01:33 AM
if one uses premium gas, how much torque is there? same?
650H1 01-14-2013 01:35 AM
good question buddy, not sure. i know SAE came out with different HP ratings last year for different premiums of gas. i would THINK torque would be affected, but im not sure.
Jay238 01-14-2013 09:25 AM
God this thing is a little annoying lol
Jay238 01-14-2013 11:32 AM
So guys I got the distance calibration within a 0.5mph of my gps and phone GPS. All should be accurate now for mpg correct. In fact, I could prolly fine tune it some more because its about 0.5mph slower than the GPS. Thoughts?
127.0.0.1 01-14-2013 11:56 AM
tune with gps speed at 80 mph over 5 miles on a straight highway for best results
and accuracy from gps
Jay238 01-14-2013 12:47 PM
Wow I only went to 65
ToyComa84 01-14-2013 08:46 PM
ok, thanks for what u do know. any idea how often SAE has/will come out w/different hp/tq ratings?
Rich91710 01-14-2013 09:05 PM
Oh just wait until you get into fuel usage calibration.
Fill the tank and reset all AVG.
Next tank, tell it that you filled the tank.
Go into Calibration > Calibrate Fuel
There will be a number there.
Change that number to match how much fuel you put in. Write this number down.
Next time you fill up, add the previous number to your new tank. So into Calibrate, and you'll see that the existing number is close, but not exact.
Each time you fuel up, repeat. After 5-10 tanks, you should be pretty close. My UG is rarely closer than 0.2mpg to calculated.
Now the good news... every time your fuel formulation changes... winter/summer, or the local nannies decide to change the ethanol content... you get to either live with the inaccuracy, or repeat the calibration procedure again.
Depending on fuel, my calibration is "correct" at a factor of anywhere from 1.080 to 1.099.
Jay238 01-14-2013 09:07 PM
Spent a lot of time today fooling with the thing today; still unsure how to use the fuel tank settings properly
Edit sorry rich we posted about the same time
Rich91710 01-14-2013 09:07 PM
Speed doesn't matter since you are calibrating on distance.
The greater the distance, the better the accuracy will be.
But...
The odometer and speedo use the same sensor, but they are not off by the same amount. My speedo reads about 4-5mph high at 65, but the odometer is only off by about 2.
Rich91710 01-14-2013 09:11 PM
Tank settings are basic.
The unit can't tell when you refuel... you have to tell it that you gassed up.
I don't use "partial"... if it's the day before payday and I only have $20, I just save the receipt and add the two purchases for Fuelly.
For the UG, once I've got the fuel calibration set, all I do is use the "up" arrow to tell it that the tank is full, and then go into the Gauge menu and clear all trip.
Jay238 01-14-2013 09:21 PM
Okay another distance calibration question for ya. So according to the tire size calculator, my speed is off by 13% ( I have 35/12.50/17s, on my speedo when I'm at dead 60mph, my gps and phone say I am going 67 mph).
So the UG is programmed at 5280 ft per mile/1.00. To get my proper distance calibration it would be 5280ft x 1.13 = 5966.4. I changed the calibration to this and it did change from 1.00 to 1.13 but the speed on the UG is still off (slower) that what my Garmin and Phone are telling me. Not by much, maybe 0.5-1.25 mph. Thoughts?
I want to get the most accurate real time MPG I can and today on the ride home, it was consistently in the 19-20 mpg range, with an avg at 19 (all freeway today, 75 miles or so). Seems high for me with lift/tires...thoughts? Do I need to adjust the 1.13 higher to match the Garmin/phone, to maybe 1.15 etc?...make sense?
I mainly bought the gauge for the real time/avg mpg feature btw and sorry if that is clear as mud. I drove my partner nutz today in the car.
GREEKBOY12295 01-14-2013 09:25 PM
I feel ya OP. I am pretty much struggling with my Ultra gauge and I dont understand how to do the calibration.
Rich91710 01-14-2013 09:28 PM
You aren't going to be able to get both speed and odometer to be dead accurate, and that number will drift slightly as your tires wear, and even from brand to brand of the same size tire.
If your odometer is matching the GPS, and speed is within 2mph, I'd be happy as a clam with that.
And yes, the MPG calculations on mine were about 2mpg high with the factory fuel calibration.
You won't be close until at least 3-4 tanks.
Like the distance adjustment, the bigger the number the better.
Jay238 01-14-2013 09:46 PM
Gothca, the thing is my odometer on my truck does not match my GPS, it is reads fewer miles than I really traveled. The MPH that is showing on the UG is close to the Garmin and phone but is off but just a tad. Am I missing something..:o:o
Rich91710 01-14-2013 11:01 PM
Just get the UG calibrated so that it's odometer is as close as possible and live with the UG's speed being off. The speed being off won't impact the MPG computations... that's all mileage and fuel burned.
On your calibration screen you have two options... one for fuel burn, and the other for speed/odometer. Reset the distance calibration, reset the GPS trip mileage, and hit the road for 200 miles.
Remember... a 2% error will barely show on a 50 mile run, but that same 2% error will be 4 miles over 200.
