-   -   URD's New "BEEF" Clutch (http://www.tacomaworld.com/forum/performance-tuning/258996-urds-new-beef-clutch.html)
Torspd 01-19-2013 05:23 PM
This is a full upgrade in every area over all prior designs. Very well constructed by the looks of it!
http://www.xr-underground.com/forum/...ad.php?t=51970
Torspd 01-19-2013 07:03 PM
This one, the Stage 3+ is rated for 580 wheel torque!
http://urdusa.com/p1260519139/URD-St...duct_info.html
wildjerseyfirefighter 01-19-2013 07:06 PM
Damn i may be doing it sooner then i planned!
Torspd 01-19-2013 07:10 PM
Just sharing the wealth my friend. Hope I didn't influence you to much. Muwahahahahaha...!
wildjerseyfirefighter 01-19-2013 07:12 PM
Not for $700...not just yet:eek:
Torspd 01-19-2013 07:13 PM
Clutch w/pressure plate is only $450.
If you also get the lightened flywheel as a package, then it is $780
wildjerseyfirefighter 01-19-2013 07:15 PM
Then i must have been looking at the stage 2.
$450 ill buy it tonight..haha
Torspd 01-19-2013 07:31 PM
Maybe the combo pack on this page?
https://urdusa.com/products_new.php
Justus 01-19-2013 09:54 PM
And sometimes I wish I had the 6spd............seems most people in my area and in this day/age they don't want to, or are so spoiled don't know how to drive a manual, so it makes it harder to find :(
Torspd 02-06-2013 09:05 AM
New from URDUSA.com !!!!!!
Originally Posted by Gadget (Post 897467)
:drool:
Torspd 02-06-2013 10:52 AM
Twin disk for the 1GR.
SconnieHailer 02-06-2013 11:06 AM
If I'm going to run stock power for the distant future which stage clutch would best suit me? I'd rather it not engage like the pure beef clutch in the Evo I run at the track... I'd go with the 3+ if it means longest durability and i'll deal with the snappy engagement. I may just go home and roast my clutch so I can upgrade !!! jk, but no more babying that OEM clutch that's for sure.
PS I swear im not following you around TW Torspd... apparently we find interest in the same things.
~M
Torspd 02-06-2013 11:12 AM
Hahaha. I have my first follower, and I don't have a Twitter account yet. Lol. Nah, it is all good man. Similar minds have similar interests. :top:
Based off of the new single disk clutches that URD released, I would just go with whichever fits your needs best.
Unless you want a (hypothetically) super smooth clutch that can take the abuse from towing, off roading, and high power builds. Then go for the twin disk. :D
Runn0r 02-06-2013 11:47 AM
I thought about a multi-stage clutch. Anyone ever have issues with the hydraulic system, pedal, TO bearing leveR when adding a multi-stage?
Torspd 02-06-2013 11:58 AM
Ask and you shall receive
http://www.xr-underground.com/forum/...494#post897494
Lucario Runner 02-06-2013 02:54 PM
http://t2.gstatic.com/images?q=tbn:A...5mLO72bQffUutw
DdayIsNear 02-08-2013 06:01 AM
So, I had bought a clutch kit nj was sent the wrong one. Sent it back and now need the right one. After reading this I have a few questions. The stage 3+ is more durable, I am getting flywheel and tob so total is $720+ 17$ shipping. Is the 3 more durable than the 1. I wheel my truck and the 3 will def make it harder, but I prefer longer life.
Thanks. Probably ordering within the next day or 2
dewey smith 02-11-2013 07:19 PM
What's the installation difficulty on one of these? I'm comfortable installing a clutch and I was just gonna go with the stock AISIN kit, but I wheel a lot and I'm planning on installing the TRD Supercharger kit when I have about $3k sitting around, haha.
Also, do I need any of the flywheel or pressure plate bolts if I get the clutch/flywheel combo? Would the flywheel be worth it if I can get the stock one machined for free? My dealership also just replaced the throw-out bearing on my truck before I bought it because it had the lovely squeak that so many of us have had. I wouldn't need to get a new one of those, would I?
ONE MORE QUESTION. Is the 3+ a dual disc? It doesn't look like it is in the pics. I'm sold on the dual-disc for sure.
Torspd 02-12-2013 06:43 AM
Best place to ask that question, would be here -
http://www.xr-underground.com/forum/...106#post898106
Since Gadget at URD started that thread.
Gadget@URD 02-12-2013 11:26 AM
The URD Clutches are direct replacements for the stock clutch. There is no difference on the installation.
Two things that you want to make sure you do or don't do during the installation. Professional mechanics are the worst for doing this.
When installing the pressure plate on the flywheel, make real sure you very slowly and evenly compress the pressure plate onto the the flywheel. Turn each pressure plate bolt 1/2 turn at a time so you slowly and evenly compress the pressure plate. I see professional mechanics use their screw gun and zip one all the way down, then do another one. Once that is done the diaphragm spring is bent and the pressure plate is ruined. You will never get a smooth engagement or release of the clutch. Something so simple is beyond the ability of so many professionals.
Next, don't hang the trans on the input shaft. This also happens all the time. People stab the trans on the clutch and then pull the jack away and the weight of the trans is hanging on the input shaft. That will bend the hub of the clutch disc and ruin it every time. The clutch will never engage smoothly once the hub is bent.
Of course always replace the flywheel or have it machined.
The URD Stage 3+ clutch is a single disc but it is a dual friction with different types of friction material on each side of the disc.
You should not try to reuse the flywheel to crank bolts. They are single use if you have the stock ones. Get new stock ones or something better.
The problem is you can be doing the install and then go to torque up the flywheel bolts and find that one or more just stretch and will not tighten up. This is a common thing so have new bolts ready to go in.
G
