-   -   Y-pipe Problems (http://www.tacomaworld.com/forum/performance-tuning/259621-y-pipe-problems.html)
DelinquentTaco 01-23-2013 06:57 AM
Y-pipe Problems
Hello, I have a 2011 TRD OffRoad and I was looking under my truck and noticed that my y-pipe seemed to be flattened where it crosses just behind the front cross member. Has anyone else noticed this? Does anyone know if the Doug Thorley performance y-pipe stays above the cross member?
Thanks.
Torspd 01-23-2013 07:15 AM
That is a factory form. Nothing out of the ordinary.
If you want an aftermarket Y-pipe that is worth the money, hands down get the URD Y-pipe. It is superior. Not an opinion.
DelinquentTaco 01-23-2013 10:43 AM
Will an aftermarket y-pipe stick below the cross member? Will I have to worry about bending it?
Torspd 01-23-2013 11:24 AM
The URD Y pipe will not. You will only have a problem with it fitting, if you have a 6" lift which uses drop brackets. Because it will lower the front diff, which in turn lowers the front drive shaft. Which would then make them hit.
DelinquentTaco 01-23-2013 11:36 AM
I have 3" in front and 1" in back so it only has a 1/2 inch or 1/4 inch rake. But i do have diff spacers. what about the DT y-pipe?
Torspd 01-23-2013 11:44 AM
I don't have any experience with the DT Y-pipe on anything really. Sorry.
