-   -   DIFF swap?? tacoma help!!! (http://www.tacomaworld.com/forum/performance-tuning/264111-diff-swap-tacoma-help.html)
Emminasian 02-18-2013 10:14 PM
i have a 2011 tacoma trd sport 4x2 , what can i gain if i swap out the rear axle with 4x4 axle and diff? Lockers ?
smmarine 12-17-2013 07:27 AM
You already have a limited slip differential. I'm a first gen, so I'm not sure how it would work for you because you have a lot more electronics then I do. I think you would want a TRD Off Road axle if you wanted a locker, because that's what it is for the first gen, but I think it may be different for you. I think they did away with all the mechanical lockers and limited slips and went to electronically lockers and limited slips.
steezinstangl 12-18-2013 03:40 PM
nothing gained unless you want the elocker from the trd off road like said above ^^^ you might as well just put an arb locker in there if you want a locker or a detroit trutrac if you was a mechanical limited slip instead of the electronically limited slip (auto lsd)
