-   -   How 2 Disable VSC? (http://www.tacomaworld.com/forum/performance-tuning/272307-how-2-disable-vsc.html)
TacoOwner 04-08-2013 02:10 PM
How 2 Disable VSC?
Can anyone tell me how to permanently disabled the VSC on a 2011 4X4 or comparable? Thanks!
ToyotaTacoma4Ever 04-09-2013 03:15 AM
Have you tried holding the button down for 5 secs? That usually makes VSC system shut off completely
Or permanently as in you don't ever want it to turn on again when you turn the truck on and off? lol if you want that then im clueless
OZ-T 04-09-2013 09:34 AM
ABS bypass switch will kill ABS and VSC
TacoOwner 04-09-2013 10:20 AM
Yes I am sick of pushing the button. Often I am in deep sand trouble when I remember I should have done it.
Permanently is what I want.
OZ-T Can you elaborate? Where do I find the bypass and is it as simple as a unplug? Will this cause warning lights and trouble codes a plenty?
Thanks for the info.
OZ-T 04-09-2013 12:34 PM
What model Tacoma do you have , there are a few different mods
Benson X 04-09-2013 12:44 PM
Like OZ asked, there are different methods/solutions depending on your trim level.
I did a write-up that might help: http://www.tacomaworld.com/forum/tec...y-why-not.html
TacoOwner 04-09-2013 07:03 PM
Mine is; No TRD, No Locker, yes LSD, Manual Trans
I have buzzed thru the tread you linked. Looks like I can sort out what I need from there. Once I shut this soccer-mom crap down, get my TrueTrac installed, the Taco should suit my needs very well. Thanks for the help!
Benson X 04-09-2013 07:11 PM
Since it's a 2011 4x4 w/ no locker, you can do the mods in my writeup. ABS killswitch will kill 2 birds with 1 stone, and the YWM will enable TRAC in 4LO (ABS has to enabled to make it work).
TacoOwner 04-19-2013 10:29 AM
Got the YWM done, as well as the fog light mod. Thanks for the help guys!
