URD 2.825 Pulley No tune or Reflash?
Discussion in 'Performance and Tuning' started by lichbanshie, May 2, 2013.
  1. May 2, 2013 at 12:03 PM
    lichbanshie
    lichbanshie [OP] New Member
    mexico
    2010 4x4 SR5
    TRD Supercharger
    What if I install the URD 2.825 Pulley on my truck and dont tune or Reflash any goods or bads? Im new to the forums by the way itsa my first time posting all the way from Mexico:D
  2. May 2, 2013 at 8:34 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    not so low, not so slow 2006 6 lug
    stockish
  3. May 3, 2013 at 6:02 AM
    KingKoda
    KingKoda Never Satisfied
    Palmetto
    '12 TRD.S DCSB 4x4
    Boosted TRD/URD All Terrain Sleeper w/ Sockmonkey Decals Worth +666HP
    I have a similar question, but from my research around here, the 2.825 does not require a re-flash. I asked URD regarding tune and of course they recommend having it tuned but as stated, the stock TRD S/C flash should support the slightly smaller pulley. I think it's on the border and anything smaller would require potential ECU piggyback's and rising FPR's?
    I have my pulley already, I'm just looking for a write up to take it off/on. Found putting it on write up but not any tips for taking it off. Yeah, I know, instruction with pulley but would like to read anyone else experience in case I need to learn from someone else mistakes.
    URD did strongly recommend the URD full pump upgrade. I think I will purchase that as well. My concern was pushing too much fuel but apparently my logic was wrong and the fuel pump upgrade will just help keep fuel pressures up when RPM's rise to avoid getting too lean and not necessarily creating more fuel burn per se. May be off there in my thinking. The injectors are the link for amount of fuel to be combusted.
    I suppose the only bad would be voided warranty if you still have one.
    So yeah, if anyone knows chime in.
  4. May 3, 2013 at 6:08 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Wait, you have a TRD s/c and no reflash? So you are using the factory injectors and not the TRD injectors?
    Injectors feed the fuel to the engine. Fuel pump feeds the fuel to the injectors. If the injectors are to small, the engine cannot get enough fuel. If the injectors are the proper size, but the pump is to small, the injectors use more fuel than the pump can supply.
    The TRD s/c requires a reflash, IF you don't already have another form of tuning device. The reflash is a tune for larger injectors than stock because the stock ones will be at or over MAX IDC, with approximately 6 psi boost.
    With the TRD reflash, you don't need anything more, if you want to install the 2.85 pulley, then you can. Assuming that a fuel pump upgrade has already been done.
    There is more capability, with the reflash, but I will leave it at that.
  5. May 3, 2013 at 6:30 AM
    KingKoda
    Palmetto
    '12 TRD.S DCSB 4x4
    Thanks, - Yeah I had the dealership do my S/C install so they SHOULD have also upgraded the full gamut that came with the kit, upgraded injectors and reflash as to not have me coming in with issues regarding the warranty. I've got 10K miles on the truck and S/C and all has been swell. I feel like it runs ever so slightly rich as is from the amount of soot on my exhaust each week. But yeah, pushing a couple more pounds of air in the upper rpm range having solid fuel pressure to avoid scorching the cylinders
    I keep finding ways to spend more money on this truck, I'll order the Fuel pump upgrade as well.
  6. May 3, 2013 at 6:43 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Be sure to check out www.Dezod.com as well. Just look in the Xrunner section.
  7. May 3, 2013 at 3:48 PM
    Ostrichsak
    Ostrichsak Don't taze me bro!
    Jer
    Northern Colorado, USA
    Supercharged '10 Tacoma 4x4 TRD
    TRD Supercharger + too much stuff to list. Click sig pic
    The TRD supercharger requires a reflash and larger injectors that come with the kit. The URD 2.825" pulley does not require any additional flashes. If you go smaller you will need to to a lot more than slap another pulley on.
  8. May 25, 2013 at 11:09 AM
    lichbanshie
    mexico
    2010 4x4 SR5
    TRD Supercharger
    Do you know what specific fuel pump is recommended by URD for a toyota 2010??
  9. May 25, 2013 at 4:24 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
