Just got another taco need some hp help
Discussion in 'Performance and Tuning' started by xspxtacoma, May 14, 2013.
  1. May 14, 2013 at 8:55 PM
    xspxtacoma
    xspxtacoma [OP] Well-Known Member
    Michael
    miami
    Xsp-X tacoma
    Hey was up guys, I been doing some research on the forum and internet. And im looking to get some juice out my taco, I want to do some exhaust, intake,tune, i heard something about them having headers (any good brands long or short and same as well as y pipes) whats the best things out there to ad some nice bolt on to mess with my buddys taco
  2. May 18, 2013 at 11:45 AM
    ToyotaTacoma4Ever
    ToyotaTacoma4Ever Get Boosted
    Eric
    Alberta
    Supercharged Tacoma Sport
    Check Out The S/C Build
    Headers is a nice bolt on for N/A engine. Doug Thorley long tube Headers or JBA will are the top contenders. URD makes a nice y-pipe. To get the most out of an intake look into URD's MAF calibrator
    If you really want power best to go put on some kind of forced induction wether it be s/c or turbo'd
  3. May 18, 2013 at 2:35 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    not so low, not so slow 2006 6 lug
    stockish
    Do NOT free up the exhaust en tooo much without going forced induction or your low end tq will be lost.
    I screwed up....ur benefit is to do as I say and not as I do :)
    I installed doug thorely long tubes (deletes front cats), urd y pipe (deletes rear cats), and prolly worst of all a 3" exhaust on top of all that.
    I hated my truck more than u can imagine.....it felt gutless off the line.
    Granted I added waay too much at 1 time to tell u what made the most impact....
    Short tube headers retain cats and are supposed to retain low end tq.
    The only way I got the tq back (and then some obviously) was by getting a supercharger......now, I may love the truck now, but it was a very expensiv3 mistake that got me here and cost me an extra 4grand to fix all the n/a mods.
  4. May 18, 2013 at 2:39 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    If u go with the maf calibrator, make sure u can tune it or get it tuned....it leans the mixture, and if ur not careful u can do serious damage.
    Id also contact gadget and make sure he has install instructions for the 2013 in case the wires colors/pins have changed.
    U will have to solder all connections into your ecu.... do not crimp or use t taps. There's also no plug n play kit for the 2009+ unless u go with the kit that user "nut" sells/used to sell.
    Urd cannot get the proper connectors to make a plug n play harness due to what I assume is a copyright issue on a propriatory plug.
  5. May 18, 2013 at 4:15 PM
    ToyotaTacoma4Ever
    Eric
    Alberta
    I forgot to mention the years in my statement there so really it's only good for 05-08, don't think the XSP version of the taco will go with the MAF calibrator
  6. May 18, 2013 at 8:40 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    wut? xsp doesn't have anything different, mechanical, then any other v6 taco. if just has rims and misc exterior and interior parts. 05-08 are able to have plug in connectors whereas newer models have to be wired in.
  7. May 18, 2013 at 9:11 PM
    ToyotaTacoma4Ever
    Eric
    Alberta
    So Toyota always has a XSP version dated back to 05? I only heard of this model like last year lol
    Yeah i know nothing mechanically changed, just cosmetic changes
  8. May 18, 2013 at 9:23 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    I don't think he was stating what yrs toyota offered xsp..........just that they are no different other than cosmetics than any other 05+ tacoma V6.
    He is stating that URD does not offer a plug and play harness for any tacoma after 2008 models due to a change in the ecu connectors that are not available to Gadget (urd).
    He did use a .
    After that sentence... maybe it woulda been easier to notice/seperate with a seperate line?
    I dunno, I understood exactly what he meant
  9. May 19, 2013 at 8:33 AM
    ToyotaTacoma4Ever
    Eric
    Alberta
    Reading to fast lol after re-reading it makes better sense now
    Yeah I did know the difference in years for the plugs
  10. May 19, 2013 at 11:09 AM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    I do it a lot (adhd).....that's kinda why I tried to clarify, I speed read thru crap alot and it may as well be greek
    When I take my meds, its better tho......otherwise I woulda been like wtf? Too
